Unofficial Enkei Wheels Thread
Old Feb 11, 2014 | 03:51 AM
  #2001
terrasmak's Avatar
You will want a lug with a max of 19mm socket size ( normal aftermarket size) but a smaller sized one is better. My wheels get a little beat when I impact them on and off with a standard wall 19 socket, I would have to be very carefull not to touch the wheel.
Old Feb 11, 2014 | 03:53 AM
  #2002
The REAL PigPen's Avatar
The REAL PigPen
^this
Get a set of lugs that are "spline" with a spline socket. The RPF1s are nice but the hub plate is VERY deep. I am getting the same set up you have next week and I saw the same thing. Sears and Summit Racing have a few of the "scratch free" lug sockets for less than $60 for a set. Kind of sucks that they are not sold individually.
Old Feb 11, 2014 | 04:30 AM
  #2003
terrasmak's Avatar
Originally Posted by The REAL PigPen
^this
The scratch free ones will be to fat for the wheel
Old Feb 11, 2014 | 06:45 AM
  #2004
pyshin's Avatar
pyshin
Here's a solid, affordable option... clean, close-ended, spline-drive lugs that are ~$60 shipped:
http://www.amazon.com/Muteki-Close-Black-Super-Weight/dp/B0068WUN9C?tag=5336108632-20 http://www.amazon.com/Muteki-Close-Black-Super-Weight/dp/B0068WUN9C?tag=5336108632-20
Old Feb 11, 2014 | 06:49 AM
  #2005
The REAL PigPen
The spline socket that comes with the black lugs has both a 19mm and 17mm socket head. I wrapped some Teflon tape around the 17mm socket and it fit fine in the PF01 socket well. Now when I say "fine" it was snug but not in contact with the wheel. I would say almost 1mm of clearance all around.
Although the protected sockets are expensive I can see where they may not fit all wheel applications. A safe bet is to wrap the socket in Teflon tape if you are in doubt.
***my bad***
I'm not sure why, but I thought I read the OP had PF01s... I have never mounted RPF1s so terrasmak is right! The PF01s I mounted on my Z this past Sunday were able to accept the 19mm socket with plenty of wiggle room.
Old Feb 15, 2014 | 12:51 PM
  #2006
Fillipe's Avatar
Fillipe
Default Suggestions
Hey guys... I got RPF1s 9.5/10.5 and im not sure wht to do for tires. My main problem is the rear because of the dual caliper bracket. It pushed the wheel out another 8mm.
So wht can I fit on 10.5 +7 without running negative camber? I was thinkin 275/40
The front I am most likely goin to need spacers to make sure I don't rub at full lock with the tie rod spacers from tein. on the 9.5 I was thinkin 245/40. Offset will prob be +5 or mayb even 0.
Im lowered on coils. Plan on keepin this same ride height
Any inputs on this? Front tires will be Nitto NT05 and rear NT 555. Thanks
Old Feb 16, 2014 | 01:45 AM
  #2007
terrasmak's Avatar
^^^ drift car? How much power and what kind of camber setting (OEM spec or proper drift)
Is this your street setup, or will you be drifting on these? I ran a 275/40 at 10.5 +10 as my street setup, then a 285/35 with the same specs for track. My rear camber was set to -2.2
Old Feb 16, 2014 | 06:17 AM
  #2008
RENFRO's Avatar
RENFRO
This was taken by my detailer after some serious hours cutting/buffing/polishing my '03's paint.
Old Feb 16, 2014 | 04:23 PM
  #2009
DarkCreep's Avatar
DarkCreep
Thanks for the new wallpaper Renfro.
Old Feb 16, 2014 | 07:02 PM
  #2010
Fillipe's Avatar
Fillipe
Its a street car. Nothing crazy for power. Bolt ons and uprev tune. As far as camber I don't kno how big a difference from oem to drift spec but I was thinkin -1 maybe -1.5. I was dumb enough to get into the whole stance crap and I'm running -6.5 now. Smh. But those days are over and it's time to have some real fun with this thing. Thx for the input.
Old Feb 19, 2014 | 09:38 AM
  #2011
nismofreak1208's Avatar
nismofreak1208
In regards to the new enkei rs05rr....I want to do a staggered 18x10 +22 and 18x11 +16 (I think its +16) but what do the wheel gurus here think? These wheels will be used for a little autox and mainly DD use since I have rpf1s for autox. I also want the speedometer to read correctly for the DD use.
Old Feb 19, 2014 | 10:35 AM
  #2012
lifekenophobic's Avatar
lifekenophobic
Paint and car are looking great, RENFRO. I'll be correcting my paint too, when I feel like devoting a weekend to it...
Old Feb 20, 2014 | 09:55 PM
  #2013
superlim9's Avatar
superlim9
Looks awesome Renfro...
I just ordered mine from Oakos today... they'll be at the house next week but i wont be home for 3 more weeks
Old Feb 22, 2014 | 06:12 PM
  #2014
meanz's Avatar
meanz
Finally put these on today
Old Feb 22, 2014 | 06:52 PM
  #2015
Underscore_Hero's Avatar
Underscore_Hero
very nice meanz
Old Feb 23, 2014 | 04:00 PM
  #2016
Bmurray350z's Avatar
Bmurray350z
Old Feb 23, 2014 | 08:34 PM
  #2017
fzero's Avatar
fzero
changed the color on my rpf1's, I'm still unsure about the result but I guess I'll keep it for now <a href="http://imgur.com/pUS2CnN"><img src="https://i.imgur.com/pUS2CnN.jpg" title="Hosted by imgur.com" /></a>
Old Feb 23, 2014 | 08:38 PM
  #2018
meanz's Avatar
meanz
need more pics fzero! looks great! Give me your diffuser!
Old Feb 23, 2014 | 09:08 PM
  #2019
fzero's Avatar
fzero
<a href="http://imgur.com/XJ8Oldb"><img src="https://i.imgur.com/XJ8Oldb.jpg" title="Hosted by imgur.com" /></a> <a href="http://imgur.com/bBWdQQp"><img src="https://i.imgur.com/bBWdQQp.jpg" title="Hosted by imgur.com" /></a> <a href="http://imgur.com/2KNtbck"><img src="https://i.imgur.com/2KNtbck.jpg" title="Hosted by imgur.com" /></a> Ask and ye shall recieve
Old Feb 23, 2014 | 11:11 PM
  #2020
terrasmak's Avatar
Dam that color works well.
