Unofficial Enkei Wheels Thread
Old Aug 26, 2013 | 08:08 PM
  #1881
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I ran 265/35/18 RS3s on 18x9.5 +12 wheels without any hint of rubbing. I apparently have only -2.1º of camber up front.
Old Aug 26, 2013 | 08:12 PM
  #1882
terrasmak's Avatar
Originally Posted by deadohiosky1984
Pretty standard set up. Thanks for all of the responses.
RPF1 18X9.5 +15; 265/35R18 RS3
Have yet to take her out and see if the tires rub under full compression. Guess i'll have to wait until the Fontana meet
It it does rub, it's a simple fix. Will take me 5 minutes to do a slight fender pull up front.
Old Aug 27, 2013 | 02:59 PM
  #1883
scotts300's Avatar
scotts300
265 is good for the 9.5 +15. I couldn't pass up a deal on four 285s, and put them on the 9.5 +15 RPF1s as well. A little tight up front, but 3.2 degrees of camber solved it.
Old Aug 28, 2013 | 05:42 AM
  #1884
jdmlove1's Avatar
jdmlove1
hi, finally sold my stock wheels planing to go for rpf1 18" 10.5 +15 all around
my car is lowered (s-techs)... i am thinking of going for Potenza re11 275-40-18?
those will be my track - autoX wheels. but also i will drive to the track and back using these tires so i dont wanna go too low.. but at the same time i wanna the wheels + tires diameter be smaller than the stock wheels
should i go for 275/40 or 275/35 re11?
Old Aug 28, 2013 | 05:53 AM
  #1885
Tearik's Avatar
Tearik
are you going for the stretched look?
275 fits perfectly on a 9.5" wheel so its going to be stretched by about 1" on the 10.5
my 255 fronts you can even tell they're slightly stretched on my front 9.5s
Old Aug 28, 2013 | 08:08 AM
  #1886
jdmlove1's Avatar
jdmlove1
its fine with me if it looked stretched, i am goin for the 10.5 coz i might go for fat tires in the future. but now i really cant decide if i go with 275-40 or 275-35 re11
Old Aug 28, 2013 | 10:01 AM
  #1887
Tearik's Avatar
Tearik
Thats really up to the look you wanna go for I gues.s
If you scroll up to the pic i posted on this page of my car my rears are 275/40 so you can get an idea.
Old Aug 28, 2013 | 10:21 AM
  #1888
jdmlove1's Avatar
jdmlove1
your rear total diameter bigger or smaller than the stock wheels with 245-45?
Old Aug 28, 2013 | 10:24 AM
  #1889
Tearik's Avatar
Tearik
275/40 is .2% different than 245/45
so. basically the exact same size
Old Aug 28, 2013 | 11:37 AM
  #1890
terrasmak's Avatar
275/35 front and rear or 275/35 front with 275/40 rears are your better options.
Old Aug 28, 2013 | 12:28 PM
  #1891
David_2613's Avatar
David_2613
^ Good advice, I'm running 275/35/18 on all 4 of my 10.5" Enkei. Solid handling.
Old Aug 28, 2013 | 01:30 PM
  #1892
deadohiosky1984's Avatar
deadohiosky1984
I found a deal on the RPF1's I couldn't pass up. From what I read on the forums the 265 RS3's would be the best tire for my DD and occasional track needs in convenience, price and performance. I had the Falken Ziex ZE912's in the stock 225/235 17" sizes on for a few track events and am really excited to see what I can do with the RS3's
Old Aug 28, 2013 | 01:59 PM
  #1893
deadohiosky1984
18X9.5 +15 RPF1. 265/35R18 Hankook RS3
Pretty standard but I like it
Old Aug 28, 2013 | 02:31 PM
  #1894
redline06's Avatar
redline06
18x10.5 zero offset thanks to a 15mm spacer, tire is 285/35/18 Nitto 555R Drag radial
Old Aug 28, 2013 | 07:38 PM
  #1895
terrasmak's Avatar
They are awesome on track. Fontana Nissan meet, time to play
Old Aug 28, 2013 | 08:04 PM
  #1896
jdmlove1's Avatar
jdmlove1
thank you sir, i will go for 275-40 rear and 275-35 front.. i dnt want the car to be too low.
Old Aug 28, 2013 | 08:13 PM
  #1897
jdmlove1's Avatar
jdmlove1
yes.. this wat i wanted to know..but the problem every tire brand have a different profile..
for example my nitto invo 19-35 got the same side wall of Dunlap sport max 19-40!!
so am afraid that the potenza re11 18-40-275 will have a big side wall, and the total diameter will be bigger than the oem diameter.
Old Aug 29, 2013 | 08:43 AM
  #1898
redline06's Avatar
redline06
just look at the Specs of each tire, itll show all kinds of things like diameter, weight, width etc.etc. I normally use Tire Rack . Com to do tire research
Old Aug 29, 2013 | 09:22 AM
  #1899
Tearik's Avatar
Tearik
It shouldn't be different atd all
Since the sidewall ratio is a percentage of the width
275/40
Is 275mm wide and the sidewall is 40% of the width. So 275*.40
And they third number is simply the size wheel you need
Old Aug 29, 2013 | 09:37 AM
  #1900
3hree5ive0ero
Retired Admin
^ Not all tires of a same size are created equal. As mentioned above, check Tire Rack for specs.
