Unofficial Enkei Wheels Thread
Old May 4, 2011 | 02:11 PM
  #801
SE5spd's Avatar
SE5spd
Just ordered my RPF1's =)
Old May 4, 2011 | 09:46 PM
  #802
Z33=MONEY's Avatar
Z33=MONEY
ENKEI RPF1 RACE SLICKS
Old May 5, 2011 | 07:11 AM
  #803
scotts300's Avatar
scotts300
What specs are the Enkeis, and what are the details of the "race slicks"?
EDIT: Found it - 18x9.5 +38 with 265/35, 18x10.5 +15 with 285/30 BFG R1s.
Old May 5, 2011 | 08:01 AM
  #804
AadosX's Avatar
AadosX
They aren't "race slicks," they're RACE SLICKS!
Old May 6, 2011 | 04:10 PM
  #805
Daron's Avatar
Daron
Default wooooooot!
These arrived today! Waiting for tires still. 18x9.5 and 18x10.5
Old May 6, 2011 | 06:37 PM
  #806
scotts300's Avatar
scotts300
Nice, and welcome to the club! I see there is no method to their madness of applying the Enkei stickers. They are never in the same spot between wheel orders.
Old May 7, 2011 | 11:28 AM
  #807
AznSky's Avatar
AznSky
anybody got pics of black RPF1's on black Z?
Old May 8, 2011 | 12:50 AM
  #808
venom42's Avatar
venom42
OK - So I have just read through all 30+ pages of this thread. It seems that there are some differing opinions of whether you can get away with a 18X10.5 +15 all the way around without rolling the fenders. I want a set of the blue RPF1s, which I can only find in a 18X10.5 +15, but have no interest in rolling the fenders. I plan to go with 275/35/18 BFGoodrich KDW tires. Am I going to be rubbing all the way around? I have the Hotchkis TVS stage 1 setup, which is a less than 1" drop. Daily driver, but I auto-x every other month or so.
I could go for the PF01 in black, which I can get in a 9.5 +15, but I just really dig the blue. Either way, I have to get rid of these SSR GT3s I have now. Way too "blingy" and too tucked in.
Old May 8, 2011 | 07:36 AM
  #809
acke15's Avatar
acke15
i have 18x10.5 +15 all around with 275//35/18s, i was dropped on gf210 springs which is 1"F and 1.2" R and i didnt rub.. should be fine.. just need some camber. do you have the stock rear camber control arms?
Old May 8, 2011 | 07:57 PM
  #810
venom42's Avatar
venom42
I have the stock alignment setup. I am within spec on the rear (i think it was -1.1), and just outside stock on the front at -1.7. I would love to be able to pull off a 285, but I have a feeling I will already be pushing it with the 275. Thanks.
Old May 8, 2011 | 08:26 PM
  #811
scotts300's Avatar
scotts300
I have personally seen 275s rub on a Z with 9.5 +15s. It was only lowered. It needed the fenders rolled. They were Kumho XS 275s.
Old May 8, 2011 | 10:06 PM
  #812
terrasmak's Avatar
Rear OEM spec is -1.1 to -2.1 and yes you will need to be on the higher side of spec in the rear, and probably still need a slight roll. The front to run a 285 you will be looking at -3, I would just do 275 front and 285 rear.
Me too, but it was with Nitto Invo's and Nitto 555's.
Old May 10, 2011 | 04:18 PM
  #813
Daron's Avatar
Daron
18X9.5, 18X10.5 wrapped in 265/35/18 and 275/35/18 BFG G-Force T/A KDW2's
I know I need a drop, still rocking the stock springs.
Old May 10, 2011 | 04:58 PM
  #814
acke15's Avatar
acke15
Anyone use the rfp1 center caps?
Old May 10, 2011 | 08:54 PM
  #815
Junkster's Avatar
Junkster
gawd those things are OOOoooglyyy, i have heard people can get away with CCW or whatever center caps, they sit flush with the wheel and dont stick out...just gota buy the right size cap but they look really nice..just do some research, im too lazy to look for the info haha
Old May 11, 2011 | 05:50 PM
  #816
mr. sparco's Avatar
mr. sparco
I did, they are okay, but rather have the flat type center caps.
Old May 11, 2011 | 10:27 PM
  #817
venom42's Avatar
venom42
Default driving me crazy
Perhaps I am just obsessing waaaay too much over this, but I just do not want to make the wrong choice on this one (already made the wrong choice once). After talking to several people, I have resigned to going with the 18X9.5 now. In looking at the tire calculator, it seems that a 255/40-18 front and 275/40-18 rear are the closest rolling diameter to stock, and should cause no issues with ABS or anything. The 35 is 4.1% faster than stock in the rear, which I am being told could cause issues with the ABS system (don't have VDC). With an aspect ratio of 40, methinks I am increasing the odds that I will have to roll the fenders, which I am trying to avoid. The SSR GT3s that I have on the car now are a 275/35-19 in the rear, on a 19X10 with a +24 offset, and they do not look right because they sit too far inside the fender (fronts are much worse on a +38 19X8.5). I plugged the numbers into the offset calculator I found in another thread (http://www.1010tires.com/WheelOffsetCalculator.asp), and it looks like the 9.5 is only pushing out about .1" from what I have now, and the 10.5 would only be about .6" farther out.
SO... I guess the question is - the ones that you guys have seen rub on a 9.5 with a 275, were the cars lowered alot? My car is lowered less than 1" on Hotchkis TVS springs. Am I worrying too much about this whole rolling thing? The guys in the shop where I work seem to think it is no big deal, but everyone else is telling me horror stories and saying it will destroy resale (if I ever wanted to sell it). Am I worrying too much about this wheel speed differential thing? Is a square setup better since I have adjustable sway bars? Is 275 going to be too wide for a 9.5" wheel (looks right on the 10" wheel on the car now)?
I really want these RPF1s, and I HAVE to ditch these GT3s, but this is making me effing crazy. I have been spending hours nightly reading threads and looking at pics. I need a drink.
Old May 11, 2011 | 10:43 PM
  #818
scotts300's Avatar
scotts300
I have posted pics of a 18x9.5 +15 car with 275/35/18 Kumho XS tires all around. It did rub a lot (front and back) until he got a roll. Then it only rubbed every now and then, then he added some camber and it does not rub. That car is lowered on Eibach springs.
Old May 12, 2011 | 06:19 AM
  #819
acke15's Avatar
acke15
Venom-Just buy some front upper control arms and run a little negative camber. You'll b fine
Old May 12, 2011 | 06:52 AM
  #820
TheSyn3rgist's Avatar
TheSyn3rgist
Do you find not being able to rotate your wheel/tire setup is worth it considering the small difference between the front and rear tires (in size)? How do you like the performance? Does the rear tire fill out the fenderwell better being a 275? I'm debating between going square and being able to rotate versus staggering...
