Wheel fitment experts HELP!!
Ok, so i got a new set of wheels and test fitted them w/o tires today. The rears fit like a glove but the fronts concern me. They are 18x10 with about a +18 offset. I am concerned about the clearance of the control arm and the outer offset.. On with the pics:
1) First issue is the clerance w/ the control arm.. I can tightly fit a pinkie between the wheel and the arm. I am going with a bit of a streched tire. Should i be fine here? Or should i worry?
2) Then i am worried about the outer offset. Obviously it looks like it sticks out but is it something i should worry? I am thinking once the wheel is on and the car is on the ground the wheel will tuck in. I am not going with too much of a wide tire.
PLEASE HELP!!!
PLEASE HELP!!!
i wouldnt worry about the outer since there isnt any load in the pics you took. they will camber in alot when you finally put a tire on there and drop it.
what tire are you gonna run on the front? a 245 would probably work, but you cant really see how much room you do have.
Originally Posted by Zilvia
yea 10 up front might be too big.......
im sure it can be done, but im not sure of the modifications needed to complete it.
- 18x10 +19 offset, also added 5mm spacer so offset comes out to +14 offset
- tire size 265/35
- dropped on hotchkis, no fender modification
Z33 SPL and ppw350zunit..
Do you also have the same extremely tight clearance with the inner control arm with a 10" wide wheel? I am starting to feel a bit relaxed about the outside part with a thinner tire but what about the small clearance on the inner part? Should i worry? Will it touch on hard cornering, etc?
Originally Posted by deviljon
isn't the distance between the control arm and the wheel not going to change?
btw, what wheels did you get?
Ok.. I'm just worried about the fitment. I contacted the manuf. so i should get an answer back soon from them. Some camber correction should also help. My camber hasn't been corrected for about 2 years and it should very well be around the neg. 3 range.
08-06-2021 06:19 AM
