I just dont know what to do anymore....
Old 09-19-2018, 01:50 PM
Anthonypalacio
Anthonypalacio's Avatar
Default I just dont know what to do anymore....
Alright guys ive been experiencing hard starts for way too long now, my car has to crank way too much before it starts, and when it does turn over its sounds crazy with the car struggling. And on top of that i recently installed new spark plugs and the car is having a hard time getting in to any gear passed the 3rd. mind you its an automatic.
what ive done to the car:
recently installed spark plugs, NWP throttle body, cleaned the MAF and got a new key from the dealership.
Also got a brand new battery like a year ago, and fuel pump like 2 years ago and camshaft sensors as well like a year ago. And ive done all the appropriate computer resets as i changed the parts.
Seriously im just done man and i have 10 days till i have to make a 9hr drive back to base... please help
Old 09-19-2018, 05:50 PM
philliesfan1992
philliesfan1992's Avatar
How many miles are on the z?
Does it ever sit for long periods of time while you’re deployed?
Old 09-19-2018, 07:02 PM
onevq35de
onevq35de's Avatar
How did the car run prior to... "recently installed spark plugs, NWP throttle body, cleaned the MAF and got a new key from the dealership." ?
If everything was fine before these things you need to go back over what you've done. Did you disconnect the battery prior to unplugging the MAF or throttle body?
It sounds like you've got either a fuel delivery problem OR an "ecu doesn't know what the hell's going on cause freakin Antny done forgot to plug something back in" problem.
Old 09-19-2018, 09:07 PM
Anthonypalacio
97,900 and i just got back it sat for 6 months with the car being turned on every week and moved rarely
Old 09-19-2018, 09:09 PM
Anthonypalacio
prior to all the recent work the car would still crank forever before starting. And yes the battery was disconnected before all the work was done.
Old 09-20-2018, 02:20 AM
onevq35de
onevq35de's Avatar
Oh, so not Antny's fault. So, it was fine before 6 moths ago Saturday? It's started every week, so who's starting it? Your little brother with a "need for speed" maybe?
If it was fine when you stopped driving it 6 months ago and now all of a sudden it's not, maybe old bad gas, fuel delivery OR the person watching the car did something.
Old 09-20-2018, 03:44 AM
BluestreamDE
BluestreamDE's Avatar
My guess is that you need to do a throttle relearn with the new NWP. The ecu has to learn the new throttle, since its calibrated to the oem one. You can look up the procedure on here in the forum.
Another place to look is the coilpack plugs that hook to the wiring harness. A lot of folks switch out cylinder 4 and 6 plugs, causing rough idle and operation (Possibly hard starts as well).
Old 09-20-2018, 04:17 AM
onevq35de
onevq35de's Avatar
"prior to all the recent work the car would still crank forever before starting. And yes the battery was disconnected before all the work was done."
The issue was there before the throttle body.
Old 09-20-2018, 04:47 AM
Anthonypalacio
i did all the relearn procedures for the throttle body provided by NWP And im 100% sure the that all was pluged in in the correct order
Old 09-20-2018, 05:46 AM
dkmura
dkmura's Avatar
I'd question whether fuel pressure might be an issue. The fuel pressure regulator in a VQ should maintain some pressure in the lines at all times. If not, it'll take time to built pressure and get the engine to start.
Old 09-20-2018, 09:05 AM
Trayn
Trayn's Avatar
Stupid question, when was the last time you put gas in the car? Is it running on the gas that has been sitting there for 6 months?
Old 09-20-2018, 09:28 AM
khnitz
khnitz's Avatar
Building on dkmura's comment on fuel pressure, does it start any faster if you cycle the key a few times first, before trying to start the car. This would allow the fuel pump to prime a few times and build up pressure in the lines (if fuel pressure is the issue). If it starts faster after trying that, then you have something else to look at (fuel pressure regulator).
Note: I am basing this on the behavior of other vehicles I own and am more familiar with, that cycle the fuel pump for a few seconds with Ignition On. I'm not familiar enough with my Z yet to know that it also does this. For example, our 2005 Volvo V70R starts easier if we hesitate for a second between Ign On and Start positions when turning the key - it gives the fuel pump time to build pressure (this is something I'll fix, eventually).
Old 09-20-2018, 09:47 AM
Anthonypalacio
ive filled it up like 2 days ago its not running on old gas
Old 09-20-2018, 09:52 AM
Anthonypalacio
I never really payed attention to that but yes, usually at some point after a few cycles the car would turn on faster and not crank as much
Old 09-20-2018, 12:18 PM
khnitz
khnitz's Avatar
OK, so next time, cycle the ignition a few times (without attempting to start it), and then cycle on again and try to start it...see if it catches quicker than without the additional cycles.
Old 09-22-2018, 06:45 AM
BluestreamDE
Did you ever figure out what happened?
Old 09-22-2018, 12:48 PM
Anthonypalacio
not yet me and my boys are working on checking the sensors and going over all the parts we installed to see if we messed up on anything
Old 09-28-2018, 08:28 AM
Anthonypalacio
Default Fixed
It turned out to be the fuel pump.... i refused to believe that was the problem since i had already changed it and didnt think it would go bad so fast. But I appreciate all of you guys who tryed to help. 🙌🏼👍🏼
The following 2 users liked this post by Anthonypalacio:
blufc3s (10-03-2018), khnitz (09-28-2018)
Old 09-28-2018, 08:29 AM
khnitz
khnitz's Avatar
Glad to hear you got it sorted out! And thanks for posting the resolution, too.
superchargedg
Mid-Atlantic
56
06-17-2011 10:23 AM
arodbrs
Southern California
07-13-2005 08:51 AM
Quick Reply: I just dont know what to do anymore....
