Norcal Track Days
Old Nov 18, 2012 | 11:25 AM
  #1041
scotts300's Avatar
scotts300
Originally Posted by the3kgt2
My dad tried out Trackmasters which is a $10 Android app. It's a very promising app but he had poor success at Infineon. I might try it the next time I'm at Laguna.
CMSLapTimer is free and has worked well for me.
Old Nov 18, 2012 | 02:15 PM
  #1042
Voboy's Avatar
Voboy
Racechrono is also free and has worked really well for me too. They have been around on the older Windows mobile phone for some time now and just added android support.
Old Nov 20, 2012 | 05:22 PM
  #1043
Shamu Z's Avatar
Shamu Z
Originally Posted by scotts300
Anyone headed to Laguna 12/1-2 with TMR? We will have at least 3 Zs there.
A SpecZ? I don't know of any others that have fully completed prep of a SpecZ. None have shown up for any of the NASA races at least. Maybe next year.
Yes, power is advantageous at Laguna, but of course only to a point. Good brakes and ***** to push the brakes are a very close 2nd, hence why we scoop up those other cars that should be faster than us but aren't. I agree that your 500hp toy should be capable of a solid sub 1:40, like 1:35, but none of that matters until the car proves it can last without failure, overheating of oil/water, sound, etc. There were two supercharged 350s there a few weeks ago, and both ran in the 1:45-1:49 range. Power can't make up all of it.
Just wait until next season! There is a shop being built next to my place that will be building a couple spec Z cars with fast drivers. The spec car that ran is in progress. I may rent one in 2014.
My car wasn't getting hot - under 220 degrees after 5 laps. I have also run it in 100 degree temps at hillclimb with no issues. Remember I have upgraded higher efficiency racing radiator, big oil cooler, bigger finned higher capacity oil pan. I'm not too worried about overheating. I'm talking to guy about dry sump next. As long as you don't over rev VQ 37 temps should be fine.
If your a driver power is everything. But my little 170whp 914 used to click off 1:41 lap times all day long but then it weighed about 2000 lbs!
Old Nov 21, 2012 | 08:07 AM
  #1044
scotts300's Avatar
scotts300
I know Lock and his upcoming shop, as well as the car they are building. Last I saw that car doing TTs it was on a street tire, no cage, etc. My car as a SpecZ is 1-2s slower than it was before the transformation! Need front camber, and sure do miss the power it used to have as well as the Hohos.
Old Nov 23, 2012 | 03:43 PM
  #1045
SE5spd's Avatar
SE5spd
Just ordered a oil cooler
Old Nov 25, 2012 | 03:11 PM
  #1046
SE5spd's Avatar
SE5spd
Anyone going to Thunderhill with citytech on 12/29?
Old Dec 17, 2012 | 10:35 AM
  #1047
wheelophile's Avatar
wheelophile
I'm sad the track season is over for me. Although NCRC and TMR have some awesome events lined up for 2013! =D
You doing that "track pack" with Citytech, Sina?
Old Dec 18, 2012 | 08:37 AM
  #1048
SE5spd's Avatar
SE5spd
Can't swing it. I have to install oil cooler, brake ducts, change brake fluid, pads, oil, coolant before I can track again. I'm gonna try and get it done ASAP I'd like to do thunderhill Atleast 2x while I'm home for winter break.
Old Dec 30, 2012 | 08:44 PM
  #1049
solidfish's Avatar
solidfish
Nice to see this thread is still active. Had another track day and was seeking the advice of the gurus here.
Had a very wet Laguna Seca track day last week. First time driving on a completely wet track. Ran first session without traction control and could not keep the car under control. Ended up going off track so spent the rest of the day with TCS on.
I had a very hard time driving with TCS. Dont remember if the Z is like this but once TCS is initiated, it wont shut off until I shift or coast steady for a long time. So although it might assist me on a turn, I can never regain acceleration. I end up shifting up and just crawling my way out of the turn. Any advice on this?
Here are a couple of clean laps with minimum slip. I dont track often anymore but was trying to remember to turn in later. Dont know if it was due to the rain but I think my lines are still a bit off.
Old Dec 31, 2012 | 11:23 AM
  #1050
mdd's Avatar
mdd
^ what car is that?
Old Dec 31, 2012 | 10:35 PM
  #1051
ITOzann's Avatar
ITOzann
Originally Posted by mdd
^ what car is that?
genesis
Old Jan 1, 2013 | 11:47 AM
  #1052
Shamu Z's Avatar
Shamu Z
Rob and his crew have been busy on my 370z.
Carbonfiber hatch painted and polycarbonate window installed
Cut fuel tank in half
Car is down to 2800 lbs now. I have titanium exhaust system coming this week that will drop another 40 lbs. So car when finished should be at 2750 lbs.
Car has lost 500 lbs since I drove it first time on the track. It's also gained 137 HP!
Old Jan 5, 2013 | 04:44 PM
  #1053
SE5spd's Avatar
SE5spd
going to patricks laguna seca day on 2/3/13, anyone else? its going to be my first time there. Im hoping its nice and dry and I dont have any problems
Old Jan 21, 2013 | 02:18 PM
  #1054
ITOzann's Avatar
ITOzann
Might attend in a Prius with RA1's or a miata
  #1055
ITOzann's Avatar
ITOzann
Anyone in here planning to do NASA TT for this upcoming season?
Old Jan 22, 2013 | 08:25 AM
  #1056
scotts300's Avatar
scotts300
PERfect day at Laguna yesterday with Patrick (in his MiataR) and friend in supercharged 350Z. Going again 2/18, and maybe with Patrick 2/3.
Old Jan 22, 2013 | 09:34 AM
  #1057
dphoenix's Avatar
dphoenix
Hei guys, I am david looking for buddies that can go track with me later this year. I have met scotty before, he actually taught me once over at thunderhills longg timee back. I dont know if he still remembers me.
Actually I am happy to find this thread as not that many interests here in bay area doing track.
It has been awhile since last time I went to track. My next track day will be at Thunderhills Feb 8. Anybody wanna go together? I go through NCRC.
http://www.ncracing.org/events.php
Old Jan 22, 2013 | 10:30 AM
  #1058
scotts300's Avatar
scotts300
David - of course I remember you! We go about 1/month. Maybe going with NCRC 2/18 to Laguna; not going to T-hill though. Likely going with NASA to Sears 2/9-10 as well.
Old Jan 23, 2013 | 06:24 PM
  #1059
dphoenix's Avatar
dphoenix
hei Scott, glad that you still remember me. Lets do track together again.
Old Jan 28, 2013 | 11:37 AM
  #1060
pchio's Avatar
pchio
That's right. My event will be coming up this Sunday at Laguna Seca. Gonna be a fun and sunny day with very minimal traffic! Dont miss out. Z Car Garage crews will be there!
Coupon code "Zforever" for $50 off
http://citytechsf.com/track
