Adding spacers to OEM wheels
Old Apr 7, 2009 | 11:00 PM
Xzero's Avatar
Xzero
Default Adding spacers to OEM wheels
Hi everybody
I have a 2004.5 roadster with v1 OEM Touring rims (specs)
Front
Offset: +30mm
Weight: 26.56lbs
Tire: 225/45-18
Rear
Offset: +30mm
Weight: 26.56lbs
Tire: 245/45-18
I thought about adding spacers but I'm also planning on getting 06+ OEM wheels sooner or later.
Here's the V2 Touring specs:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
I see that installing +20mm in the front & +25mm in the rear are popular with the 06+ OEM wheels as they sit flush with the fender. Will those sizes work for both applications(v1&2) or do I need to buy different sized spacers for the v1 Touring wheels until I get the v2 Touring wheels?
What sizes can you recommend for the v1 Touring wheels if 20mm front/25mm rear combo doesn't work?
Last question, where is a good place to buy spacers? I dont wanna buy cheap crap that will crack & rust right away...
Old Apr 8, 2009 | 12:52 AM
Black Z Eddie's Avatar
Black Z Eddie
https://my350z.com/forum/southern-ca...ml#post6680674
Old Apr 8, 2009 | 03:09 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/wheels-and-...er-thread.html
Old Apr 8, 2009 | 03:33 AM
Z04's Avatar
Z04
waste of money to put spacers on a OEM wheel set-up (or any other wheel that fits properly) since it does nothing at all except stick them out a bit further and increases the amount of rocks and debris that hit the sides/rear of the car but hey, it's your car. do what you want.
Old Apr 8, 2009 | 04:24 AM
If you want to move your wheels do it. Worry about your next wheels when you have your next wheels.
Old Apr 8, 2009 | 07:04 AM
Midas78's Avatar
Midas78
Ichiban V2 Spacers, I installed mine a few months ago and have had 0 problems and they are very easy to install. I put 25mm all around for the 17" OEMs, you should be fine with the 20/25mm for the 18"s.
If you want to check for yourself how the wheels will fit, take a ruler and measure the distance from the outside of your tire to where the fender is, 25mm is ~1inch (if using a standard ruler).
Old Apr 8, 2009 | 09:10 AM
coolblue830's Avatar
coolblue830
cmon now, let's be honest. It simply looks better. There's a reason we're driving Z's and not spending our time at myprius.com
Old Apr 8, 2009 | 11:48 AM
JasonZ-YA's Avatar
JasonZ-YA
Done and done...see here and decide...
/thread
-J
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
