Official Aggressive Wheels & Fat Tires Thread
Old Mar 11, 2012 | 03:28 PM
  #3241
Total D's Avatar
Total D
Originally Posted by SoCal07HR
Pretty easy to see they won't wonk. Hope you didn't already buy them.
Nope, wanted to ask here first before I made any final decisions.
What offset would work better with those sizes? Max rear tire I am looking to run is a 345. For the front looking at 275ish might be to small for 10.5s though.
Car is at the body shop now, so now is a good time to get it all figured out.
Old Mar 11, 2012 | 03:29 PM
  #3242
350Zdj's Avatar
350Zdj
Looks good, are the 9.5 inch wide?
Yes they're 9.5" wide
Old Mar 11, 2012 | 03:30 PM
  #3243
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Maybe mods need to.create new thread
"Neutral wheels and tires"
Shouldnt nothing under a 285 be posted
Old Mar 11, 2012 | 04:18 PM
  #3244
Waiz's Avatar
Waiz
There are threads for 18", 19", and 20" wheels already created that the non-aggressive questions should be asked in.
Old Mar 11, 2012 | 09:06 PM
  #3245
SoCal07HR's Avatar
SoCal07HR
10.5 up front has been done many times, I'm sure you can find examples you like and go from there. 12 inch wide rears with 345's is going to require widebody. I'm running 11 inch wide rears and my wheelwells are full with fenders rolled flat, I don't have any room to go closer to the damper or fender. Good luck. Post pics when you're done.
Old Mar 12, 2012 | 07:59 AM
  #3246
scotts300's Avatar
scotts300
I liked my 285/30/18 on the front 18x10.5 +15 a lot.
Old Mar 12, 2012 | 08:58 AM
  #3247
Total D's Avatar
Total D
I saw a few people running the 10.5's up front. So really wasn't worried about the front, more the rear. Just tying to fit the widest tire possible under the rear with a good roll and pull. If the 12" with 345 requires widebody, I'm not ready to do that quite just yet haha.
Thanks for the info Scott. What would you suggest for the rears, going off of what I said above?
Old Mar 12, 2012 | 09:11 AM
  #3248
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Seibon offers a +10mm front & rear cf fender.
Old Mar 12, 2012 | 10:00 AM
  #3249
SDGenius's Avatar
SDGenius
Old Mar 12, 2012 | 10:23 AM
  #3250
scotts300's Avatar
scotts300
Looking at changing my wheel setup from what I am running now.
I want more tire of course, I mean why else post in here. My question to you guys is, will the sizes work and what size tires would you recommend? I am on KW Clubsports coilovers with fender pull and roll.
19x10.5 +32 Front
19x12.0 +35 Rear
Thanks in advance for the help guys.
Jeremiah
Depends what you end up deciding on for the rear, as it looks like you're not doing the 12" rears and widebody just yet.
Old Mar 12, 2012 | 12:29 PM
  #3251
Total D's Avatar
Total D
I'm going to keep the stock body for right now. When the time comes for me to do widebody, I'll adjust fire then. For no,w I just want to fit the widest tire/rim I can with the body the way it is. If its 315 on a 11 that works too.
Old Mar 12, 2012 | 01:29 PM
  #3252
SoCal07HR's Avatar
SoCal07HR
Its done!
Front: 275/35-18 on 18x10 +25, -2 degrees camber, zero toe.
Rear: 295/35-18 on 18x11 +30, -1 degree camber, 1/16 total toe in.
Old Mar 12, 2012 | 01:33 PM
  #3253
SoCal07HR's Avatar
SoCal07HR
If that's the case i'd go with 11 inch wide +30 with a 315 and set camber to around -1.
Old Mar 12, 2012 | 02:41 PM
  #3254
scotts300's Avatar
scotts300
Its done!
Yowzers. . . looks awesome
Old Mar 12, 2012 | 03:15 PM
  #3255
SoCal07HR's Avatar
SoCal07HR
Thanks Scott. I really appreciate all your help and advice when I was ordering my wheels. I think it turned out great and I can't wait it try some larger tire sizes in the future.
Old Mar 12, 2012 | 03:18 PM
  #3256
jarrodh77's Avatar
jarrodh77
I think 12" rears are doable at about +30 to +33 offset. Assuming they clear the suspension inside, and I think they will based on SoCalHR07's measurement pics, they will only stick out 1-4mm farther than the popular 10.5 +15 setup. 345 would be pushing it, but 335 would probably work. I'll have a real answer for you in a few weeks once I get my new wheels in.
Old Mar 12, 2012 | 03:19 PM
  #3257
scotts300's Avatar
scotts300
Thanks Scott. I really appreciate all your help and advice when I was ordering my wheels. I think it turned out great and I can't wait it try some larger tire sizes I'm the future.
You're welcome. Glad I could help!
Old Mar 12, 2012 | 04:51 PM
  #3258
lgear080's Avatar
lgear080
nice outcome socal... really reminds me of my setup.
Old Mar 12, 2012 | 06:48 PM
  #3259
SoCal07HR's Avatar
SoCal07HR
I would not go any closer the the damper in the rear than mine are! My wheel contacted my damper at around -2.2 camber going through dips. My pictures are with no weight on the suspension and the wheel gets MUCH closer to the damper when compressed. I have about 10mm clearance at my ride height and I'm sure it comes very close as it compresses. Get spacers and pull the crap out of your fenders.
Old Mar 12, 2012 | 07:00 PM
  #3260
03threefiftyz's Avatar
03threefiftyz
Tucked back into the garage after a long weekend of racing in GA...
