new 19"s causing tire pressure sensor light to turn on
Old Apr 21, 2009 | 11:28 AM
sleeper832's Avatar
sleeper832
Default new 19"s causing tire pressure sensor light to turn on
anyone else have this problem? I just put a set on, without the TPMS, and on longer trips (1-3 hours) the tire pressure sensor light on the left-most gauge pod will light up. really weird, never had this problem, and the tires are inflated just fine...
Old Apr 21, 2009 | 11:30 AM
quakerroatmeal's Avatar
quakerroatmeal
You've answered your own question. New wheel without TPMS will cause the light to light up.
Old Apr 21, 2009 | 11:39 AM
sleeper832's Avatar
sleeper832
damnit, i figured there would be an easier/cheaper fix than buying a new set of those monitors. gayness
Old Apr 21, 2009 | 11:45 AM
quakerroatmeal
You should of taken them out of the old wheels that had them, and put them in the new wheels.
Old Apr 21, 2009 | 11:48 AM
sleeper832's Avatar
sleeper832
i have a near-new set of tires on the OEM's that i didn't want to take off, take the sensors out of, put the tires back on, and then put the sensors on the new rim, then do all those steps again, once i change wheels in winter. its looking like im screwed and will just have to buy a set of TPM sensors. just dont feel like spending another 200. is there ever an in-expensive, simple modification that will ever go just as planned?
Old Apr 21, 2009 | 01:12 PM
There are no sending units in the wheels? I guess that would be it.
Old Apr 21, 2009 | 01:27 PM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/showthread....9&postcount=44
Old Apr 21, 2009 | 02:11 PM
terrasmak's Avatar
Do people think anymore ???
Hey i removed my steering wheel and i can't turn my car anymore!! Can someone help me figure this out?
Old Apr 21, 2009 | 02:18 PM
LAKERSFAN's Avatar
LAKERSFAN
make sure if you do get an extra set of tpms that they are compatible with the new wheels. may have to get adapters as well. i believe Forged makes them.
also, i put my sensors on my Volks. Fronts read ok (just a bit under what the actual pressure is) but my rears work only on occasion. Had them reprogrammed as well. Someone mentioned it may be due to the larger wider wheel? (19x10.5 rears)
Old Apr 21, 2009 | 02:55 PM
DavesZ#3's Avatar
DavesZ#3
Wheel size shouldn't have anything to do with them functioning or not. I, like many others have 19" volks, 9½/10½ and have no problems with the sensors or the system.
Old Apr 22, 2009 | 08:39 AM
sry110's Avatar
sry110
I don't have a set of TPMS sensors in my summer or winter wheels, so the yellow warning light is on my dash all year round. It just stays on, doesn't blink or do anything annoying, and I've learned to live with it. In fact I don't even really notice it anymore. I think you'll survive and it's probably not worth spending all the money to get new TPMS sensors, unless it bothers you that much. Just get into the habit of periodically checking your tire pressure the old fashioned way.
liqalu04
Jan 2, 2022 12:58 PM
wanderingstuden
Jan 28, 2016 07:03 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
