NorCal Autocross
Old Feb 18, 2011 | 09:41 AM
  #161
christoc's Avatar
christoc
Grant,
I thought the 370's had a bit more space than the 350z's? I can get (4) 285's in my Z. It isn't a fun fit, but I can get them in there.
I can get 4 305s in the car (remove all the spare tire and tools). Makes it hard to get in reverse, but I can get her done
Old Feb 18, 2011 | 09:44 AM
  #162
03threefiftyz's Avatar
03threefiftyz
^What is your method of getting them in? Likewise...my only issues are getting into 6th and R.
Old Feb 18, 2011 | 12:32 PM
  #163
Shamu's Avatar
Shamu
Robs dead set against me putting tires in my new Nismo, but I told him I'd bag them. LOL! Maybe somone can come down to shop and distract him while I load the tires in the car. LOL!
Old Feb 18, 2011 | 02:03 PM
  #164
scotts300's Avatar
scotts300
Tire totes - about $80/set. There is a set at ZCG, but they are mine!
Old Feb 18, 2011 | 02:44 PM
  #165
03threefiftyz
At the same time, though, I would be DEAD set against you driving 40mi each way on A6's.
Old Feb 18, 2011 | 02:47 PM
  #166
christoc's Avatar
christoc
Here's my config
1 in spare tire location
1 behind driver/pass seat on a towel
2 laying somewhat flat in passenger seat and on center console
Old Feb 18, 2011 | 03:01 PM
  #167
03threefiftyz
Originally Posted by christoc
Here's my config
Same as me. Was just curious if there was another way I wasn't thinking of.
Old Feb 18, 2011 | 03:05 PM
  #168
scotts300's Avatar
scotts300
Here's my config
I actually stand mine up on the passenger seat, so only the really wide ones start to crowd reverse and 6th.
Old Feb 18, 2011 | 03:18 PM
  #169
03threefiftyz
Do you bungie them or something to keep them from toppling over?
Old Feb 18, 2011 | 03:20 PM
  #170
christoc's Avatar
christoc
I tried standing up but didn't have any luck
Old Feb 18, 2011 | 03:28 PM
  #171
scotts300's Avatar
scotts300
No. I usually snug them up against the dash, and put a hand on them when I make right turns.
Maybe I can do them this way because my door panels are removed?
Old Feb 18, 2011 | 03:38 PM
  #172
christoc's Avatar
christoc
That woud likely do it
Old Feb 18, 2011 | 08:33 PM
  #173
Shamu's Avatar
Shamu
Picked up the car! We did dyno with new high flow cats. 316 hp and 260 ft/lbs of torque. That's on stock Nismo tune. Up Rev hasn't cracked the code on Nismo yet. Those new cats really woke up the motor! Sounds cool too!
LSD feels great. We weighed the race wheels and they are almost 40lbs lighter with tires than my street setup! Wicked 315's fill up the rear. I think I may be able to go to 295 from 285 up front.
Got negative camber and a little toe out too!
Raining to hard to stop by tonight so I will get teched tomorrow. Will throw on a6 if it stops raining at Z car garage in the am. Then drive a couple miles to the event.
Old Feb 18, 2011 | 08:43 PM
  #174
christoc's Avatar
christoc
I got some new street tires mounted tonight just in case I decided there's too much water for the V710s, but if it isn't down pouring during my runs V710s it will be!
Grant and I are running first heat, working third. I'll be in the trailer announcing
Old Feb 18, 2011 | 09:06 PM
  #175
Shamu's Avatar
Shamu
I thought SP classed cars go rg4? Do all indexed cars run together? Is that x class?
Old Feb 18, 2011 | 09:15 PM
  #176
christoc's Avatar
christoc
X is index class, all in rg1.
U need an X on car too afaik
Old Feb 18, 2011 | 09:20 PM
  #177
christoc's Avatar
christoc
Ill be there around 630a.
Old Feb 18, 2011 | 09:24 PM
  #178
Shamu's Avatar
Shamu
Well I may be on streets regardless of conditions then. My hoosiers are at ZCG. Don't know if I will have time to run over there. Do you know when first car goes out?
Old Feb 18, 2011 | 11:25 PM
  #179
scotts300's Avatar
scotts300
New street tires? Sweet! On what wheels?
Dang! That's some great power! That puts your wt/hp at 10.3 - wow! That's WAY better than mine (11.1) - and my car is lightened a bit! You should bring the Z over to the scales by the airport to get an actual weight on the race tires. I'm glad you guys aren't in my class!
Good luck to you both this weekend!
Old Feb 19, 2011 | 04:54 AM
  #180
christoc's Avatar
christoc
First car 9a. Drivers mtg 830 tech/reg before that
