19's in 255's & 285's?
Old Nov 3, 2008 | 03:07 AM
Big Tav's Avatar
Big Tav
Default 19's in 255's & 285's?
Hi guys, will 19's in 255/40's and 285/35 fit on a stock 350Z ok? Will I need to roll the guards? My car is not lowered at all. I have come across a set of these 2nd hand and I need to know if I should grab them tomorrow. Thanks.
Old Nov 3, 2008 | 05:01 AM
militia's Avatar
militia
thats the setup i have on my car.
Well, 18 inch up front and 19 inch on rear (stock rays)
Old Nov 3, 2008 | 06:02 AM
Zridder19's Avatar
Zridder19
Yea it will be fine
Old Nov 3, 2008 | 09:16 AM
DavesZ#3's Avatar
DavesZ#3
Should fit fine - depends on the wheel width and offsets though.
Old Nov 3, 2008 | 10:12 AM
raf84ny's Avatar
raf84ny
WELL,
Is your 2004 equipped w/ VDC?
I belive (255/40/19 ) 40 side wall is too tall.
Check the tire calculator.
255/35/19 is fine for the front.
I'm running 255/35/19 on 8.5 F and 285/35/19 on 10.5 R
and VDC is within the required specs (in order to work propertly.)
Old Nov 3, 2008 | 10:22 AM
Big Tav's Avatar
Big Tav
I have no VDC.
Old Nov 3, 2008 | 11:52 AM
raf84ny's Avatar
raf84ny
Originally Posted by Big Tav
I have no VDC.
You're good to go then!
"Depends on the wheel width and offsets though. "
Old Nov 3, 2008 | 02:23 PM
The front tire is taller than the rear. Is that what you want?
Old Nov 3, 2008 | 02:26 PM
DavesZ#3's Avatar
DavesZ#3
He's asking if they'll fit - not whether VDC will work. There's a good chance that TCS will kick in on him though.
You want 255/35 and 285/35 if you want to maintain stagger.
Old Nov 4, 2008 | 01:26 AM
Big Tav's Avatar
Big Tav
Ok. It's just that we have an M6 coming into work and they are replacing the tyres so they are new so we can sell it. The kicker is there is nothing wrong with the old ones! I can get them for free. They are the standard fitment on the M6 and thought I might just get a sweet deal.
Old Nov 5, 2008 | 12:51 PM
scotts300's Avatar
scotts300
What wheel width and offset?
Old Nov 5, 2008 | 07:39 PM
Triple8Sol's Avatar
Triple8Sol
You want 255/35 in front. 285/35 rear is perfect
Old Nov 6, 2008 | 11:02 AM
Big Tav's Avatar
Big Tav
Ok. I think the fronts will be too big then. I wonder why they run a bigger front diameter tyre on an M6?
Old Nov 6, 2008 | 11:07 AM
scotts300's Avatar
scotts300
I think they will fit just fine. Since they're "free", why not put them on and try them out? Seems like you have nothing to lose, although 285 is a bit large for your 8.5" wheel.
Old Nov 6, 2008 | 11:45 AM
gothchick's Avatar
gothchick
265/35/18 and 285/30/19.
Stock Rays 18x9 +30 and 19x10 +30.
Fits fine.
Old Nov 6, 2008 | 01:55 PM
scotts300's Avatar
scotts300
Fits fine.
He didn't say he has stock Rays. Clearly he doesn't, since he has 19" all around.
OP - what wheels (or at least sizes/offsets) are you talking about?
zland
Jun 11, 2005 01:38 AM
JJGALIA
Apr 17, 2004 01:31 PM
Driven
Dec 23, 2002 06:34 PM
