oil catch tank
Old Mar 11, 2010 | 06:23 AM
red_magic2000's Avatar
red_magic2000
OP, I put in a homemade catch can on my 08 Z, NA. Works great! Theres a write up here somewhere, just search it. Try Homemade Oil Catch Can or something like that. Also it catches quiet a bit of sludge, considering I'm NA. I used a big air compressor water seperator so I empty mine out like every 2,000 miles. Even then its not even half full. Hope this helps. At work If I remember I'll try to hook you up with pics of my setup when I get home.
Old Mar 11, 2010 | 06:36 AM
flecko28's Avatar
flecko28
Half full after 2000 miles? Wow! Are you split 50/50 highway/city driving?
Old Mar 11, 2010 | 06:46 AM
red_magic2000
Yup you guessed it. I drive like maybe 15 mins on the HWY and like 30 mins of city driving before I get to work. Sux, I was even considering getting rid of my Z cause I can't even have fun with it (man. trans). I can't drive fast, even on the HWY cause I always run into the a-hole on the left side lane who won't let me pass But the oil catch can is very effective nonetheless.
Old Mar 12, 2010 | 07:57 AM
whoisthis's Avatar
whoisthis
sounds like they r pretty good. but would this b better choice than oil cooler? i dun wanna get both because if i do both then i would hav tp put more.engine oil lol
Old Mar 12, 2010 | 08:39 AM
flecko28's Avatar
flecko28
If you are going to be drifting like you mentioned earlier, and you are choosing between a catch can and an oil cooler, I would choose the oil cooler. Thats my $.02! It would be worth having to add the little extra oil each time you do a change.
TJ
Old Mar 12, 2010 | 08:42 AM
flecko28's Avatar
flecko28
Damn that is crazy. I am split roughly the same - little more highway time. With my driving (and I do A LOT of driving in this car) I may look into this after all. Just to keep things clean. I have never heard of people using these on the HR's. Glad to see that they're functional on our motors, although, at the same time, unhappy to know they're catching oil.
TJ
Old Mar 12, 2010 | 10:00 AM
red_magic2000
^Its catching oil, but its not like its losing enough to worry bout it. I never check my oil level, except for when I change it
Old Mar 12, 2010 | 10:36 AM
flecko28's Avatar
flecko28
Gotchya -
That's what I figured. It's not enough to cause concern, but you know, who likes oil in places other than where it should be? I have a burned in habit of checking my oil once a week, and between changes rarely see a difference in amount, hence my curiosity of using a catch can on an HR motor. Do you have pics of your install?
TJ
Old Mar 12, 2010 | 10:46 AM
ATL_Red_G35's Avatar
ATL_Red_G35
Thanks for the feedback. I guess the HR motors corrected that problem seen on the DE.
Mine was full (same size as yours) after a short 300-500 miles trip on my 03 G35.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
