03 rpm signal wire?
Old Jan 3, 2008 | 02:29 AM
djclongisland's Avatar
djclongisland
Question 03 rpm signal wire?
did my serching guys, theres 1 write up for a raptor, but i cant open it for some reason, i know we had individual coils, so did my spec v, what wire is the RPM signal wire on the back of the gauge cluster please thank you
Old Jan 3, 2008 | 03:53 AM
tourinz's Avatar
tourinz
coool that you researched it, but you put ur question on the wrong section of the forum...
Old Jan 3, 2008 | 04:42 AM
djclongisland
ok seriouslly, im looking for an answer not critisism, thank you
Old Jan 3, 2008 | 05:37 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Is the '03's wire in a different place than the '04 to current? I'll assume that its not in the same place attached to the AC amplifier module.
Old Jan 3, 2008 | 06:53 AM
djclongisland
please just a color of a wire thats all i need thanx
Old Jan 4, 2008 | 08:43 AM
rcdash's Avatar
rcdash
I believe the gauges are controlled by CAN signals, so there would be no wire back there to tap...
Old Jan 6, 2008 | 12:35 PM
GTM's Avatar
GTM
Vendor - Former Vendor
This guy isn't very nice, lol. It should be a pink wire behind the A/C Control, can't remember the pin out, but I am pretty sure the pink wire is the VSS.
Good luck!
-George
GT Motorsports
Old Jan 7, 2008 | 09:59 PM
djclongisland
ok thank you, i apologize about the tude... ive just had some problems on the fourm (not with you guys) and i just wanted a straight answer... after reading over what i wrote your exactlly right, i will watch my E-tone lol
Old Jan 7, 2008 | 10:01 PM
djclongisland
iesent the vss wire vehicle speed sensor? im looking for RPM for a shift light... thanks
Old Jan 8, 2008 | 04:19 PM
Chebosto's Avatar
Chebosto
since this is a CAN based ECU system, we don't have a traditional single wire output for RPM signal. the back of the cluster actually accepts all 6 coil inputs via the unified AMP meter to display RPM on the tach.. however most recent shift lights can be adjusted to accept single cylinder operation, if thats the case then you can pull the signal off of the ignition wire signal for cylinder 1 which is off of the ECU harness.
Old Apr 14, 2009 | 02:22 PM
Khanvict's Avatar
Khanvict
im gonna bump this thread.. does anyone have any pics of where the tach/rpm signal is or the coil? i have an rpm/shift gauge (stewart warner) that i need connected but cant find a way to get an rpm pulse. thanks.
Old Apr 19, 2009 | 05:31 AM
hippie's Avatar
hippie
No pics, but this lists the pin-outs and wire colors.
http://www.innovatemotorsports.com/r...5_G35_350z.php
aarrgghh
May 1, 2022 11:04 AM
350Z_Al
Oct 29, 2020 07:44 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Daniel_dh
Sep 7, 2015 12:56 PM
