Official Aggressive Wheels & Fat Tires Thread
Old Dec 5, 2011 | 10:17 AM
  #2741
SoCal07HR's Avatar
SoCal07HR
Originally Posted by andre81k
Ahh my favorite thread... quick question anyone running "true" coilovers with a 11inch width wheel probably 305 tires, if so how is the clearance of the inside of the wheel/tire and the coilover... thx
I have 11 inch rears and there is plenty of room for a true coil. Mine are +30 so if you plan to go more aggressive there will be lots of room.
Old Dec 10, 2011 | 12:29 PM
  #2742
JonnyB504's Avatar
JonnyB504
20x10.5 +22
What tire size would have it sitting really nice in the rear? Thanks for your opinions.
Old Dec 12, 2011 | 06:16 AM
  #2743
kevin3fittyz's Avatar
kevin3fittyz
I have a question for lowered z owners... Will the front stock camber arms be able to bring the fronts back into spec or will i need aftermarket front camber arms along with the rears i already have
Old Dec 12, 2011 | 07:08 AM
  #2744
kno's Avatar
kno
Old Dec 13, 2011 | 04:12 PM
  #2745
TehkMob's Avatar
TehkMob
There isn't any adjustment for camber on the front only toe. Camber and caster are fixed on oem components
Old Dec 14, 2011 | 06:37 AM
  #2746
kevin3fittyz
hmm so the oem fronts will be able to bring /--\ back to l--l? Im thinking there might be some toe issues from lowering it too cuz ive driven it for less than a couple thousand miles and the front tires are wore pretty bad on the inside, or is this just from the camber? Thanks in advance for answering my noob questions
Old Dec 14, 2011 | 07:16 AM
  #2747
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
By fixed he meant they can't be moved. You will need aftermarket upper a arms in the front to correct camber (and spl are caster adjustable if desirable). Toe can be adjusted by your tie rods however. Toe will eat tires much much faster than camber, and I would suspect toe was your issue before I would camber if it has only been a few thousands miles unless you are running very dramatic camber.
Old Dec 14, 2011 | 07:26 AM
  #2748
kevin3fittyz
ohhhh i see i read it wrong ... thanks for clearing that up.
Old Dec 14, 2011 | 08:12 AM
  #2749
BEBO'S ZEE's Avatar
BEBO'S ZEE
What brand camber arms are most of you guys running anyway(for the front)?
Old Dec 14, 2011 | 08:29 AM
  #2750
EmpireDude's Avatar
EmpireDude
I have SPL that are sitting in my garage awaiting install. I think many would argue they may be over kill for a street car. They are also particularly pricey
Old Dec 14, 2011 | 09:56 AM
  #2751
brandon3434's Avatar
brandon3434
I would just say that they are quality parts, not overkill.
Old Dec 14, 2011 | 11:03 AM
  #2752
kno's Avatar
kno
think a 5mm spacer will rub? im about to buy new rear tires im running a 285 but im considering a 275
Old Dec 14, 2011 | 11:14 AM
  #2753
KingBaby's Avatar
KingBaby
Hardest Setting
find out...
Old Dec 14, 2011 | 11:38 AM
  #2754
brandon3434
kno, I wouldn't change a thing bro, looks perfect!
Old Dec 14, 2011 | 11:54 AM
  #2755
Waiz's Avatar
Waiz
5mm would probably rub but +1 on leaving it alone
Old Dec 14, 2011 | 11:56 AM
  #2756
-Trav-'s Avatar
-Trav-
+2, stick with 285...why downgrade? Youll have a shorter rear tire which means youll have to lower the rear, probably throw off the entire look.
Old Dec 14, 2011 | 12:04 PM
  #2757
Duckeee's Avatar
Duckeee
stickwithit
Old Dec 14, 2011 | 12:05 PM
  #2758
kno's Avatar
kno
mmm ok anyone wanna buy a ichiba 5mm spacer then? lol
Old Dec 14, 2011 | 12:17 PM
  #2759
brandon3434
^^^Actually, yes. I need a 5mm spacer for my fronts...send me a PM...
Old Dec 14, 2011 | 01:45 PM
  #2760
KingBaby's Avatar
KingBaby
Hardest Setting
Put them on!
>:I
atleastforpicsandtomakekingbabyhappyokthanksbye!
