Unofficial Enkei Wheels Thread
Old Mar 26, 2011 | 11:12 AM
  #641
scotts300's Avatar
scotts300
FYI:
255/35/18 R888 on 18x9.5 +15 rubs lightly at 2.4 camber
275/35/18 R888 on 18x10.5 +15 rubs lightly at 2.0 camber
Car is mildly lowered, camber is in check, tires are mildly square, but certainly not square like a Hoosier. Fenders are not rolled - owner has no desire for that.
I was surprised to; so. . . anyone want a set of new matte black RPF1s on those sizes?
Old Mar 26, 2011 | 12:50 PM
  #642
rich2342's Avatar
rich2342
Originally Posted by NyCSnEaK
Congrats on the purchase. Post some pics when you get them installed. What size and offset's did you purchase? Tire widths? Thanks in advance.
Probably going to go with Nitto Nt05's they are surprisingly the cheapest I've found and get pretty decent reviews.
I'm still waivering back and forth on sizing to save a few bucks on the tires and fender roll. Either 285/35/18 ---255/35/18 or 275/40 and 245/40.
We'll see how frisky im feeling. My wallet is drained with so many expenses i've created..
Old Mar 26, 2011 | 02:42 PM
  #643
03threefiftyz's Avatar
03threefiftyz
Nt05's are rubbish in the wet.....
Old Mar 26, 2011 | 03:08 PM
  #644
rich2342's Avatar
rich2342
Streetwise? Hydroplane easily? I read some mixed reviews some said actually decent in rain, another not so much..
Old Mar 26, 2011 | 04:00 PM
  #645
terrasmak's Avatar
Why drop to a 30mm stagger front to rear, the car understeers enought with the factory 20mm stagger. 255/75 or 265/285 is a much better combo.
BTW never driven my NT05's in the rain, don't know how they are. I would think they are better than the Falken 615's i had at one time.
Tires all hydroplane at the same speed, the tread determines the traction before you go up on plane, and the stability you have while on plane.
Old Mar 27, 2011 | 07:52 AM
  #646
BSERIEuS's Avatar
BSERIEuS
i just went and checked out some NT03's in person.
Since I've already done RPF1's on my previous car...I figured i would go with a NT03 setup.
it just seems that no one ever posts theirs up! All i've seen with NT03's are Kal_el's all black Z.
if anyone has some pics of NT03's on Z's please post them up for inspiration!
thanks in advance.
Old Mar 27, 2011 | 10:49 AM
  #647
Waiz's Avatar
Waiz
Originally Posted by Rx Punk
Yay, my turn 18 x 9.5 all around and re11's 35 x 265 all around.
Offset?
thanks in advance.
This dude has a set:
https://my350z.com/forum/media-share...hotoshoot.html
Old Mar 27, 2011 | 03:05 PM
  #648
terrasmak's Avatar
thanks in advance.
Like the ones in post #12 of this thread, like on the first page https://my350z.com/forum/7197204-post12.html
Old Mar 27, 2011 | 06:28 PM
  #649
NyCSnEaK's Avatar
NyCSnEaK
Terrasmak,
I was wondering which combo would be ideal between 255/40/18 & 265/40/18 and 265/40/18 & 275/40/18, on a RPF1 9.5 & 10.5 rims? Since a few posts up you mentioned, that staggered sets bring about inherent understeer. I want to do it right the first time. Any info would be of great help and much appreciated.
Old Mar 27, 2011 | 07:06 PM
  #650
rich2342's Avatar
rich2342
^ you can tune your suspension and sways for a more neuteral feel.
Old Mar 27, 2011 | 07:10 PM
  #651
terrasmak's Avatar
Terrasmak,
255/40 and 275/40 is a great street combo with some stretch for the "look" thats what i run for daily driving. Then if you want wider fronts, you really nee to drop to 35 series. A 265/35 285/35 is still a great street combo, but will really start to shine on the track. My current track setup, very minimal understeer is 275/35 and 275/40, its easily streetable, next i'm going to add a little understeer with running 275/35 front and 285/35 rear just to have the extra rubber.
Old Mar 27, 2011 | 08:13 PM
  #652
scotts300's Avatar
scotts300
Is this for the 9.5/10.5 +15 combo? If so, please elaborate on camber specs, because a car I just toyed with with the combo above and 255/275 tires did not work out perfectly.
Old Mar 28, 2011 | 01:33 AM
  #653
NyCSnEaK's Avatar
NyCSnEaK
Scott,
I hadn't specified the offset, but you are correct, +15 offset. What kind of issues with camber have arised, with 9.5 & 10.5 widths? You and Terrasmak are the individuals who I look to for advice, in regards to proper tire sizes, since you two are the track and autocross OG's. Thanks again fellas.
Old Mar 28, 2011 | 06:29 AM
  #654
lazyduster's Avatar
lazyduster
285/30/18x10.5 all-round with +15 front an +0 rear with 15mm spacer
Old Mar 28, 2011 | 06:36 AM
  #655
BSERIEuS's Avatar
BSERIEuS
thanks fellas!
what suspension are you running?
Old Mar 28, 2011 | 06:55 AM
  #656
lazyduster's Avatar
lazyduster
Stance al+pros true rears
Old Mar 28, 2011 | 06:58 AM
  #657
scotts300's Avatar
scotts300
Scott,
No real issues with camber, but one simply needs to be cautioned when running the Enkei RPF1 wheels in the +15 offset (whether they are 9.5 or 10.5). It is an awesome looking set-up, but not everyone can run a moderately large tire without some requirements (high camber, rolled fenders) or consequences (rubbing). A little bit of camber goes a long way in upper clearance.
I run this same set-up on the track, but without the rear spacer. My rear camber is 2.5*, I have no idea how you can run those with a +15 rear spacer unless you have the same or more camber, and rolled fenders. Mine are not.
Old Mar 28, 2011 | 07:49 AM
  #658
lazyduster's Avatar
lazyduster
I'll find out today when I do the aliment on the car after work
Old Mar 28, 2011 | 08:12 AM
  #659
terrasmak's Avatar
My current street combo is the 9.5 front at +15 and 10.5 rear spaced to +10 with the 255/40 and 275/40. The camber is the key, i had -1.5 front for a while and rubbed on the fender liner screw, -1.8 clears easily ( i removed the spring and collapsed the suspension to check clearances. With -2.3 i clear the +15 up front with 275/35. The rear is rolled and i was running -1.8 with no problems, now at -2.1 i have extra clearance.
Ride height is a huge factory too because of the camber gain as suspension compresses.
Old Mar 28, 2011 | 08:54 PM
  #660
Creepin!'s Avatar
Creepin!
18x9.5+15 18x10.5+15 on Tein S techs
Attached Thumbnails Unofficial Enkei Wheels Thread-one.jpg   Unofficial Enkei Wheels Thread-three.jpg
