replacing stock studs
Old Aug 22, 2007 | 12:25 PM
dkorr's Avatar
dkorr
Default replacing stock studs
a few questions I couldnt find w/ the Search feature:
Do you guys know if its safe to knock out oem studs with a 5lb hammer?
Does it have to be brass-coated? will it screw up the bearings?
Is it necessary to shrink the stud (by freezing it) so that it comes out easier?
Is 60mm studs too long for the rear (clearance)?
If so, is it necessary to remove the hub?
Is it better to just a shop 'pull' out all the studs w/ a machine than DIY?
thanks
Old Aug 22, 2007 | 12:37 PM
LaoSiFu's Avatar
LaoSiFu
subscribe, I am curious too.
Old Aug 23, 2007 | 12:08 PM
dkorr's Avatar
dkorr
what setup do you have on your rears?
Old Aug 23, 2007 | 12:11 PM
fast kiwi's Avatar
fast kiwi
ive been told bashing em out is a no no.. but ive read where people have done it with out problem.. i dont suppose this helps... ill stop then.. lol
Old Sep 5, 2007 | 08:14 AM
Midnyte's Avatar
Midnyte
i had to do 3 of mine on the driver side front from where a local shop incorrectly impacted/stripped them. Some wd40 and my hammer worked just fine. I didn't need to freeze it or remove the hub. Worked fine. as for length, not sure. Although the first set i bought were a tad too long. If there too long, you'll never get them behind the hub on the front because the shielding is in the way. The second set was very close to stock length, just a tad longer.
Hope that helps.
-Trash
Old Apr 2, 2008 | 01:10 PM
350zGuy04's Avatar
350zGuy04
I am also curious i need to replace 3 studs in the rear? How should i go about replacing and where do i get the new ones?
Old Apr 2, 2008 | 11:22 PM
terrasmak's Avatar
I pounded all mine out with a 5 pounder without problem. 60mm i can't answer, my 50mm studs i had to remove the parking brake hardware to install.
Old Apr 3, 2008 | 12:24 AM
Triple8Sol's Avatar
Triple8Sol
I had to replace a couple earlier this year. Used a regular hammer and pounded them out. Pulled the new oem ones back through with a closed-end wrench and a stock acorn lugnut. Don't know how you would freeze them to pull them out. You could freeze the new ones to make installing those marginally easier.
Old Apr 3, 2008 | 07:41 AM
kingrukus's Avatar
kingrukus
Can you do this without removing the rotor, is removing the rotor required?
Also, how difficult is it to install 60mm spacers? any additional work? I recently acquired 20mm H&R Traks, but without the extended studs...
Thanks
Old Apr 3, 2008 | 11:20 AM
Triple8Sol's Avatar
Triple8Sol
Thanks
Mine were in the rear. Just had to move the caliper and rotor. Nothing else, even though the DIY calls for some other things to be removed.
Oh, and 60mm spacers? Are you crazy? You mean studs, right?
Old Apr 3, 2008 | 11:30 AM
kingrukus's Avatar
kingrukus
60mm studs i meant, my bad.
EDIT: What is an acceptable stud size to hold a 20mm spacer? I was thinking 60mm, but it seems liek 40-50mm is more available?
Old Apr 3, 2008 | 11:47 AM
terrasmak's Avatar
50mm is the norm for 20mm spacers.
Old Apr 3, 2008 | 12:06 PM
kingrukus's Avatar
kingrukus
cool thanks
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
