Unofficial Enkei Wheels Thread
Old Jan 16, 2014 | 01:48 PM
  #1981
pyshin's Avatar
pyshin
^^^ Not a problem. I have Enkei RPF1's myself:
18x10.5 +15 square with 275/35 f and 275/40 r (stock height atm)
When these tires run their course I will run 285/35 square like terrasmak does on his track Z
Old Jan 16, 2014 | 01:51 PM
  #1982
Cux350z's Avatar
Cux350z
hatersgonnahate
Originally Posted by scotts300
RPF1s in SBC with 9.5 / 10.5 +15 offset, 265/35 and 285/35 tires, lowered on BC coilovers at the time. Now lowered on KW Clubsports, and about 1/2" lower.
(also for sale by PM)
damn that looks good.
If i didnt have my volks this would be the EXACT setup I would run.
Enkei makes some nice clean, well priced wheels.
Old Jan 16, 2014 | 03:28 PM
  #1983
scotts300's Avatar
scotts300
Thanks!
pssst, they are for sale! : )
Old Jan 26, 2014 | 05:10 PM
  #1984
NA&CH's Avatar
NA&CH
Thinking of selling the Advans and putting the enkeis back on. Prob coat them a mag blue before.
Chris
Old Jan 26, 2014 | 05:14 PM
  #1985
Bmurray350z's Avatar
Bmurray350z
Old Jan 28, 2014 | 01:58 PM
  #1986
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Pf01 evo
http://enkei.com/pf01evo.shtml#
Attached Thumbnails Unofficial Enkei Wheels Thread-1545952_742016349141818_1237591255_n.jpg   Unofficial Enkei Wheels Thread-154.jpg
Old Jan 30, 2014 | 11:57 AM
  #1987
Underscore_Hero's Avatar
Underscore_Hero
Originally Posted by CJ Lackner Jr.
Hi everyone, I've been lurking these forums for a long time, finally hit the join button. After reading tons and tons of posts over time on this site I bought myself a 2007 Nissan 350z Touring A/T. I did that in December of 2012 and after a year of enjoying the car and researching my behind off, I'm ready to get started with the things I want to do.
First up are Wheels / Tires, Suspension & Brakes. I've decided on the Eibach / Bilstein 1.2" Lowering Suspension and the Akebono 14" F / 13.8" R Brakes. I've been trying to settle in on wheels for a long time, and have seen some great posts on offsets. The car is currently just an enjoyable daily driver, but I want to start enjoying it on the tracks as well. I will build the car around the street with trackability as a side bonus, not a devoted goal. With all that set, I've decided on the Enkei RP03 18" Wheels and am going to stick with the Staggered setup. I'm finding +18mm and +22mm offsets for these wheels and need a bit of advice as to how this would sit on the car. I will get the rear fenders rolled just to be safe.
18x9" F +18mm Offset
18x10" R +22mm Offset
I'll seat 255x40r18 tires on the front and 275x40r18 on the rear, which I believe is the correct size to keep the speedometer and factory ratios in check.
I've seen a large amount of people suggest 18x8.5 and 18.10.5 with +15mm offsets but I couldn't find those sizes for wheels I liked the appearance of.
My question is: Are the offsets the correct ones to use, and how will they look on the car? I've had a hard time finding those particular sizes and offsets on the 350z in pictures to get a good idea.
Thank you in advance for any help and advice with this guys (and gals).
I'm also thinking about the RP03's.
2003 350Z Touring
Going for conservative as it's a DD.
Stock suspension, but max 1/2" if I decide to drop it. I prefer not to roll fenders.
FRONT: 18x8.5 +30, 245/40/18 Hankook V12 Evo's
REAR: 18x9 +18, 255/40/18
Also would like some feedback on my desired setup, will it rub? etc.
Old Jan 30, 2014 | 12:51 PM
  #1988
pyshin's Avatar
pyshin
^^^ those are incredibly weak sizes/offsets for a Z.
18x9.5 +15 255/40 front
10.5 +15 275/40 rear
Bmurray along with many other members run this setup. It is not crazy aggressive and you won't need a large amount of camber to run them, especially at stock/-.5" ride height.
Old Jan 30, 2014 | 12:59 PM
  #1989
Underscore_Hero
Thanks for the reply.
I might have to choose a different wheel if I went with that size, (not sure, haven't contacted Enkei on those specs).
On their size sheet, the front 18x9.5 only comes in a +38, and the rear has a max width of 10 with a +20 or +22. I'll have to check my wheel calc to see the differences.
I'm not familiar with running spacers, so I'll read up on those.
Old Jan 30, 2014 | 02:30 PM
  #1990
Itzcashew's Avatar
Itzcashew
Originally Posted by AdvanZ33
Oh sweet baby jesus.
Old Jan 30, 2014 | 06:07 PM
  #1991
terrasmak's Avatar
The 18x10+15 would work well with a 18X9 +18 front
Old Jan 30, 2014 | 07:58 PM
  #1992
Underscore_Hero
Thank you kind sir!
Old Feb 3, 2014 | 06:43 PM
  #1993
mr. sparco's Avatar
mr. sparco
Time to sell my PF01s for the evos.
Old Feb 4, 2014 | 05:26 AM
  #1994
NA&CH's Avatar
NA&CH
Selling my rpf1 for rs05rr...
Chris
Old Feb 4, 2014 | 07:45 AM
  #1995
OAKOSAutomotive's Avatar
OAKOSAutomotive
Vendor - Former Vendor
When your ready to order the new PF01 EVO let me know I have all the info on getting those wheels.
Old Feb 9, 2014 | 09:49 AM
  #1996
Adrianisbetter's Avatar
Adrianisbetter
May I ask what's your wheel and tire specs are?? Are you using spacers? Did you need to roll your fenders?? Your set up looks great man!
Old Feb 9, 2014 | 11:30 AM
  #1997
350ZZJoe's Avatar
350ZZJoe
Chris
Oh god. I looked up the RS05RR for the first time after seeing your comment and wow...I could make the switch from RPF1 to that as well!
Old Feb 11, 2014 | 12:51 AM
  #1998
08redHR's Avatar
08redHR
Default Studs/Lugs For Enkei RPF1s
Ok,
Sorry if this is a noob question but I dont want to get my wheel and find out I will have to wait another week to get them on.
I got a set of Enkei RPF1 18x9.5 front and 18.10.5 rear. Will I need new studs for them to be properly mounted? Also, will I need non OEM lugs. I am guessing the Enkeis are conical or flat and not ball shaped?
Thank you.
Old Feb 11, 2014 | 02:31 AM
  #1999
2004Black350z's Avatar
2004Black350z
Exhaust Whore
new lugs is all that's needed
Old Feb 11, 2014 | 03:23 AM
  #2000
AdvanZ33's Avatar
AdvanZ33
OEM lug nuts are ball shaped? That's news to me. OP, you will not need different studs but you will need conical lug nuts (if OEM aren't already). I suggest tuner lugs with a key because standard lug wrenches will rub the wheels and damaged the finish.
