new tire sand rims, psi sensor question
Old Feb 22, 2006 | 07:26 PM
StillAlive2029's Avatar
StillAlive2029
Default new tire sand rims, psi sensor question
i put on a new set of rims and tires and the psi sensor is just showing the lines everytime i start the car..is there a way to disable the light and the fact that you have to hit the top button to return to mph on the digital readout thing??
Old Feb 22, 2006 | 07:39 PM
Everybodywildou's Avatar
Everybodywildou
I think if you drive for a few miles
Old Feb 22, 2006 | 08:09 PM
StillAlive2029
nope it has been over a thousand miles since i put them on...its not going away
Old Feb 22, 2006 | 08:31 PM
Z_Driver's Avatar
Z_Driver
Master
Were the sensors taken out of the old wheels and installed on the new wheels? Not everyone knows that the transmitters needs to switched from the old set to the new set.
Old Feb 22, 2006 | 09:14 PM
jedi-z's Avatar
jedi-z
Do you have to have all 4 sensors in at one time to make the car read the pressure?.Dumb question I know.. but I'm waiting on a sensor to come in but the car will not read any of the three I have on right now?/
Old Feb 22, 2006 | 11:48 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
this is weird. My car didn't show up anything.
Old Feb 23, 2006 | 01:58 AM
BeyJer's Avatar
BeyJer
i had the same issue. i did a search and apparantly you can use the sensors from your stock wheels/tires adn then take it to dealer to reset.
goodluck swapping, it's part of the valve stem and they're $200 USD to replace each.
Old Feb 23, 2006 | 11:02 AM
WNM's Avatar
WNM
ok, this is how you do it: put the stock wheels on(make sure there is good pressure) drive and let the light go out. Turn the car all the way off, and put on your new wheels on. done no light except after like 60-80 miles, but it will be off next time you start your car. if the light is on for any reason while or before you change your wheels the light will never turn off
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
rizzla
Sep 29, 2015 03:58 PM
