Unofficial Enkei Wheels Thread
Old Jul 18, 2012 | 12:33 PM
  #1401
harman850t5's Avatar
harman850t5
Originally Posted by boliviandaddy23
ok need your help before i pull the trigger
i have rpf1 f9.5 r10.5 +15 all around...i like the nice fat tire look
i already have 265/35 for the front but for the rear i see alot of you
guys going with 285/35...could i do 295/35 instead? its only a little
difference and i know i will get a little under steer with 285 and 295
...that's question number one...my car is dropped a little less then
1.5inches...so would i have to get my rear fenders rolled? (im guessing
yes)
can you guys tell me the pros and cons of running nice fat tires?
besides the fact that they are expensive lol got my eye on
bfGoodRidge g-Force T/A KDW 2
Not sure about your question, but you'll love the kdws. They kind of scare me with how much wet traction they have
Old Jul 18, 2012 | 01:18 PM
  #1402
terrasmak's Avatar
Originally Posted by Zoco
What about 8.5 in the front and 9.5 in the rear for rims sizes? Or 9 in the front and 10 in the rear? Why does everyone run 9.5 and 10.5? Im sticking with 18' all around too.
9 front and 10 rear work , but you will need spacers because the Offset sucks in RPF1 in those sizes.
If you don't want to roll the fenders , run the Enkei NT03 9.5 front +27 and 10.5 rear +30 with the same tires i mentioned earlier.
Old Jul 18, 2012 | 01:34 PM
  #1403
Esser's Avatar
Esser
waiting to be put on.... just one more week!
A quick photoshop.....
Old Jul 18, 2012 | 07:44 PM
  #1404
Zoco's Avatar
Zoco
Ok im probably going to get rpf1's 18x9 and 18x10. What kind of spacer do I need to run and why? Also best tire sizes and I looking for nismo height suspension wise.
Old Jul 18, 2012 | 08:06 PM
  #1405
SE5spd's Avatar
SE5spd
I think 9 is +35 10 is +38
Old Jul 18, 2012 | 08:47 PM
  #1406
mr. sparco's Avatar
mr. sparco
You should do more reading and searching before you make a purchase, you may regret due to offsets. +38 is pretty shatty looking on the Z, spacers would correct the offsets.
Old Jul 18, 2012 | 10:08 PM
  #1407
terrasmak's Avatar
20mm front and rear, just save your the $200 in spacers and buy the 9.5 and 10.5 combo. 255/40 front and 275/40 rear will fit your tire needs just fine.
Old Jul 19, 2012 | 09:44 AM
  #1408
Zoco's Avatar
Zoco
I still dont get all this offset stuff. How would it look shitty I mean I understand offset, but is it just on enkei's that it looks bad?
Old Jul 19, 2012 | 10:53 AM
  #1409
Zazz93's Avatar
Zazz93
He's basically saying the wheels may tuck in a little more than you expect, giving you a little buyer's remorse and forcing you to buy band aids (oops, spacers). I agree the +35 is a lot for a 9 inch wheel if that's what your considering (similar to a stock Nismo or Track V2 Wheel). Wouldn't look retartded but you may end up buying spacers. I think the calc says is will be 26mm tucked in the fender compared to the 9.5 +15's. +38 on the 10's would be a little tucked but not bad.
Play around with this.
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jul 19, 2012 | 12:10 PM
  #1410
Zoco's Avatar
Zoco
But I like that look...Thats actually what im going for the same ride hight and everything. I dont like 10.5 because the rear wheel is out further than the fender so whats my problem then??? Is the offset causing the problem or is it you guys just dont like my style
Old Jul 19, 2012 | 02:13 PM
  #1411
scotts300's Avatar
scotts300
The offset is a tad high for "most" Z owners, but the 18x10+38 fits in the rear without a spacer, and you can put a big tire on that mother if you want. I believe the 9" front +35 will require a spacer though. I run this same 9/10 combo in the RPF1 on my race car without issue, and the front requires a spacer (with the Brembos).
Old Jul 19, 2012 | 02:14 PM
  #1412
Zazz93's Avatar
Zazz93
No real problem we are just suggesting you see it before buying. Many pics out there, just search and confirm thats what you want.
BTW, my wheels are 9.5 +22 and I think its fairly conservative.
Old Jul 19, 2012 | 03:40 PM
  #1413
Zoco's Avatar
Zoco
Either 10' or 9.5' in the rear for me. You have 19' wheels though. What if I wanted 8.5 and 9.5 in the rear what offset would be the best? +30 and +15?
Old Jul 23, 2012 | 07:33 AM
  #1414
scotts300's Avatar
scotts300
Take a look at the 8.5" RPF1 - it is convex instead of concave; you may not like it. The +30 offset for an 8.5" wheel is also a touch high, although it does fit (it's similar placement to the stock front wheel).
Old Jul 23, 2012 | 10:22 AM
  #1415
Zoco's Avatar
Zoco
Ok 9.5 all around sounds like the best deal to me right now. I can get +15 offset for them and its not too wide. As long as I dont **** with the vdc ill be fine. Give the best tire combos for 9.5 all around, but keep them staggered.
Old Jul 23, 2012 | 11:53 AM
  #1416
scotts300's Avatar
scotts300
You can run the same size tire all around (265/35/18) or stagger with a larger rear if you like.
I have a set of black 9.5 +15 RPF1s for sale if you're interested as well. If so, PM me (not here).
Old Jul 23, 2012 | 12:00 PM
  #1417
Zoco's Avatar
Zoco
I would like to stagger them. Whats a good combo for street use?
Old Jul 23, 2012 | 02:09 PM
  #1418
terrasmak's Avatar
255/40 and 275/40 would work great for street use
Old Jul 26, 2012 | 06:57 AM
  #1419
boliviandaddy23's Avatar
boliviandaddy23
when mounting the rpf1 will i need center hub rings? or can i just slap em on the whip?
Old Jul 26, 2012 | 06:58 AM
  #1420
boliviandaddy23
<a href="http://s22.photobucket.com/albums/b335/Boliviandaddy08/?action=view&amp;current=IMG_4678.jpg" target="_blank"><img src="http://i22.photobucket.com/albums/b335/Boliviandaddy08/IMG_4678.jpg" border="0" alt="Photobucket"></a>
rpf1 can finaly go on
