sizing question
Originally Posted by kaminariZ
Would a 19x10 with 275/30/19 tire and 20mm offset or 15mm offset fit all around without fender roll?
--Spike
can i get a response for both if possible? if i do say 15 all around, and then 20 all around. would i need to run camber to make them fit.
10” wide wheels on the front are too wide, even with a 22mm offset. A 15mm offset with 10” wide wheels on the front would be comical. But, it won’t rub.
If you go too wide on the front (and 275mm is wide), and you have any weakness in your suspension (i.e., wimpy or worn suspension parts), you will experience bump-steer and wandering at highway speed.
On the rear, 10” wide wheels with a 22mm offset should be fine, but a 15mm might require rolling the rear fenders. A 275mm wide tire is a good choice for the rear, but you should go with 275/35-19” (as terramask mentions) instead of the 30 aspect ratio you are considering for the rear. 275/30-19” on the rear will look small and may interfere with VDC (if you have that).
--Spike
ok, so do you think a 19x9.5 in the front would be good. what offset range would you suggest with a 9.5 inch wheel in the front to be okay? i had no idea about getting a 35 series tire in the back thanks for the help. But what about a 295/35, wouldn't that look just too beefy of a sidewall. if i moved up to 295 for the rear, should i get a 30 series tire? plus i read in car magazine that running 18x9.5 and 285 tire all around makes for the best handling in a Z car. they put it to the test with stock suspension and everything. and they pulled over 1G on the skid with just a wheel swap. which is kinda why i wanted to go that route. i only have 13k miles on my z, so suspension wearing shouldn't be a problem, and i only put around 2k miles a year on her.
