Nitrogen Filled Tires?
Old Aug 14, 2007 | 11:40 AM
raf84ny's Avatar
raf84ny
Default Nitrogen Filled Tires?
Have anyone filled thier tires with nitrogen? I know it's been used in the racing world for years, but I wonder if it's worth spending the money? I've heard that not only it stays in your tires longer and deos not fluctuate pressure, but also prevents corrosion. It is also lighter than air = better mpg?
What do you think?
Old Aug 14, 2007 | 12:18 PM
redlude97's Avatar
redlude97
If its free, then go ahead. Its main advantage is that it is "dry" without the water vapor present in air to cause the "corrosion". The pressure of the tires will flucuate slightly less because of the lack of water vapor also. To say that is doesn't flucuate pressure is totally incorrect however, all gases expand/contract with temperature. Corrosion resistance is worthless because our wheels are aluminum, not steel so they won't rust anyways. It is also not "lighter than air", at least not by an appreciable amount. Remember air is already 78% nitrogen
Edit: forgot to include that because nitrogen is a slightly larger molecule, it potentially will seep out of the tire less, so you may be able to go longer between refills, but if you have to go back to the tire shop to get it refilled, that kinda defeats the convenience factor, and the tires are supposed to be filled and checked when cold, so ideally you would have to leave the car there overnight for them to refill them to the correct pressure....LAME!
Old Aug 14, 2007 | 12:31 PM
mattshaver's Avatar
mattshaver
^^^ true. the molecular weight of air is around 29 g/mol whereas nitrogen is 28. sure it will weigh less, but not worth it.
Old Aug 14, 2007 | 12:33 PM
fast kiwi's Avatar
fast kiwi
God dame.. you goggle that or what??? makes for a good read though.. lol..
Old Aug 14, 2007 | 12:35 PM
raf84ny's Avatar
raf84ny
It costs $5 per tire, so it's not free. There are lots of positive as well as negative articles on the web summarizing the nitrogen and its use in tires. It seems that if air in the tires is already 78% nitrogen, then it looks like it's not really worth $20 dollars replacing it with the "100%" nitrogen/air.
Old Aug 14, 2007 | 12:42 PM
pln2311's Avatar
pln2311
How easy or available is it to put more nitrogen in your tires if the psi gets too low?
Old Aug 14, 2007 | 01:23 PM
redlude97's Avatar
redlude97
No, I'm a chemical engineer, and we just had a long discussion about this on g35driver.com. Some of the things that are advertised about magical abilities of nitrogen are just laughable
Old Aug 14, 2007 | 01:27 PM
Z04's Avatar
Z04
waste of money. it does nothing at all for your car.
and a search next time would do some good
https://my350z.com/forum/search.php?searchid=4014019
Old Aug 14, 2007 | 04:52 PM
raf84ny's Avatar
raf84ny
... oh I'm so sorry...
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
