spare tire not fitting
Old Jan 10, 2009 | 09:44 AM
sbickle350z's Avatar
sbickle350z
Default spare tire not fitting
I smashed up my wheel and I am trying to put the spare on to get it to the tire shop. The spare off my z and a friends z is not fitting over the brake caliper. Has anyone else had the problem?
Old Jan 10, 2009 | 10:13 AM
Kwame's Avatar
Kwame
Where is it not fitting? Hitting the brake calipers? What is it hitting?
Old Jan 10, 2009 | 10:53 AM
terrasmak's Avatar
Do you have stock brakes, did you upgrade to OEM brembo's ?
Old Jan 10, 2009 | 02:06 PM
Spike100's Avatar
Spike100
It sounds as though you are trying to fit a stock spare tire/rim on a car with brembo’s.
If you do manage to get that spare on your car, be sure to turn TCS/VDC off if your car has this. The spare is undersized and messes with TCS/VDC.
--Spike
Old Jan 10, 2009 | 04:21 PM
sbickle350z
car does not have brembos. calipers on the back look smaller. I am going to try to fit it on the back and see if that works. car was bought 6 months used and i have not up graded the brakes.
Old Jan 10, 2009 | 07:53 PM
Adrenaline Rush's Avatar
Adrenaline Rush
Is it a front wheel? Did you take off the bolt on the front hub? It prevents you from putting the rear wheels on the front, but I think it may also interfere with the spare wheel.
Old Jan 10, 2009 | 11:05 PM
Yes but how does that help now?
Old Jan 11, 2009 | 07:11 AM
cheshirecat79's Avatar
cheshirecat79
Are you putting the wheel on backwards
Old Jan 11, 2009 | 03:02 PM
sbickle350z
I am an IDIOT!! I was not lining up that "6th" bolt on the front hub!!! I feel like I have never changed a tire before. Thanks for the help!!
Old Jan 11, 2009 | 06:21 PM
Do yourself a favor. Remove bolt #6, and toss it in the trash.
Old Jan 11, 2009 | 09:16 PM
terrasmak's Avatar
+1 and ,Make sure you do it on both sides so this doesn't happen again.
Old Jan 12, 2009 | 06:30 AM
sbickle350z
hahahahaha..... already done!!!
350z82
Oct 1, 2015 06:25 PM
