Unofficial Enkei Wheels Thread
Old May 1, 2013 | 10:21 AM
  #1741
OAKOSAutomotive's Avatar
OAKOSAutomotive
Vendor - Former Vendor
Originally Posted by reuben350z
Just ordered my RPF1s matte black staggered set up
Still contemplating which tire set up to go with..
Hankook V12
255/40/18 275/40/18 or..
265/35/18 285/35/18
So stoked.. This week is prob gonna go by super slow /:
Cant wait to see what they look like on your car!
Bryce
OAKOS Automotive
Old May 1, 2013 | 10:36 AM
  #1742
reuben350z's Avatar
reuben350z
Bryce
OAKOS Automotive
Me neither!!
Either of those tire setups will be good, if you're not lowered the 40 series will fill in the wheel gap a little more if that matters to you.
I am hopefully trading my varrstoens for some some black rpf1s here within the next week or so.
Yea I'm lowered on gf210s
Old May 1, 2013 | 12:18 PM
  #1743
terrasmak's Avatar
Hankook V12
265/35/18 285/35/18
Street car, go with the 40 series combo
Old May 2, 2013 | 09:57 AM
  #1744
srsairbags's Avatar
srsairbags
Thumbs up
Originally Posted by 2004Black350z
Order from oakos. Vendor here on the forum. Top notch. Just received my enkeis yesterday
^ +1
Got my rpf1s from them also
They need to sell more Z stuff . . currently they specialize in Subarus primarily
Old May 8, 2013 | 08:48 PM
  #1745
reuben350z's Avatar
reuben350z
Where do you guys find center caps for the rfps
Honda center caps.
Cheaper alternative and look better IMO..
https://my350z.com/forum/body-interi...nter-caps.html
Old May 9, 2013 | 01:07 PM
  #1746
reuben350z's Avatar
reuben350z
got them mounted!
18x9.5+15 18x10.5+15 on 255/40/18 275/40/18 Hankook v12s
here are some crappy phone pics. chrome lugs are temp, black lugs comin next week.
Old May 10, 2013 | 09:58 AM
  #1747
paint3all88's Avatar
paint3all88
car looks great man! thats the exact setup that i want to pull the trigger on here in a few months. how much are you fenders rolled in the rear?
Old May 10, 2013 | 12:33 PM
  #1748
reuben350z's Avatar
reuben350z
thanks!!
I actually got my fenders shaved instead of rolled..
Old May 10, 2013 | 11:02 PM
  #1749
Itzcashew's Avatar
Itzcashew
Contemplating this right now, 18x9.5 +15 all around. Concave too!
Old May 10, 2013 | 11:16 PM
  #1750
freddys 350z's Avatar
freddys 350z
yes, i want those too. wish they had a 9" and 10" in good offsets.
Old May 11, 2013 | 11:20 AM
  #1751
N80's Avatar
N80
I've got the 18x9.5 +15 square set up with RPF1's. They fit and run fine with no spacers needed on the stock, un-lowered suspension and that's what I like about that offset. Got 265x40's on it now. Will be getting a set of NTO1's in 275x35 as soon as the current tires are shot....which should be immediately after and hopefully not during my next track weekend.
Old May 11, 2013 | 07:51 PM
  #1752
scotts300's Avatar
scotts300
What are they (and cost)?
Old May 11, 2013 | 09:05 PM
  #1753
SR71's Avatar
SR71
Lead Super Moderator
Enkei Kojin's and under $250 each.
Old May 13, 2013 | 06:18 PM
  #1754
ian99rt's Avatar
ian99rt
SBC RPF1s: 18x9.5 and 18x10.5 +15mm offset, pilot super sports in 265 and 285 flavors.
Old May 13, 2013 | 06:27 PM
  #1755
Bmurray350z's Avatar
Bmurray350z
full car pic?
Old May 13, 2013 | 06:32 PM
  #1756
ian99rt's Avatar
ian99rt
full car pic?
In a day or two, only have rear fenders rolled right now and I have to knock out wheel studs to bolt up the eastwood roller.
Old May 13, 2013 | 06:56 PM
  #1757
terrasmak's Avatar
A spacer may fix the problem if you have of know someone with a spacer floating around.
Old May 13, 2013 | 10:03 PM
  #1758
scotts300's Avatar
scotts300
or 9 and 10 in ANY offset
http://www.enkei.com/size_chart/KOJIN.pdf
Old May 14, 2013 | 02:23 AM
  #1759
ian99rt's Avatar
ian99rt
My initial thoughts but the roller in its short configuration puts the pressure screw in line with a wheel stud. My ARP extended studs make it impossible to use a spacer and still able to attach the roller.
Knocking out the wheel studs is easy, just reassembly of the parking brake which is tedious.
Old May 14, 2013 | 10:26 AM
  #1760
scotts300's Avatar
scotts300
Not sure what the issue is, just know that I used the same roller to roll my rears a few weeks back, and also have the 60mm ARP studs. The only thing in the way was the caliper, which kept me from being able to roll all the way forward, but I was still able to do a tight roll in the most critical area of 60 degrees each side of TDC.
