Unofficial Enkei Wheels Thread
Old Aug 31, 2010 | 07:33 AM
  #501
ComeBack's Avatar
ComeBack
Originally Posted by arsey51
Got the new PF01's dropped off the other day......will put on this weekend......
They look very similar to the work cr kai. But they should look nice mounted.
Old Aug 31, 2010 | 10:10 AM
  #502
JDSMotoring's Avatar
JDSMotoring
Vendor - Former Vendor
scotts i love the way your car turned out man....looks sick
Old Aug 31, 2010 | 01:18 PM
  #503
Voboy's Avatar
Voboy
Originally Posted by scotts300
Another shot, but now with 305/30/18 tires on all four corners on 18x10 RPF1s.
http://farm5.static.flickr.com/4095/...24a87fd1_b.jpg
http://farm5.static.flickr.com/4141/...5943a391_b.jpg
first photo is really making the setup stand out! even if the car was still silver it'd still look good!
Old Aug 31, 2010 | 01:47 PM
  #504
scotts300's Avatar
scotts300
Thanks, fellas!
Old Sep 2, 2010 | 07:28 PM
  #505
Clam's Avatar
Clam
I thought I share my new autocross wheels for STR.
Enkei RPF1 17x9 +22 w/ Kumho XS 245/45/17 tires
And my DD wheels Enkei RP03 18x10 +22 w/ Yokohama S-drives 275/35/18
Old Sep 3, 2010 | 07:51 AM
  #506
OAKOSAutomotive's Avatar
OAKOSAutomotive
The RP03s look awesome on your car!
Bart
OAKOS Automotive
Old Sep 3, 2010 | 07:56 AM
  #507
03threefiftyz's Avatar
03threefiftyz
Clam,
What was your reasoning for not going to the 255 all the way around? Just curious.
Old Sep 3, 2010 | 11:08 AM
  #508
Clam's Avatar
Clam
Bart
OAKOS Automotive
Thanks! That's why I have them as my DD wheels.
Clam,
There were no tires in the Extreme Summer Tire Category that were in the size of 255/45/17. The current size I was driving on were 275/35/18 tires, which were about 3.7% shorter than stock. I wanted to to keep the same gearing like I had for the 275/35/18, so I went with a 245/45/17 tire instead of a 255/40/17 tire, which would shorten my stock gearing by 6.5%.
Maybe I'll try a 255/40/17 tire after I go through these sets. Right now I'm just trying to re-learn the car on skinny tires and don't want to introduce too many variables in the learning process.
Old Sep 3, 2010 | 11:14 AM
  #509
03threefiftyz
True. I suppose a lot of it will lie in how your region picks its emphasis on course design....whether faster or slower. The shorter gearing may actually help if it's the latter.
Old Sep 3, 2010 | 11:51 AM
  #510
Clam's Avatar
Clam
Most of my region's course design are wide open and fast. However, I can see how the shorter 255/40/17 would help with the tighter and slower course designs. My 2nd gear would top out at 67 mph with the 255/40/17 tire instead of 69 mph with the 245/45/17 tire. But my main concern, is putting the power down. I won't know which set-up works for me till I go out there and drive.
Old Sep 3, 2010 | 08:35 PM
  #511
mr. sparco's Avatar
mr. sparco
Old Sep 6, 2010 | 08:09 PM
  #512
Zazz93's Avatar
Zazz93
Very clean!
Old Sep 6, 2010 | 08:11 PM
  #513
Waiz's Avatar
Waiz
Originally Posted by Zazz93
Very clean!
What are the specs?
Old Sep 7, 2010 | 05:11 PM
  #514
mr. sparco's Avatar
mr. sparco
Very clean!
Originally Posted by Waizzz
What are the specs?
18x9.5/10.5 +15, 255/35 285/35s.
Old Sep 7, 2010 | 05:45 PM
  #515
ppwpz33's Avatar
ppwpz33
Thought I'd join in!
Attached Thumbnails Unofficial Enkei Wheels Thread-35326_10150231698305384_730840383_13645908_2402034_n.jpg   Unofficial Enkei Wheels Thread-sdc10608.jpg   Unofficial Enkei Wheels Thread-sdc10612.jpg
Old Sep 7, 2010 | 07:05 PM
  #516
siberian57's Avatar
siberian57
Originally Posted by ttuberz
ya that was me. thanks man! which one is yours?
Mine is sitting down in Florida right now. I moved down there for school but you should see me back up in CT as soon as I find a better job up there.
Old Sep 11, 2010 | 09:11 PM
  #517
arsey51's Avatar
arsey51
OK, I don't get it - where did I go wrong -was going to mount the new PF01's (with +15, similar to a lot of the RPF01 setups I've seen on this thread)and look how much they stick out from flush -here are shots or rear 10.5 +15
front
rim sizes are 9.5 front and 10.5 rear +15 on all four. Isn't this size and spec similar to mosrt oif the RPF01s on this thread - and they don't appear to stick out anywhere near to what are doing. Obviously have to have these exchanged, very disappointing day.
iffest, and before tires got mounted,
Old Sep 11, 2010 | 09:23 PM
  #518
Zivman's Avatar
Zivman
front
those are pretty aggressive offsets, but people run them... get the tires mounted and set the car down and you will find, they aren't quite as bad as they seem with car car up in the air.
IMHO, a +27 on a 10.5" wheel is about where one wants to be. You can run just about any size tire without rubbing/rolling and still not look tucked. So figure you are only 12 mm off that.... 12mm isn't that much, maybe a bit more than the width of your finger
Old Sep 11, 2010 | 09:26 PM
  #519
2k6-z33's Avatar
2k6-z33
Yeah once you have the car on groud they wont seem so aggressive..
Old Sep 11, 2010 | 09:38 PM
  #520
Ruthless18x's Avatar
Ruthless18x
Wow, car looks awesome man. What model tire are you running? R888s?
