Help with slip light!!! please
Old Nov 6, 2007 | 07:23 PM
henry j's Avatar
henry j
Default Help with slip light!!! please
I put on used rear tires 245/45/17 that i had laying around. when i reach the speed of about 60 it keeps saying "slip" and it wont allow me to accelerate as fast or even at all. can anyone please help?
Old Nov 6, 2007 | 07:35 PM
Kingofvacuity's Avatar
Kingofvacuity
Whats the size of your front tires?
henry j's Avatar
henry j
Old Nov 6, 2007 | 07:37 PM
Kingofvacuity
Hmm, im not sure but i think it might be because either your tires are worn out or your back wheels are too small and its tricking it into thinking when you are slipping.
Thats just me though
Old Nov 6, 2007 | 07:39 PM
henry j's Avatar
henry j
i used the same tire size i had before and there is more tred on these tires then i had on the tires that i was driving on that were basically bald
Old Nov 6, 2007 | 07:55 PM
henry j's Avatar
henry j
any other suggestions anyone???
Old Nov 6, 2007 | 08:05 PM
Dmorrisjr350z's Avatar
Dmorrisjr350z
im not sure how the sensor system works back there (New z owner..) but it sounds like its some sort of sensor malfunction if they are the same size tires etc etc
Old Nov 6, 2007 | 08:15 PM
sporkdevil's Avatar
sporkdevil
My understanding of that slip light is the rear end is spinning faster than the fronts, and if it goes more than a 3 or 5 percent difference between the two, that light comes up so you know you are losing traction.
So, I would guess that extra 20MM*.45, so there is a 9MM difference in tire height. I would guess that that difference is not enough until you get into some real speed (ie: more revolutions of the tire per second multiplied by the difference) you finally hit the max limit and the computer thinks you are slipping. At least, that's what I would assume, and I think the slip light is quite common when people swap tires out.
Old Nov 6, 2007 | 08:19 PM
henry j's Avatar
henry j
this only happens when my lsd is on...?
Old Nov 6, 2007 | 08:20 PM
Kingofvacuity
Then it must be because one of the tires on the back is spinning slower or faster
Old Nov 6, 2007 | 08:22 PM
henry j's Avatar
henry j
yeh that could be it. how would i fix that?
Old Nov 6, 2007 | 08:37 PM
henry j's Avatar
henry j
Old Nov 6, 2007 | 09:25 PM
henry j's Avatar
henry j
Old Nov 6, 2007 | 09:26 PM
gruntysmasher's Avatar
gruntysmasher
Well, here's a quick fix for you, and I don't mean to sound rude or condescending.
1: Until you can perform step two, this should suffice, though you should be more careful while you drive: Press the TCS button on the dash. It'll turn off your traction control system, eliminating the light and the "slip" problem for the short term.
2: Go to TireRack.com, order new tires in the correct size, and have them balanced. I would recommend you do this immediately. Remember: you might save a couple hundred bucks in the short term by putting your old used tires back on, but if one bursts and you total your car, you just cost yourself twenty thousand dollars or so.
Of course, you might know that, in which case I would simply be blowing hot air. But either way, I'll have at least done my duty.
As for the cause, as was stated earlier, it could be a difference in wheel/tire diameter, width, rubber compound (old tires tend to get kind of hard, so they don't stick anymore), tread, or perhaps a sensor fault.
If you replace the tires and the problem persists, my recommendation would be to visit a dealership and be very specific about your problem. Dealers aren't exactly the most inviting place to have your car repaired, but in this case, it may be the safest unless you can find someone experienced in dealing with Nissans, and specifically the 350Z.
Hope that helps.
Old Nov 6, 2007 | 09:36 PM
henry j's Avatar
henry j
Hope that helps.
thanks man that actually helps. when i went to put the tires on the guy actually asked me if they had been laying around because they seemed dry or hard as u just mentioned
Old Nov 7, 2007 | 07:50 AM
Thumbs up
Old Nov 7, 2007 | 01:06 PM
gruntysmasher
No problem, let us know how it works out!
Old Nov 7, 2007 | 01:19 PM
bbs350z's Avatar
bbs350z
aww mine dosnt turn off. wat teh hellz
Old Nov 7, 2007 | 03:26 PM
Spike100's Avatar
Spike100
I think this has been answered, but it’s probably your fronts causing the problem. Your rears are within specification as to overall diameter, but your fronts are not tall enough.
Stock Size
F-225/50WR17 Overall Diameter: 25.85 in
R-235/50WR17 Overall Diameter: 26.25 in
Your Size
F- 225/45-17” Overall Diameter: 24.97 in
R- 245/45-17” Overall Diameter: 25.68 in
If you replace the tires with new ones, and want to go 245mm (hardly any difference from 235 mm) width, consider mounting 245/50-17” on the rears (Overall Diameter: 26.64 in). Since the difference is miniscule between 235 and 245, I would get the stock size (that insures proper TCS function).
--Spike
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
