Unofficial Enkei Wheels Thread
Old Jan 6, 2013 | 10:24 PM
  #1561
terrasmak's Avatar
Originally Posted by stascom
What offset would I need to be just a bit under (lower offset for more tuck) the common setup of +15 (for 9.5 and 10.5)? The reason I want to be a bit shorter on the offset is it looks like I would rub with a fatter tire otherwise (like a 265/40 or 275/35 on the 9.5). I don't want to roll fenders or remove the liner. Correct me, if I'm wrong. Exhibit A: Mexiflush
Nope, very flush, Mexiflush would stick out further
And I'm allergic to stanced camber and stretched tires
I don't blame you
What I DO want:
TIA
You need to roll to get that look, as Scott mentioned above those are wide tires on wide wheels , with a lower offset. Stick to a 9.5 front and 10.5 rear with +15 and run a 265/35-18 front and 285-35-18 rear. it will be very close to what your looking for.
Old Jan 7, 2013 | 06:25 AM
  #1562
OAKOSAutomotive's Avatar
OAKOSAutomotive
Vendor - Former Vendor
Originally Posted by 350Zdj
U da man..
Oaks, see your pm.
Reply Sent!
Taylor
OAKOS Automotive
Old Jan 7, 2013 | 10:01 AM
  #1563
stascom's Avatar
stascom
Originally Posted by 350Zenophile
Well almost. The 8.5 is convex so best to make sure you like that before committing. Here are a few 18x8.5/18x9.5 I had saved on my computer (not my car):
Ah, I didn't have a clue about the spoke design. Are all 8.5s convex regardless of offset?
Originally Posted by NA&CH
Tia,
I think the second photo is mine? If so those are 265/35/18 on a 10.5 +15. Not sure the black setup(but like it).
The last pic I beleive is scott300 silver Z before the green paint. I would pm him. Hope I helped your journey
Chris
Thanks
Originally Posted by scotts300
That's my rig. I believe that set-up was 18x10 +38 x 4 with 285/30 tires and 10 or 15mm spacers.
Indeed. I'm trying to get that fitment without rolled fenders or spacers. I guess Enkei doesn't make RPF1s in the geometry I want :/
But I would need more negative camber than stock to clear the fenders, no?
Old Jan 7, 2013 | 10:06 AM
  #1564
stascom's Avatar
stascom
That 9.5" in the back sticks out exactly as much as I want. Same color car, too. The front needs +5 more, I think. Wonder what offset that is. Hmm... maybe do a square setup? Or too much oversteer?
checked specs on Enkei's site again. They have 9.0 with +35 offset. The car above probably runs 8.5 with +30. 9 w/ +35 would be 2mm out more (according to the wheel offset calculator). I can live with that. Now, are 9s concave or convex?
Old Jan 7, 2013 | 10:37 AM
  #1565
terrasmak's Avatar
With the rears rolled you can run OEM camber, the fronts will require .2 to .5 more camber than factory spec. Scott's car is the pic you like probably has 2x or 3x more front camber than factory spec.
Old Jan 7, 2013 | 11:17 AM
  #1566
350Zenophile's Avatar
350Zenophile
LMGTFY, Looks like concave:
http://forums.nasioc.com/forums/show....php?t=2386102
Old Jan 8, 2013 | 01:43 AM
  #1567
stascom's Avatar
stascom
Thank you. 9.5 +15 for rears it is then (should be 12mm more fender clearance vs 10.5 +15).
Old Jan 11, 2013 | 04:13 AM
  #1568
NA&CH's Avatar
NA&CH
Does anyone know a shop that can achieve the SBC finish? Or am I looking at dipping the wheels? I want to "lighten"(color wise) the car up. Id trade someone a square set of 18x10.5 +15 for a silver set?
Chris
Old Jan 11, 2013 | 05:32 AM
  #1569
Bmurray350z's Avatar
Bmurray350z
I'm hopefully trading my Te37 reps plus some cash for a SBC RPF1 18x9.5/10.5 +15 setup this weekend
Old Jan 11, 2013 | 07:41 AM
  #1570
JaE35z's Avatar
JaE35z
PF01's
18x9.5 +38 BFG KDW 255/40
18x10.5 +35 BFG KDW 295/35
Old Jan 11, 2013 | 08:53 AM
  #1571
Bmurray350z
looks clean!
Old Jan 11, 2013 | 10:41 AM
  #1572
yellowxhoodie's Avatar
yellowxhoodie
[IMG][/IMG]
Chris
I looked into that for the longest time. The closest thing I found was Black Chrome powdercoat.
Or you could polish them yourself, although its extremely time consuming and frustrating. (Especially since RPF1's have alot of spokes, im doing my XD9's right now and even that sucks)
Chrome dipping is also an option. Ive heard some people say it adds quite a bit of extra weight while others say it doesnt add much.
What I ended up doing was just selling my Black RPF1's outright and picked up brand new SBC's on black friday for really cheap.
Old Jan 11, 2013 | 10:44 AM
  #1573
yellowxhoodie
Old Jan 11, 2013 | 07:27 PM
  #1574
NA&CH's Avatar
NA&CH
Originally Posted by yellowxhoodie
Great thanks you had to post a pic Damn it... Opertion find SBC. I have seen some polished black chrome powder coat loos pretty good.
Chris
Old Jan 11, 2013 | 07:29 PM
  #1575
NA&CH's Avatar
NA&CH
What i should have picked up were Advanz33 19x10 sbc...
Chris
Old Jan 12, 2013 | 03:03 PM
  #1576
mr. sparco's Avatar
mr. sparco
Old Jan 12, 2013 | 03:05 PM
  #1577
Bmurray350z
lookin good
Old Jan 12, 2013 | 03:46 PM
  #1578
freddys 350z's Avatar
freddys 350z
nice..i wished they made the Z i a pure white color. not that pearl color.
Old Jan 12, 2013 | 04:21 PM
  #1579
yellowxhoodie
PPW is such a crappy color just because of the pita of paint matching
Old Jan 12, 2013 | 05:34 PM
  #1580
-Trav-'s Avatar
-Trav-
Loving the subtle black accents, nice touch.
