Highest mileage HRs
Old Aug 1, 2015 | 03:08 PM
  #521
HRMoneyPit's Avatar
HRMoneyPit
Figured. So might as do it all while I'm in there. That whole adjusting every oil change would be annoying. What happens when there is no more room to adjust? But I can't bare dropping the trans again for a CSC issue. I'm a deer in headlights for the past couple weeks on this forum. So much good information
Old Aug 1, 2015 | 03:19 PM
  #522
travlee's Avatar
travlee
Master
you don't have to adjust every oil change unless you go with the z1 slave elimination kit. with the zspeed you never have to adjust it
Old Aug 1, 2015 | 03:22 PM
  #523
HRMoneyPit's Avatar
HRMoneyPit
The Z1 was the one I wanted cause it's external, if it does bad yoy can change it on a lift. I'm just worried about one day not having any more space to adjust it into spec.
the Z speed worries me cause of having to drop the trans WHEN it goes bad.
As we can see I trust neither in the long run.
what made you get rid of the Z? You seem knowledgeable
Old Aug 1, 2015 | 03:32 PM
  #524
travlee's Avatar
travlee
Master
it won't go bad, been in my old z 3 years now, and the new owner isn't concerned about it. the first time mine went out was 6 weeks after i bought the car in 2011, i bitched at the dealership to help me out with it some since i wrote them a check for the car. they replaced it with oem stuff, a year later it went out again. that time i put the zspeed in and never looked back. i helped a buddy install the z1 setup and to be honest i wasn't impressed with it, didn't like the fact you have to adjust all the time.
i got rid of the z because i got bored with it, i had full bolt ons and it wasn't going to get any faster without really tearing into the motor or going FI, so i sold it to a friend that has seen it throughout the years and watched it evolve, he knew the parts on it and knew how i was with the car. for the price i gave him it was a no brainer for him. took the cash he gave me and put it down on a C6 Z06 corvette, factory it has about 200 wheel hp more than my Z did with a ton of money in it. i love the Z to this day, and when i see one i still look at them.
Old Aug 1, 2015 | 06:38 PM
  #525
HRMoneyPit's Avatar
HRMoneyPit
Did the Zspeed kit help the clutch grabbing? Or is that just a HR thing? I can't stand how high it grabs
Old Aug 2, 2015 | 06:50 AM
  #526
travlee's Avatar
travlee
Master
that is every Z, if you don't like it get the RJM clutch pedal assembly
Old Aug 2, 2015 | 07:18 AM
  #527
HRMoneyPit's Avatar
HRMoneyPit
They don't even give you any play in the pedal. I adjusted it then I couldn'tget the cruise control switched so reach the pedal so I went back to how it came. Whatever, as long as I know it's not just mine
Old Aug 3, 2015 | 04:59 PM
  #528
HK350 Z's Avatar
HK350 Z
Travlee has given you everything you need to make a great decision, if your a DIY'er and dont mind adjusting the clutch regularly, then external is for you.If you want to bolt up and go, then go with the upgrade CSC. Fluid is going to be Redline, if you use the correct one you will not have issues with Redline. All this information is posted thoroughly.Its good your looking now, that way you will know which way to go make a good decision.
Good luck.
Old Aug 3, 2015 | 05:10 PM
  #529
travlee's Avatar
travlee
Master
i halfway know what i am talking about, being one of the few (actually only) of my friends that had the hr, i did a lot of research. obviously it is your car, and your decisions .... i led you to water, only you can choose to drink
Old Aug 3, 2015 | 05:31 PM
  #530
HRMoneyPit's Avatar
HRMoneyPit
I do all my own work but I'm debating paying a shop to do the clutch just cause a whole weekend vs dropping off the car and picking it up later seems easier. But i see people paying $800 for a clutch job. All that on top of a $1,600 clutch job!? Yeah I might have to waste a weekend lol a weekend of headaches
Thanks for the info guys! So eventually what your saying is during normal driving the clutch won't come back up? Cause right now I only have that problem while trying to launch or standing burnouts (have not tried since)
Old Aug 3, 2015 | 05:35 PM
  #531
travlee's Avatar
travlee
Master
honestly, the trans is not that hard to drop.... between me and a buddy we can do it (with beer and food breaks) in about 6 hours. the hardest part is stabbing it back into the motor. if it is sticking down intermittently it is only going to get worse
Old Aug 3, 2015 | 05:55 PM
  #532
HRMoneyPit's Avatar
HRMoneyPit
Only under a hard launch. I drive the car normally all weekend and 0 problems.
And how many times have you dropped it? I hate the top bolts on a RWD car. It's on the same left as Timing chain and water pump. Two things i debate paying to do or not. Internal water pumps blow
Old Aug 3, 2015 | 06:00 PM
  #533
travlee's Avatar
travlee
Master
dropped mine once, others about 5-6 times. the thing with the internal slave, it is not if it goes out, it is when
Old Aug 3, 2015 | 06:06 PM
  #534
HRMoneyPit's Avatar
HRMoneyPit
Oh yeah and mine is definitely going out then. But with it being a weekend car only I can park it once it goes out and sound like I'm doing a Southbend stage two and the HD CSC. With Redline fluid in the diff and trans. Would love a clutch type diff but the list of to do has enough mods already
Old Aug 3, 2015 | 06:11 PM
  #535
travlee's Avatar
travlee
Master
patience, but do you really want a clutch diff... you are supposed to change the fluid like you do you engine oil.. i had the quaife and loved it
Old Aug 3, 2015 | 08:00 PM
  #536
HRMoneyPit's Avatar
HRMoneyPit
That's a H (can't spell it right now for some reason) type diff no? How does that effect a car with VDC? Do you just turn it off so they diff can do what it's supposed to do? I can imagine a clutch type not liking VDC
Old Aug 4, 2015 | 03:14 AM
  #537
travlee's Avatar
travlee
Master
yeah you have to turn off the vdc for it to act the way it should
Old Aug 4, 2015 | 06:39 AM
  #538
HRMoneyPit's Avatar
HRMoneyPit
So back to the original point of this thread.
84k miles checking in here
Old Aug 4, 2015 | 06:43 AM
  #539
travlee's Avatar
travlee
Master
about what mine had it when i sold it
Old Aug 4, 2015 | 09:24 AM
  #540
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Originally Posted by stogey420time
I'm @ 90k still on stock clutch as well.
Looking back since the time of the post above 8/14/2014, it's been a year and I'm at 98K.
