Where to get Replacement Studs for H&R 25mm Spacers?
Old Jun 29, 2006 | 04:47 PM
sq40's Avatar
sq40
Default Where to get Replacement Studs for H&R 25mm Spacers?
I Need to get some replacement studs for my H&R 25mm Wheel Spacers.. Anyone know of a good place at a good price? Also, I need 20 moderatly priced Lug Nuts too...
Thanks!!
Old Jun 29, 2006 | 06:26 PM
A Spec Products's Avatar
A Spec Products
What's your definition of moderately priced?
Most tuner lugs like Muteki start at around $40.
Then the higher end quality stuff like Rays and Work are around $120.
Then the highest quality gangster stuff like Kics Project R40/R26 are around $200.
If you can find the knurl size of the spacer stud you might just be able to get a replacement one at a Pepboys or such for cheap.
Old Jun 29, 2006 | 07:27 PM
sq40's Avatar
sq40
$40 doesnt sound too bad. From what I understand it is pretty hard to find replacement studs without going Nismo. 20 Nismo Studs will run me around $120, which I think is way too much... The H&R studs seem to be very soft though.. But, they will fit perfectly and I will only need 10.
Old Jun 30, 2006 | 05:00 AM
sq40's Avatar
sq40
Bump.. Im a man in Need.
Old Jun 30, 2006 | 10:13 AM
A Spec Products
Nismos are extended though (60mm iirc?), I assume the H&R studs are stock length (50mm?)
Old Jun 30, 2006 | 10:16 AM
sq40's Avatar
sq40
I beleive so. I contacted H&R about 10 Minutes ago, They told me I can get them through my distrubutor (which was performance Nissan) for about $2.00 each. So that wont be too bad.
About those lugs, Do you sell them?
Old Jun 30, 2006 | 11:08 AM
A Spec Products
Yeah Performance Nissan are good peoples.
Yes I sell all the lugs I listed, PM me.
Old Jul 1, 2006 | 03:10 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
I think you called and spoke to justin when I was passing through the office today?
When he asked me about it he wasnt sure if it was the studs on the actual spacer its self or in your wheel hubs...
If H&R says the studs in the spacer its self can be replaced with a factory hub bolt, then you can either use the factory Z hub bolts or the extended NISMO ones...
PM me if you need any more info...
the more detail you give me the better I can help you...
350z82
Oct 1, 2015 06:25 PM
