Don't update osiris!!
Old 06-30-2018, 04:43 PM
arficus
arficus's Avatar
Default Don't update osiris!!
OMFG. If you haven't used osiris software in a while DON'T let the updater run!! It updated the firmware on my cable. Now cipher is irretrievably gone. I deleted new installation, deleted all references to uprev in windows registry, installed old version of osiris, and none of the software works - won't detect cable. Cable firmware update is obviously to blame.
Don't let anyone fool you - cipher functionality in new all-in-one software is way less than old stand alone app. I've lost access to some features that were part of the reason I bought osiris to begin with. In other words, I paid for things and uprev stole them. Uprev is on my **** list now. I'm pissed.
To make matters (much) worse, new software won't let me flash or even edit any of my "old" ROMs because it claims ECU base file is out of date. Pure BS. I can find no substantive difference between "new" base file and old. And what about everyone who has been running "old" base file successfully for years? What's the problem uprev? I had big library of maps - all useless now.
NissanZcrazy (07-04-2018)
Old 07-01-2018, 07:20 AM
mgk5391
mgk5391's Avatar
Thanks for this. Unfortunately, it's too late for me.
But if possible, since you have an older installation file, could you install it in another laptop that's never had Uprev programs? That might work.
Old 07-01-2018, 12:39 PM
arficus
arficus's Avatar
No, that's not possible as far as I can tell - the cable firmware "update" that was forced to be installed by the updated osiris software disallows the cable to be used with all older software.
BigBlue (07-01-2018)
Old 07-01-2018, 02:37 PM
mgk5391
mgk5391's Avatar
Ah missed that but understood. Only thing I could think is to reach out to them for possible work around. The fact that all your older ROMs are no longer compatible should be enough for them to do something. Really makes no sense for them to push that type of Firmware update without making it optional.
Old 07-01-2018, 03:12 PM
BigBlue
BigBlue's Avatar
This kind of Sucks!
Old 07-01-2018, 03:48 PM
onevq35de
onevq35de's Avatar
I read something along the lines of uprev having been ****ed, not proper ****ed, but ****ed nonetheless.
What does it all mean? What features have been lost and what other issues are there?
Old 07-04-2018, 05:47 AM
seymore4
Professional
seymore4's Avatar
Cipher has been gone for a long time. You can do everything important with the Rom Editor.
When they released the ARC features they had to push a major update to ALL the Z/G rom files, and no you can't flash the old ones anymore. They can still be viewed in rom editor however, so all you or your tuner has to do is copy the tuned tables into the updated rom and you're good to go.
As much as it does suck never updating software or trying to use outdated software is never a good answer...
The following 2 users liked this post by seymore4:
BigBlue (07-04-2018), BluestreamDE (09-16-2018)
Old 09-16-2018, 03:47 PM
ashram
ashram's Avatar
To late for me 😑, thanks uprev now I can't delete these dtc codes.
Old 09-16-2018, 04:01 PM
BluestreamDE
BluestreamDE's Avatar
I personally check for updates everytime I load up Rom Editor. And if I get codes, once I read them I clear them. No that hard.
Old 10-02-2018, 10:32 AM
RENFRO
RENFRO's Avatar
Anyone know if it's possible to have old DTC codes that were disabled, turned back on? I used to have an exemption from emissions being away from home in the military, and had the DTC codes turned off to avoid an engine light.
However, now I'm back in my home state and will need to run the car through emissions. Plan is to use the mechanical spacer/non-fouler method, but I'll need the O2 sensors to be in a ready state.
Old 10-02-2018, 11:20 AM
seymore4
Professional
seymore4's Avatar
You will need to contact whoever did the tune originally, or if you were to retune it the original tune would be overwritten
Old 10-03-2018, 09:19 PM
Blizzard25
Blizzard25's Avatar
Deleted
Old 10-14-2018, 06:12 PM
420YOLO403G
420YOLO403G's Avatar
also you lose the ability to turn off DTC with the update.
https://my350z.com/forum/tuning/6142...es-by-law.html
I should really hold off on software and firmware updates... I have ART pipes and was going to try to run without downstream o2 cause i think they are messing up my AFR. Now I cant turn off the those DTC codes. Maybe someone here can help me out?
Old 10-14-2018, 06:19 PM
seymore4
Professional
seymore4's Avatar
The alternative for Uprev is this:
https://www.epa.gov/newsreleases/epa...defeat-devices
Old 10-14-2018, 06:48 PM
420YOLO403G
Ouch! yea for sure Uprev did the right thing and did what they had to do. I think that really kills off any hope of them bringing those features back.
There are no emission law here where I live so i am still looking for someone to help me disable those codes, please PM me if anyone can help me out. Thanks!
Old 10-14-2018, 09:04 PM
seymore4
Professional
seymore4's Avatar
The emissions laws are federal, not local. That's why the EPA is involved. Whether your local area tests or not depends on the state and county...but the actual LAW, is the same
Old 03-16-2021, 09:00 PM
ENZORICCI
ENZORICCI's Avatar
The same thing happened to me too uprev does not work after I pay $ 750
Old 03-17-2021, 06:05 AM
seymore4
Professional
seymore4's Avatar
What do you mean it doesn't work?
Warishuku
Tuning
09-08-2018 07:01 AM
micho196
Tuning
15
05-29-2018 05:06 PM
sry110
09-04-2014 07:31 AM
dikspiel
05-13-2014 04:55 PM
T_K
Tuning
29
11-10-2011 09:49 AM
Quick Reply: Don't update osiris!!
