Highest mileage HRs
Old Jan 22, 2009 | 11:38 AM
  #121
bigbgballz's Avatar
bigbgballz
Default PAS
Originally Posted by Peak350
I have tried to get this fixed many times, but can't duplicate it, it seems to only happen for me with female passengers, so I think it might be "wider surface area with less weight" not causing enough pressure on the spot where the sensor is.
Same here. It only happens when my girl sits in the car.I think its not enough pressure too. I may have to get her to come with me to the dealership so she can duplicate the issue cause my warranty gonna expire at 36000 miles and i dont wanna get stuck with an issue if my car does not fall under the recall.
Old Jan 22, 2009 | 11:54 AM
  #122
Peak350's Avatar
Peak350
I'm tempted to take the seat apart and just tie the sensor into the seat belt. Seat belt on = airbag on.
Old Jan 22, 2009 | 01:14 PM
  #123
kelsey_kaye's Avatar
kelsey_kaye
I have to take my car to the dealership to get this fixed.
Old Jan 22, 2009 | 03:52 PM
  #124
M_FRESH's Avatar
M_FRESH
Got mine oct 2007 have 12k miles, had a recall on the airbag light not turning off but other than that no problems..
Old Jan 24, 2009 | 04:46 PM
  #125
Master of Baiting's Avatar
Master of Baiting
Demolition Man
08 31k
Downshifting into 5th grinds some times.....
Other then that no probs and I drive it hard
Old Jan 24, 2009 | 05:20 PM
  #126
Peak350's Avatar
Peak350
Anyone else have valve tick after its idled for a while (when hot).
I'm starting to get a small tick and wondering if I should be concerned (obviously could just be a collapsed lifter)
Old Jan 24, 2009 | 05:25 PM
  #127
ninor's Avatar
ninor
Originally Posted by 07rdsterGT
Same thing here. When my girl, and only my girl (who is 105 and petite) do I see the SRS light on even though shes sitting in the damn seat.
when my friend, who is also tiny, rides with me the light comes on... wtf?
Also, I got my car in April 08 as well and I got 9,100 miles on it so far
By the way, no problems here except random rattles in right side of the hatch and the door.
Old Feb 3, 2009 | 12:03 PM
  #128
Blck350z's Avatar
Blck350z
Wrecked my 06 this past thanksgiving and will be picking up my '08 this Friday. No problems yet......
Old Feb 3, 2009 | 08:46 PM
  #129
ROCA Z's Avatar
ROCA Z
i got 22k on mine... and is flawless!!! i take it to the track and run it very hard!!
Old Feb 4, 2009 | 11:30 AM
  #130
terrycs's Avatar
terrycs
Just shy of 22K on my G sedan.
Old Feb 4, 2009 | 03:50 PM
  #131
Darg2er's Avatar
Darg2er
07HR - 21K
8K - Slave cylinder recall.
12K - CEL - bad right cat (replaced)
14K - CEL - bad intake MAFS (replaced)
19K - CEL - both cats deteriorated (replaced) - got to see them, it was really bad, big bits falling out of them and everything.
Sound-system crashes when bluetooth connects to my Iphone.
all sorts of little squeks on dash.
The car drives strong.
Old Feb 10, 2009 | 11:23 PM
  #132
2007 Z's Avatar
2007 Z
40K. Had tranny and clutch replaced under warranty once. Still have grinding problems when driving normally, usually 5th gear. But no problems at all when getting on it.
Old Feb 24, 2009 | 07:03 AM
  #133
sibble's Avatar
sibble
65k heh.....
Recall done, nothing but wear/tear items needed to be replaced. I'm on my 3rd set of tires and 2nd set of brakes (rotors/pads) including factory sets.
The windows need to be reset because of my own fault, and I'm due for a serp. belt.
Old Feb 25, 2009 | 08:17 AM
  #134
JZK's Avatar
JZK
08HR 6MT 17.5k miles
5th gear grinds occasionally.
6th gear grinds when shifted from neutral. (Example: driving at 55mph, throws in neutral & lets clutch out, puts clutch back in and throw 6th gear = grind)
Driver side window motor going bad
Everything else runs good
Old Feb 26, 2009 | 08:37 PM
  #135
Villain's Avatar
Villain
holy crap some of you have lots of miles!
Old Feb 27, 2009 | 07:00 AM
  #136
Hexxus's Avatar
Hexxus
2007 Base
15,700 miles
Slave cylinder recalled, but I haven't had it replaced.
Old Feb 27, 2009 | 12:28 PM
  #137
Da Monsta's Avatar
Da Monsta
Originally Posted by 350Zimo
I have a starter problem but it still hasn't been fixed because the dealership has to replicate the problem. It does it once a blue moon. Well anyway I have a year and a half left of My warranty
Same here, turn the key and nothing happens. Do it again and then it starts.... weird.
Old Feb 27, 2009 | 03:18 PM
  #138
411Z's Avatar
411Z
08- w/ 8700 mi
1. airbag light
2. dash rattle
3. left rear wheel bearing bad
only problems so far. took it to dealership and had problems addressed. apparently we have pretty good nissan dealerships here in vegas because they warrantied the wheel bearing and rattle no questions asked. after i got it back the service guy told me that the audio place where i had my subs installed broke a clip that holds the center dash piece, but they still fixed it under warranty. it still kinda rattles but whatever.
and i asked about the airbag sensor. the guy said the sensor is too sensitive and the light will go on and off with slight movement. he said not to worry and the airbag would work properly as long as someone is in the seat.
other than that, no problems. and i gotta say that ive been extremely pleased with the customer service from nissan. im a former chevy/dodge guy, and i never saw the same service from those guys... but judging from other posts ive read i guess im one of the lucky ones lol.
Old Feb 28, 2009 | 06:54 AM
  #139
BigMo350z's Avatar
BigMo350z
08 HR 4600 miles no problems thnk god!
mods: injen dual cold air intakes
Old Mar 1, 2009 | 03:50 PM
  #140
powermark's Avatar
powermark
Originally Posted by sibble
65k heh.....
finally someone higher than me! I was feeling bad. I just cracked 50k on my 07
