Running an 18 x 9.5 at all corners
Is anyone running this setup? I'm wanting to go with Rota P45's but only size in stock is the 9.5" wide wheels. So are there any disadvantages to going with an unstaggered setup? Offset on these wheels is +20 I believe.
If theres anyone running these size wheels front and rear, what tire sizes are you using? I've been recommended 275 front and 295 rear.
Thanks
Thanks
Thanks for the heads up. I just found this thread too:
https://my350z.com/forum/wheels-and-tires/231523-new-wheels-p45r-rota.html
So looks like I'll go ahead and get em. Gonna be going with the black w/red lip P45's.
I run rota p45r all around, which are 18x9.5 and have a +25 offset. I run 265/35 in the front and 275/35 in the rear. The front is pretty much perfectly flush with the body of the car, it fits perfectly. The clearance is fairly tight in the front, you might be able to squeeze 275's in there, but it depends if you want to lower your car and by how much.
Also, in my opinion you gotta go with the p45r all around, I don't like the flat face in the front then the concave face in the back. Just my opinion though.
Thanks
Thanks
