Unofficial Enkei Wheels Thread
Old Jan 23, 2013 | 06:46 PM
  #1601
CleanFairladyZ's Avatar
CleanFairladyZ
Originally Posted by Barnabas
Just a roll... that's the same setup I ran.
Front and Rear? and I'm not lowered yet, still at stock height. Will I need the roll immediately at stock height or only after I go down the 1'?
Old Jan 23, 2013 | 06:57 PM
  #1602
Bmurray350z's Avatar
Bmurray350z
Fronts are rolled from the factory
  #1603
Barnabas's Avatar
Barnabas
National Z Club President
What size spacers are you running. I'm running a 10mm up front ( i could run a 5mm and still clear) and a 20mm out back on my NT03's
i think it was 15mm/20mm (offset was 30 on the NT03 right? but i dont remember i have to see if i still have the build sheet from when i had the car.
edit: found the list, 10mm in front 20mm in rear.
Old Jan 23, 2013 | 06:59 PM
  #1604
Barnabas's Avatar
Barnabas
Whats the offset on your rims?
Fronts are rolled from the factory. you need 15-25 final offset to fit it up front IIRC
Old Jan 23, 2013 | 07:03 PM
  #1605
Barnabas's Avatar
Barnabas
Old Jan 23, 2013 | 08:24 PM
  #1606
CleanFairladyZ
i was thinking +15 all around on 18x10.5
Old Jan 23, 2013 | 08:27 PM
  #1607
Barnabas's Avatar
Barnabas
Look at my pics. That's effectively 20mm front. 15mm your gonna be needing some camber.
Rear will work well at 15mm
Old Jan 23, 2013 | 08:32 PM
  #1608
CleanFairladyZ
So im going to need a roll and some front camber arms?
Old Jan 23, 2013 | 08:33 PM
  #1609
Barnabas's Avatar
Barnabas
yup. if you dont lower the car you may get away with the front until you lower.
I was lowered long before i did that setup.
Old Feb 7, 2013 | 08:53 AM
  #1610
Fenvy's Avatar
Fenvy
Default another enkei rpf1 question.. more than just will it fit
hi friends, I have a 350z with brembo/quaife lsd and that's probably the extent of performance uprades I plan to do.
No lowering the car, no out of spec negative camber, no intake/header/exhaust or FI upgrades. I am too old for that now. This is a daily driver/weekend warrior type of car.
I am already set on 17" for the sake of performance.
front tires will be 245/40R17
rear tires will be either 255/40R17 or 275/40R17
question 1) since I have no future goal for additional power, will 275/40R17 be overkill over 255/40R17? as in performance decrease due to excess contact patch?
according toe these those tire options... the front should be 17x9, unfortunately most of the search result tend to correlate with 18" but based on below post. 17x9 +22 does not clear brembo
Originally Posted by mekatoka
17x9 +22 DOES NOT clear the brembos. I know this by experience
I did not want to use spacers at the track.
question 2) so 17x9 +18 WILL clear brembo front and fit nicely?
according to the unofficial enkei thread, a lot of people run +22 for 18x10 or 19x10 and +15 for 18x9.5 or 19x9.5
question 3) so either 17x10 +22 or 17x9.5 +15 both work nicely for the REAR, right?
thank you guys so much for your input
Old Feb 7, 2013 | 09:05 AM
  #1611
terrasmak's Avatar
Run some 17x9.5 or 17x10 front and rear with 275/40 front and rear. Don't be afraid of spacers, i've been running them at the track for years now, if you track you should upgrade to APR studs anyhow.
Also since you mention track, add a little extra front camber. Out of specs is no big deal and will help you as far as lap times and tire wear.
Old Feb 7, 2013 | 10:02 PM
  #1612
stascom's Avatar
stascom
Any idea how much Kojin will weigh?
Old Feb 8, 2013 | 11:25 AM
  #1613
Fenvy's Avatar
Fenvy
see if it is in the excel list:
http://www.wheelweights.net/
Old Feb 8, 2013 | 02:43 PM
  #1614
stascom's Avatar
stascom
Microsoft Excel cannot find the data you're searching for.
Old Feb 8, 2013 | 04:10 PM
  #1615
Fenvy's Avatar
Fenvy
works fine for me but there is no kojin
probably not a popular wheel
Old Feb 8, 2013 | 05:33 PM
  #1616
terrasmak's Avatar
Doesn't look like they list the "tuning" wheel weight
Old Feb 11, 2013 | 11:26 AM
  #1617
Fenvy's Avatar
Fenvy
whoa what's that? lol
btw
do you know if RPF1 17x9 +18 front and 17x10 +22 rear is the best combination and will clear brembo?
most of the data found pertain to 18", I am pretty firm on 17 inchs
Old Feb 11, 2013 | 11:39 AM
  #1618
scotts300's Avatar
scotts300
btw
Those will clear brembo. Not sure how you define "best" combination. I like a square set-up of 9.5s, 10s, or 10.5s. Why are you pretty firm on 17s? That's where I started, but now I'm firm on 18s.
Old Feb 11, 2013 | 12:25 PM
  #1619
Fenvy's Avatar
Fenvy
by best I meant that it won't look out of place, sticking out or sit too far inside the fender
I am set on 17" for economic reason as well as weight concern. I have 0 plan for power gain.
Hancook Ventus R-S3 245/40ZR17 $152
Hancook Ventus R-S3 255/40ZR17 $155
Kumho Ecsta XS 245/40ZR17 $163
Kumho Ecsta XS 275/40R17 $187
If I were to run 18", the cost of these tires will be about 100$ more expensive a piece at no performance gain.
That's what I think anyways
Old Feb 13, 2013 | 02:51 PM
  #1620
joshua350z6841's Avatar
joshua350z6841
will be picking up a set of nt03 soon was going to go with a square setup of 18x9.5 +27 but was reading that they wouldnt clear the stock brembo brakes what sizes are u guys running an were is the best place to buy a set at
thanks for the help
