Unofficial Enkei Wheels Thread
Old Sep 21, 2017 | 04:59 AM
  #2781
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Originally Posted by xxKURTMANxx
18x9.5 +15
245/40s
Spacers 15mm/20mm front/rear
Interesting I have the same size with no spacers and my fronts are poked out... Dont know why you would need spacers.
You might wanna double check the back of your wheel the next time you take them off.
Old Sep 21, 2017 | 06:14 PM
  #2782
xxKURTMANxx's Avatar
xxKURTMANxx
Front camber is around -2.5°. They poke a little bit but the front fenders are pulled a bit from drifting with the car fairly low.
Old Sep 27, 2017 | 06:52 AM
  #2783
KingBaby's Avatar
KingBaby
Hardest Setting
saving for 17/18 combo in RPF1s
MORE
Old Sep 28, 2017 | 08:28 PM
  #2784
terrasmak's Avatar
MORE
I would run a 17/18 combo or just run 17’s if tire selection didn’t suck. Without 275/40-17 available everywhere, just not worth it
Old Oct 1, 2017 | 05:25 PM
  #2785
NA&CH's Avatar
NA&CH
18x10.5 295/30/18 square
by https://www.flickr.com/photos/ejhcab/, on Flickr
If you can't beat'um Join'em Damn Honda 2000's
Chris
Old Oct 30, 2017 | 10:48 PM
  #2786
Irontimmy's Avatar
Irontimmy
Me again, TSP6 9.5x18 +15
Old Oct 31, 2017 | 03:56 PM
  #2787
Spike100's Avatar
Spike100
^^ looking good
Old Nov 8, 2017 | 05:22 PM
  #2788
Irontimmy's Avatar
Irontimmy
Originally Posted by Spike100
^^ looking good
thanks
Old Mar 8, 2018 | 08:42 AM
  #2789
Xrabbix's Avatar
Xrabbix
Finally got mine mounted. Need a drop so bad
How low can I go before I have to start messing with camber, and stuff? I'd like to just pickup a set of Bilstein pss10's and be done with it if possible
Old Mar 8, 2018 | 01:29 PM
  #2790
dboyzalter's Avatar
dboyzalter
I'm so tempted to get another set of wheels right now but I dont need them at all... They are just on sale... The horror.
Old Mar 8, 2018 | 03:23 PM
  #2791
MicVelo's Avatar
350Z/370Z Tech Moderator
GENERALLY SPEAKING.... <25mm/1" will bring your camber to a little more than -2.1 degs, coincidentally, the low end of the alignment range.
I always tell people that if you want to be safe, do a toe alignment after you lower it and check all for out of spec to save tires. And have the budget to buy FUCAs and camber gear.
DO EEEEEEEEEEEEEEEEEEEEEEEEEEETTTTT!!!! JUST DOOOOOO EEEEEET!!!!!
I know, Mrs. dboyzalter hates me.
Old Mar 9, 2018 | 06:06 AM
  #2792
Xrabbix's Avatar
Xrabbix
After mounting the new wheels I have a grinding / scraping noise in the front end when turning the wheel either direction. I have PLENTY of clearance all around the tire so it's not the fender hitting it.
I see nothing that could be hitting anything when turning the wheels anywhere. Did not have this problem with the stock tires/wheels I just replaced.
Now the odd part is when I jack the car up and turn the wheels I get zero noise.
Ball joints look fine and don't appear to be leaking, nothing is hitting the backside of the wheels and I can slide my hand in between the fender all around the tire.
Any ideas?
Old Mar 9, 2018 | 07:46 AM
  #2793
MicVelo's Avatar
Any ideas?
When the car is jacked up the suspension droops enough to give you clearance between the tire/wheel assembly and whatever it's hitting.
Check the fender liner bolt for interference with the tread, not sidewall. Also check for clearance at the fore/aft, lower extremes of the fender well opening (the lips). If the tire is taller than stock, there's a chance of tread interference in these areas.
Size of tires? Offset of wheels?
Old Mar 9, 2018 | 07:53 AM
  #2794
Xrabbix's Avatar
Xrabbix
255/40/18 / 275/18/40 hankook ventus Evo with RPF1's 10.5+15 / 9.5+15 on stock 08 suspension
With the car on the ground there is still tons of room between the fenders and tires and everything else. I've inspected all around with it sitting on the ground and can't find anything that's even close to hitting anything. Just super strange.
Old Mar 9, 2018 | 07:57 AM
  #2795
Xrabbix's Avatar
Xrabbix
Lots of room. I can get my hand all around the tire with it sitting on the ground.
Old Mar 9, 2018 | 12:24 PM
  #2796
dboyzalter's Avatar
dboyzalter
Could be hitting the upper control arm, pull off the wheel and look for the marks.
Old Mar 10, 2018 | 04:03 AM
  #2797
Xrabbix's Avatar
Xrabbix
I got up under the car and looked for anything they may be hitting and there is definitely nothing they could be hitting. They are the standard 18" 9.5+15 with 255/40/18 tires.
I may just slap some new wheel bearings and rotors on and see if that fixes it.
Old Mar 10, 2018 | 09:30 PM
  #2798
terrasmak's Avatar
Front fender screw will hit and the rear lips will also crib if not rolled
Old Mar 11, 2018 | 01:43 AM
  #2799
Xrabbix's Avatar
Xrabbix
Turns out it was a semi blown front strut. Weird.
Side note will the 14'' Akebono Big Brake Kit fit this setup? (9.5 +15 & 10.5 +15)
Old Mar 27, 2018 | 04:37 PM
  #2800
CK_32's Avatar
CK_32
What lugs is everyone using with the RPF1’s?
My stock lugs don’t fit.
