Unofficial Enkei Wheels Thread
Old Mar 7, 2014 | 11:14 AM
  #2041
ap2_S2Kyle's Avatar
ap2_S2Kyle
Originally Posted by AdvanZ33
OEM TPMS will fit and they act as your valve stem as well so you don't use the blue ones at all. You should be able to use the blue valve stem caps on the OEM TPMS if you want to add some color though.
Thanks!
Old Mar 10, 2014 | 08:08 PM
  #2042
Bmurray350z's Avatar
Bmurray350z
Added some decals to my RPF1s today
Old Mar 13, 2014 | 08:23 PM
  #2043
ap2_S2Kyle's Avatar
ap2_S2Kyle
[IMG][/IMG]
got wheels and tires installed yesterday..had to get the fenders rolled as well..love the wheels so far.. 18x9.5 and 10.5 on 255/275
Old Mar 13, 2014 | 09:21 PM
  #2044
mr. sparco's Avatar
mr. sparco
PFs.
Old Mar 14, 2014 | 02:44 PM
  #2045
superlim9's Avatar
superlim9
Default finally got them in
Got them put on today.. 17x10 effective offset is +24.5 in the front and +28 in the back. Should have plenty of room for 285s when lowered.. 275 square now
Old Mar 15, 2014 | 05:56 AM
  #2046
superlim9's Avatar
superlim9
A few more pictures of the test fit at full compression
Old Mar 16, 2014 | 06:32 AM
  #2047
harman850t5's Avatar
harman850t5
Finally took the winter wheels off and put these back on. Plan on putting some 285s on the rears sometime this year.
Old Mar 16, 2014 | 07:14 AM
  #2048
terrasmak's Avatar
That's not even close to full compression. At full compression the tire should be well tucked in the well.
Old Mar 16, 2014 | 12:39 PM
  #2049
superlim9's Avatar
superlim9
I Pulled a front Strut and rear spring, disconnected the sway bars and then jacked up the wheel.. maybe I missed something
Old Mar 16, 2014 | 04:23 PM
  #2050
mr. sparco's Avatar
mr. sparco
I'm with terrasmak on this one, the wheel should be much closer to the fender with tire tucked in. Even more so minus suspension parts since no spring compression in the rear. lol
Old Mar 16, 2014 | 05:52 PM
  #2051
ap2_S2Kyle's Avatar
ap2_S2Kyle
[IMG][/IMG]
planning to do a nismo v2 front bumper next..have had the wheels for a few days now..love them so far
Old Mar 16, 2014 | 07:31 PM
  #2052
terrasmak's Avatar
Coilovers?
Old Mar 18, 2014 | 11:16 AM
  #2053
superlim9's Avatar
superlim9
Coilovers?
All stock.... except my sways
Old Mar 18, 2014 | 11:25 AM
  #2054
pyshin's Avatar
pyshin
^^^ Is there a reason why you went with the smaller size/weaker offset instead of the usual 18x9.5f 18x10.5r +15 staggered setup? Weight savings for the track or just stumble on a deal..?
Old Mar 18, 2014 | 01:29 PM
  #2055
superlim9's Avatar
superlim9
Wanted an entry level track setup. I do DD the car when I'm in the states and will only be doing a few track days and I wanted light weight setup. I don't have plans for BBk or anything crazy so I stuck with 17's
Old Mar 19, 2014 | 01:11 PM
  #2056
R6n350GT's Avatar
R6n350GT
I Have Enkei Raijin 18/9.5+15 all round, 265 on front and 285 on rear. I would like to go to a 305 on the rear as will be hitting 500HP and maybe need to extra width on the rear (using RS3s). What wheels and offset do i go for ? the 9.5+15 are perfect offset.
Oh and must be concave front and rear
Old Mar 19, 2014 | 01:22 PM
  #2057
pyshin's Avatar
pyshin
^^^ I would look into the new RS05RR's. Raijin's max width is 9.5 and although that is great for the front it leaves more to be desired in the rear (pun intended).
RS05RR's come in 18x10.5 +15 and even 18x11 +16, very desirable sizing/offset for the rear of a Z.
Also they have the concave look that you're looking for:
Just a thought.
Edit: Btw Hankook doesn't make anything larger than 285/35 for 18" RS3's iirc.
Old Mar 20, 2014 | 02:37 AM
  #2058
R6n350GT's Avatar
R6n350GT
Just a thought.
Yeah i like them but want hypersilver like the raijins. black just doesnt stand out :/ yeah ill have to go to 19" what size is best for 305, 11" or 10.5" and which is closest to 9.5 +15 ?
I guess is a 305 going to be of any benefit over a 285 rear for 500HP ?
Also prices for those Enkei ? i asked some sponsors but no reply yet
Old Mar 20, 2014 | 05:57 AM
  #2059
pyshin's Avatar
pyshin
- Honestly idk what to say about color preference, that's your prerogative
- Enkei does not make 19" RS05RR's. You would have to go with classic RPF1's. Or choose a different tire.
- Yes 305 will benefit, hell I'd consider going 315 for 500 hp
- Don't know MSRP, I have a friend that runs a set but he got a deal on them
Old Mar 23, 2014 | 05:27 AM
  #2060
joeyxbat's Avatar
joeyxbat
Do you happened to have pic with this setup on your G? I have the same wheels but not sure what size of tires to get. Thanks
