18x9.5R and 285/40's ?
Old Nov 6, 2005 | 05:38 PM
002-M-P's Avatar
002-M-P
Default 18x9.5R and 285/40's ?
I'm looking at doing a set of 18" TE37's (18x8.5F/18x9.5R) and had a quick question about tires. I really want to get some BFG KDW-2's but they don't make them in 275/40-18, but do in 285/40-18. Will the 285/40's fit in the rear (its only .2" bigger radius than stock)? I've never heard of anyone running this size, but figured I would ask. Front tires are no big deal though, they make them in both 245/40 and 255/40.
Old Nov 6, 2005 | 05:45 PM
westpak's Avatar
westpak
SFZCC
If you have TCS/VDC and you use the 245/40 you will need to use the 275/40 to keep them happy.
I have 285/35 and they clear the car fine even lowered. Not exactly what you were looking for but I figured I would throw it out there.
Old Nov 6, 2005 | 05:51 PM
002-M-P's Avatar
002-M-P
So to keep VDC happy with your 285/35's what front tire would be needed.
Old Nov 6, 2005 | 06:14 PM
westpak's Avatar
westpak
SFZCC
Im currently running 245/35/19's front and 285/35/19's back on a 8.5/9.5 inch rims. I have no issues with VDC. I wouldn't run 285/40's tho since the 35's are near stock diameter.
Not sure never looked into it, but probably something like a 235/40 not sure if they make that, but if I had to buy new tires I was going to go with 275/40 or 295/35 I know 295 is suppossed to use a 10 in rim but I was told I could squeeze the 295 on a 9.5 rim.
Old Nov 6, 2005 | 07:19 PM
002-M-P's Avatar
002-M-P
well since you are running 19's and I will be running 18's I'm not sure everything holds the same. Any other input would be most helpful.
Old Nov 7, 2005 | 08:24 AM
westpak's Avatar
westpak
SFZCC
I am sorry that should have been 18 not 19, don't know why I put 19.
Old Nov 7, 2005 | 08:27 AM
barthelb's Avatar
barthelb
Master
Sorry Westpak I didn't mean to edit your post, had some latency issues on wireless from home last night. This is what i meant to post.
Old Nov 7, 2005 | 08:30 AM
barthelb's Avatar
barthelb
Master
That's the 2nd time we almost posted at the same time. = we need to get a life. J/k....hahahhah
Old Nov 7, 2005 | 08:40 AM
westpak's Avatar
westpak
SFZCC
LOL that is wild, I didn't know that could happen, I was trying to figure out why I wrote that, thanks for clearing that up.
Old Nov 7, 2005 | 09:14 AM
002-M-P's Avatar
002-M-P
Man you guys are confusing me, haha. So what exactly was the dilemma with the posts?
Old Nov 7, 2005 | 09:27 AM
westpak's Avatar
westpak
SFZCC
Apparently since barthelb is a mod he can edit any posts, so when he posted his answer it happened at the same time I posted mine so instead of posting his it edited mine, pretty crazy.
Old Nov 7, 2005 | 09:50 AM
engiNERD350Z's Avatar
engiNERD350Z
Great question. This is exactly what I was also wondering, running LMGT4's 8.5"/9.5" with 285 in the rear since that's all KDW-2 offers. I don't know about VDC, but I don't think TCS would be a problem.
Old Nov 7, 2005 | 10:03 AM
350zQ45a's Avatar
350zQ45a
I have 18 x 9 285/45s in the rear...
Check it out. Although I'm going to put on a pair of track wheels and tires from an 04..
The offset is off a tad, but you get the idea
Old Nov 7, 2005 | 10:20 AM
002-M-P's Avatar
002-M-P
Wow 285/45 is big. That is a 1.4" larger diameter. I don't think I will ever try that. Also isn't 285 a little wide for a 9" wide rim?
After looking more into it, I think I might just try and avoid the hassle and go with a set of Goodyear Eagle F1 GS-D3's instead. 275/40R and 245/40F. They are a little more expensive than the KDW-2, but they should have equal traction, a stiffer sidewall, and are a little bit lighter.
Old Nov 7, 2005 | 10:53 AM
002-M-P's Avatar
002-M-P
Oh and while I'm at it I should probably just go ahead and verify that the offset I want is correct....
Wheels
18x9.5 Rear w/ +22 offset
18x8.5 Front w/ +22 offset
Tires
275/40-18 Rear
245/40-18 Front
This should not create any problem with rubbing on my Z with Hotchkis springs (.8R/.6F drop)? Also, is this the best offset setup for the most curved look in the 18's?
Old Nov 7, 2005 | 10:58 AM
mojo powered's Avatar
mojo powered
people make it a lot bigger of a deal than it really is about VDC
285s are the largest you can fit on a 9.5 and would be perfectly fine. I usually try to fit the largest tire you can fit on the rim while trying to stay as close to stock diameter as possible. 275/40/18s are 1% smaller and 285/40/18s are 1% larger so in my book, both are perfectly acceptable. Any larger (295s) and I'd go to a 35% sidewall.
Old Nov 7, 2005 | 12:34 PM
WA2GOOD's Avatar
WA2GOOD
On my 1 car (G35 coupe) I run a front 265/35/18 on a 18x8.5" wheel and the rear, a 295/35/18 on an 18x9.5" wheel. It's a good balance. IMO, the best for overall grip and performance though, is a 285/30/18 front on an 18x8.5" wheel, and a 315/30/18 on a 18x9.5" wheel on the rear. And on 19's we run 275/30/19 on a 19x9.5" front and a 305/30/19 rear on a 19x10.5" wheel. All of these clear on lowered Z's and G's and perform great!
Old Nov 7, 2005 | 01:55 PM
350zQ45a's Avatar
350zQ45a
Heh yea it really isn't ideal. The tires were brand new mounted on the wheels and I got them for pennies so thats why I threw them on the Z, they wernt even intended for that in the begining. They have done me pretty well, but I am looking forward to going back to the lighter weight track rims
KTR5
Apr 14, 2015 11:55 AM
breftayka
Wheels Tires
Dec 30, 2014 01:56 PM
tm9293
Wheels Tires
Jan 22, 2014 01:20 PM
original786
Jun 25, 2007 07:10 AM
