Some issues with my UTEC
Old Jul 8, 2007 | 05:11 PM
Andres_Miami's Avatar
Andres_Miami
Question Some issues with my UTEC
I did a search on the forum to see if someone have already post about this, unfortunately no one has come up with the question or I did a poor job searching for the answer.
As you will see in the pictures, my parameters do not resemble the Turbo XS manual on page 38. I’m trying to increase my RPMs, but I’m having a lot of problems doing so.
My parameters
Turbo XS
Could someone help me out with this or point me to the right direction? Also, if I have a 05’ enthusiast, what should be the values that I should use to increase my RPMs?
Old Jul 8, 2007 | 05:48 PM
westpak's Avatar
westpak
SFZCC
well first 65 is not really increasing it, and you want to set it about 200 rpm higher than you want the limit at.
Old Jul 8, 2007 | 06:06 PM
Andres_Miami
Gus, if you see my graph is the one on top. It is set up for 80
Old Jul 8, 2007 | 06:57 PM
rcdash's Avatar
rcdash
Where does the rev limiter cut in? Are you sure you're not in valet mode? The params on that page look ok to me...???
Old Jul 9, 2007 | 10:23 AM
Andres_Miami
As far as I know, parameters do not change with the maps. But, anyway I'm running on #3
Old Jul 9, 2007 | 11:54 AM
Mike@IOS's Avatar
Mike@IOS
IOS Performance
What year is ur car? I believe it can only increase revs for 03-04.
Old Jul 11, 2007 | 08:52 AM
rcdash's Avatar
rcdash
It should have complete control of fuel so I don't get it. Call TurboXS - their phone tech support is excellent.
Old Jul 13, 2007 | 05:04 PM
Andres_Miami
I tried couple of times, but it still busy. I guess have a lot of callers
Old Jul 16, 2007 | 02:22 PM
MDeezy's Avatar
MDeezy
parameters look decent too. I did remember hearing that there is an issue raising the rev limiter on the rev up Z's. Not sure if they have solved the problem yet.
https://my350z.com/forum/tuning/285381-soft-rev-limit-on-utec.html
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
