03 350z Emergency break
Old 02-16-2019, 02:52 PM
Anxietylol
Anxietylol's Avatar
Default 03 350z Emergency break
Hey guys,
Gonna break down for you what I've already done to try to fix this issue
*I have tried the bolt/nut that is inside the coin/cup holder by tightening it up
*I have switched out the drum break springs in the rear and have spent hours just flipping the dial up and down and testing the break
regardless of these two things, the car will still roll back in a slight incline.
i live in a hilly area and would like to have the e-brake working properly if the emergency were to ever happen.
Any idea's on different things i should try?
Old 02-16-2019, 07:00 PM
spitfire91104
spitfire91104's Avatar
Just curious. Have you replaced the shoes themselves?
Just replacing the drums that are built into the rotors may not help if the shoes are worn.
Also the cables themselves could be stuck. As these cars get older the physical lines could be getting corroded and sticking a bit which would cause you to lose parking brake performance.
Old 02-16-2019, 08:28 PM
Anxietylol
Anxietylol's Avatar
Haha i forgot to say yes, yes i did replace the shoes as well!
Can you speak more into the cables? how would i locate/replace?
Old 02-17-2019, 12:10 AM
mr. sparco
mr. sparco's Avatar
Adjust the interior hand brake lever and exterior brake adjustment screw. Be sure it is between a point where it is not constantly engaged. Search diy on how.
Old 02-17-2019, 06:41 AM
spitfire91104
Yeah under the car you should see the black cable coming out just below where you adjust the nut in the center console. Follow it back to where it branches off. Double check to make sure both branched out cables move with ease and evenly.
But first make sure it is properly adjusted like the other gentleman said. There should be a sticky on here but I know for sure it's in the Haynes manual. I am currently out of town otherwise I would send you pics of the pages.
After proper adjustment i cant think of any other parts you haven't replaced besides the cables. Not much more to the system that that.
Old 02-17-2019, 07:12 AM
Heel Til I Die
Heel Til I Die's Avatar
PB section of the FSM is only a couple pages, so I'll post them up:
Spike100 (02-17-2019)
Old 02-17-2019, 07:33 AM
Anxietylol
Anxietylol's Avatar
Hmm i'll have to look underneath the car then.
i still have to park in gear with e-brake up because i still roll backwards on the slightest incline/decline
I've tried different settings with the drum breaks that it's made no difference... definitely at a loss here
Old 02-17-2019, 10:18 AM
Heel Til I Die
Did you do the break-in procedure and then readjust everything?
Old 02-17-2019, 11:51 AM
tmdz
tmdz's Avatar
It's really frustrating that Nissan copyrighted the FSM for a model they don't even make anymore. I'm REALLY glad I downloaded the whole thing before they did that.
Old 02-17-2019, 12:36 PM
Spike100
Spike100's Avatar
I was experiencing problems with my e-brake (i.e., the brake did not immobilize the car).
The fix required new shoes (the original shoes were worn past usefulness), freeing the cable (it was partially "frozen,") and adjusting the "pull."
Old 02-17-2019, 12:48 PM
Anxietylol
Anxietylol's Avatar
Not gonna lieeee no i have not it is currently winter and i havent driven the car yet..
Blu_Blur
07-20-2006 10:05 AM
scottlewis
02-13-2003 08:45 PM
FoleyF
11-21-2002 04:47 PM
donkeykong
10-16-2002 07:14 PM
Quick Reply: 03 350z Emergency break
