FP Exclusive 1st: The VQ35HR Dissected
Old Apr 22, 2007 | 09:37 PM
  #81
Justin@WestCovinaNissan's Avatar
Impressive and very thorough! Interesting finds indeed!
Old Apr 23, 2007 | 05:29 AM
  #82
ZLadie2000's Avatar
ZLadie2000
Confirmation for pre-07 clutch and flywheels not working on the 07?
Old Apr 23, 2007 | 05:54 AM
  #83
Mansmind's Avatar
Mansmind
According to Nissan no, I was considering upgrading to the Nismo clutch... the '06 or older will not work.
John
Old Apr 23, 2007 | 06:37 AM
  #84
rythex's Avatar
rythex
I'm mainly interested in the heads... it would be nice to be able to slap the HR heads on and get a nice redline increase..
Someone go get some HR heads and slap them on a <06 :P
Old Apr 24, 2007 | 04:42 AM
  #85
brooke's Avatar
brooke
Well hurry up sharif and open that thing up....
Old Apr 24, 2007 | 05:43 AM
  #86
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Talked with him last night. Looks like they are pretty busy. Looking at next week before they start taking it apart.
Jeremy
Old Apr 24, 2007 | 07:51 AM
  #87
6894kevin's Avatar
6894kevin
So what exactly are they going to do when they have it broken down?
Cheers
Kevin
Old Apr 24, 2007 | 08:09 AM
  #88
brooke's Avatar
brooke
wow, some people on here really amaze me...
Old Apr 24, 2007 | 08:25 AM
  #89
bboypuertoroc's Avatar
bboypuertoroc
Cheers
Kevin
Play with stuff.
Old Apr 24, 2007 | 09:37 AM
  #90
marques1's Avatar
marques1
This is really interesting can't wait to here more.
Old Apr 24, 2007 | 10:49 AM
  #91
warmmilk's Avatar
warmmilk
i really hate to be that annoying guy, but does anybody have pics of the stock collector/inside of headers?
Old Apr 24, 2007 | 02:10 PM
  #92
NETSHARK's Avatar
NETSHARK
Nice finding Sharif, thanks Jeremy for letting Forged Team taking it apart
Sharif i have a small question please, i know i`m a dumb when it comes to engine internals, but do you think that we VQ35DE owners can put the Crank of the VQ37HR which have 86 storke in our motors with 96 Bore so we can get 3.8 Stroker Engine in a cheaper way ? Thanks in advance
P.S: i thought this is the VQ37HR just noticed the title after the end
Old Apr 24, 2007 | 03:30 PM
  #93
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We are going to break down the engine, and caress the internals for starters...hehe. But honestly, we just want to take a peak inside, and see what's in there.
We'll keep you posted as we start the breakdown. Not sure how far we will get into it....prior to Jeremy's car arriving back in our shop.
Old Apr 24, 2007 | 03:31 PM
  #94
Sharif@Forged
Forged Performance
The swap will not work. The block is taller, so even if the crank and pistons fit, the pistons will most likely hit the valves on the VQ35 heads.
Old Apr 24, 2007 | 05:16 PM
  #95
Miche350Z's Avatar
Miche350Z
So will there be a VQ40HR for the Xterra and Frontier? Also is it safe to assume that since VQ37HR crank is bigger the VQ40 crank and other engine parts may not work either?
Old Apr 24, 2007 | 06:13 PM
  #96
Sharif@Forged
Forged Performance
More speculation, but my guess is probably not. We recently took apart a pathfinder VQ35, just about everything was crappier...the heads, timing assembly, camshafts, cam gears, tensioners...everything. The only usable piece was the block/crank, which is virtually identical to the 350Z VQ35.
Truck/SUV engines are tuned very differently. They need lots of low end trq, which results in less top end power....so I doubt they would use the HR in the pathfinder..but I could be wrong!
Old Apr 24, 2007 | 09:01 PM
  #97
tourinz's Avatar
tourinz
nice work... let me know if more test dumies are needed....
Old Apr 25, 2007 | 09:36 AM
  #98
blackstealthz's Avatar
blackstealthz
Originally Posted by gNaRKiLL
No Disassemble, Number five is Alive!!
LOL johhny 5
Old Apr 26, 2007 | 02:14 PM
  #99
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by Audible Mayhem
back on topic!!!
sharif, you pull off the plenum and lower runners yet??
how do they look?
Bump for answers
Old Apr 27, 2007 | 07:21 AM
  #100
Sharif@Forged
Forged Performance
OK, we pulled the upper plenum, and this nice is NICE. We figured the waffle pattern on the top is to strengthen the composite for...you guessed it...BOOST! The more we crack into this thing, the more we are convinced this engine has been tailered physically for boost.
The upper/middle collector is now one piece, and appears to be glued together with some kind of apoxy.
Velocity stacks are contured and nicely integrated into the upper plenum. Also notice the larger collectors on the sides, for increased volume.
The lower collector is very straight, and uses large square runners...another interesting find. The TB's are 60mm.
Here are some pics:
