tpms question
Old Sep 3, 2008 | 09:41 PM
hran's Avatar
hran
Default tpms question
I've a question concerning the TPMS:
My tpms came on, and I'm just wondering what level of pressure triggers it to go off.
My tire pressures as measured by a pressure tool are 29.x, 31.x, 31.x, and 30.x.
thanks!
Old Sep 3, 2008 | 11:03 PM
xtremefairladyz's Avatar
xtremefairladyz
Mine went on when it went below 30psi.
Old Sep 3, 2008 | 11:05 PM
ericjackson's Avatar
ericjackson
Mine only come on at 28. Maybe the heat of driving made it go back up to 29?
Old Sep 3, 2008 | 11:08 PM
samjcg's Avatar
samjcg
i think regular is 35-38? I cant remember for stock tires. I always had it around 34 psi.
check tire pressure measurement on your driver side door panel.
There are specs how much psi you should have on front and rear tires..
I think 35 is normal though
Old Sep 4, 2008 | 02:50 AM
Z04's Avatar
Z04
thanks!
owner's manual. read it. learn something
Old Sep 4, 2008 | 06:13 AM
halcyon901's Avatar
halcyon901
i believe it is whenever the pressure goes below 28psi
Old Sep 4, 2008 | 06:30 AM
hran's Avatar
hran
Thanks all. I think mine is probably below 28, but the driving made it go above that.
not in it.
Old Sep 4, 2008 | 07:13 AM
Z04's Avatar
Z04
not in it.
you are just too frickin lazy to read it. directly pasted form the owner's manual, section 2
Low tire pressure warning light (if so equipped)
The light comes on for about 1 second when the ignition switch is turned ON, and then it turns off. NISSAN’s low tire pressure warning system is a tire pressure monitoring system. It monitors tire pressure of all tires except the spare. When the tire pressure monitoring system warning light is lit, one or more of your tires is significantly under-inflated. You should stop and check your tires as soon as possible, and inflate them to the proper pressure as indicated on the vehicle’s tire information placard. Driving on a significantly
under-inflated tire causes the tire to overheat and can lead to tire malfunction. Under-inflation also reduces fuel efficiency and tire tread life, and may affect the vehicle’s handling and stopping ability. Each tire, including the spare, should be checked monthly when cold and set to the recommended inflation pressure as specified in the vehicle placard and Owner’s Manual. The recommended inflation pressure may also
be found on the Tire and Loading Information label.
If the vehicle is being driven with very low tire pressure (lower than 28 psi), the light will illuminate and the chime will sound for about 10seconds.
For additional information, see “Low tire pressure warning system” in the “5. Starting and driving” section and “Flat tire” in the “6. In case of emergency” section. You can check the tire pressure of all 4 tires on the trip computer
display. See “Trip computer” earlier in this sec
Old Sep 4, 2008 | 08:17 AM
zettahertz's Avatar
zettahertz
weird... Mine seems to work the opposite or something, does it turn on when there's too much pressure?
Mine sometimes turns on in the middle of the highway, starts blinking then turns solid. I don't hear a chime though. And then in the morning when I turn it on, it blinks for a while, then disappears.... O_o what's with this? happened like 4 times so far. And it doesn't come back on on the next few drives. Checked the pressure on the first 2 times then just stopped checking after that, pressure seems normal.
Old Sep 4, 2008 | 03:50 PM
hran's Avatar
hran
I have a 2008 z. go find the manual online. it's NOT in it.
http://www.nissanextendedwarranty.co...r_manuals.html
Old Sep 5, 2008 | 07:42 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Sep 5, 2008 | 07:51 AM
jerseystyle's Avatar
jerseystyle
Nope, not in the manual. No offense, but does it matter? It goes off when you need air.
Old Sep 12, 2008 | 12:46 PM
starkiller's Avatar
starkiller
I have a 2007 and the TPMS light came on. Is there a way to determine via dash light which tire is low or is it a catch-all dummy light?
Old Sep 12, 2008 | 12:50 PM
jerseystyle
I don't think there is. Just gonna have to check all 4 of them.
issyz
Jul 2, 2017 03:04 PM
