Norcal Track Days
Old Mar 17, 2012 | 09:50 PM
  #841
scotts300's Avatar
scotts300
Next event for me is CityTech. Gotta sort out the race car - needs lots of help. The car is faster than the GreenZ, but I was a few seconds slower at Sears in the new car compared to the green car last week.
Old Mar 18, 2012 | 10:05 AM
  #842
SE5spd's Avatar
SE5spd
^ you think the race car is possible to hit under 2:00 at thill bypass?
Old Mar 18, 2012 | 10:10 AM
  #843
03threefiftyz's Avatar
03threefiftyz
I ran a 1:57 on my 50cc pit scooter....
Old Mar 18, 2012 | 11:02 AM
  #844
SE5spd's Avatar
SE5spd
Psh, I ran it faster then that.
Old Mar 18, 2012 | 11:27 AM
  #845
03threefiftyz
Originally Posted by SE5spd
Psh, I ran it faster than that.
Corrected...
Old Mar 19, 2012 | 08:57 PM
  #846
scotts300's Avatar
scotts300
Using the bypass? Yes, depending on what tires I show up with.
Old Mar 19, 2012 | 09:03 PM
  #847
SE5spd's Avatar
SE5spd
thatd be sick if you click under 2:00
Old Mar 20, 2012 | 07:51 PM
  #848
scotts300's Avatar
scotts300
Hmm. I thought I ran a 2:04.xx with the cyclone at some point, but I'm only seeing a 2:05.xx. I believe I was about 2s faster with the bypass, so 2:02/2:03. With fresh tires, which I hope to run (the SpecZ tire) and some confidence, the new Z should be pretty fast. It still needs a lot of sorting out with the compression/rebound, camber, ride height, dyno tune, etc., so maybe not.
Here is some vid from it's very first dry day at the track, and first day with the SpecZ shocks and springs. Lots of throttle-on oversteer post-apex, which slowed me down greatly. I figure it's because of the new, higher spring rate, rear springs:
http://youtu.be/XPsQvwVDjXc
Old Mar 21, 2012 | 10:00 AM
  #849
Neimad's Avatar
Neimad
How much fuel were you running and have you started playing with the ballast I'm assuming you need to meet your rev-up weight requirements?
Old Mar 21, 2012 | 01:01 PM
  #850
SE5spd's Avatar
SE5spd
I just got a GOPRO HD 2, im excited to use it in April at thunderhill
Old Mar 21, 2012 | 03:17 PM
  #851
03threefiftyz
You shoulda bought shocks.........
Old Mar 21, 2012 | 06:39 PM
  #852
SE5spd's Avatar
SE5spd
GOPRO = $300
shocks = $1100
Old Mar 21, 2012 | 06:44 PM
  #853
Neimad's Avatar
Neimad
Ohlins 2500? Somebody's got the Spec Z itch.
Old Mar 21, 2012 | 06:46 PM
  #854
SE5spd's Avatar
SE5spd
I wish
im about to move so I shouldn't even be doing things like buying LSDs and track related items since ill be 100% busy with school next semester but I still do
Old Mar 21, 2012 | 06:52 PM
  #855
Neimad's Avatar
Neimad
I hear ya, for what I pulled out of the stock market to buy what little I have on this car I would have had my own shop and a GT3 RS 4.0 etc etc etc. Suffer in your 20's, have fun later.
Old Mar 21, 2012 | 07:24 PM
  #856
SE5spd's Avatar
SE5spd
thats the plan
Old Mar 22, 2012 | 11:58 AM
  #857
scotts300's Avatar
scotts300
I started the day with a full tank. I don't need any ballast, as I'm still about 80# porky. I found about 60# to remove, so I won't be flirting with going under the min weight and should sit right about 3200# (with driver) at the end of the race.
Old Mar 22, 2012 | 04:01 PM
  #858
Neimad's Avatar
Neimad
Try putting about 50 pounds of ballast in spare wheel well, don't ask how I know.
Old Mar 23, 2012 | 08:55 PM
  #859
solidfish's Avatar
solidfish
Hey guys. Had another day at Laguna Seca a few weeks ago. Was hoping to get your critiques. I think I still take a lot of those turns too early. Errr, I need to break out of that!
The Genesis has a high rev hanging problem where on the down shifts, the rev just hangs. Makes it difficult to gain acceleration out of some the turns. Also, I've noticed the 350z has a far smoother transmission than than the Genesis. Some of those shifts were very rough.
http://youtu.be/ApHNuCtiCyo
Any of those Zs folks here on the board? I saw about 3 or 4 of them that day.
Old Mar 24, 2012 | 12:34 AM
  #860
SE5spd's Avatar
SE5spd
what camera are you using and how are you mounting it?
thats how I want my videos to look.
