Official Aggressive Wheels & Fat Tires Thread
Old Jun 21, 2013 | 10:26 AM
  #4821
CleanFairladyZ's Avatar
CleanFairladyZ
Originally Posted by scotts300
+20 or so, with 285/35 Hankook RS3 tires
Thanks for the reply. Are the RS3s a lot better than the V12s that most people have? Also the wheel I'm looking at is the SSR Professor. Not sure if people here like SSRs but if you have a better alternative for Meister-esque wheels chime in lol.
Old Jun 21, 2013 | 10:58 AM
  #4822
ProXR 440's Avatar
ProXR 440
Better for traction yes. The RS3 is a much softer tire and has a wider tread compared to a V12 of the same size. If you track your car or only drive it on the weekends I'd go that route. V12's won't wear as fast, are better on wet roads, cost almost 1/2 of what an RS3 does, and are perfect for a DD.
Old Jun 21, 2013 | 11:11 AM
  #4823
scotts300's Avatar
scotts300
Not quite 1/2 the price, $192 for the V12, $293 for the RS3.
Old Jun 21, 2013 | 11:42 AM
  #4824
ProXR 440's Avatar
ProXR 440
I guess in the smaller sizes it's not double. I just looked again since it's been a year since I've bought tires and in 305/30-19 it's still double. V12 is $238 and RS3 is $467 on tirerack. I couldn't justify the price difference just for driving my car back and forth to work.
Old Jun 21, 2013 | 11:52 AM
  #4825
CleanFairladyZ
I DD my car every day but also do a fair amount of autox. Almost every other weekend from May-October. I got the same prices you did scott (285-35-18). You think the extra 100 is worth it for my purposes? Also is there a "width" difference with the 2. I was under the impression that the V12s were on the "thin" side. As opposed to like an r888 which is "wider".
Old Jun 21, 2013 | 03:10 PM
  #4826
STL 350Z's Avatar
STL 350Z
Screw tire rack and their prices... www.discounttiredirect.com
Free ground shipping too
Old Jun 21, 2013 | 04:51 PM
  #4827
scotts300's Avatar
scotts300
They will amaze you as an autocross "street" tire... seriously worth it.
Old Jun 25, 2013 | 09:45 AM
  #4828
DarkCreep's Avatar
DarkCreep
I had the RS2's on my Civic and they were amazing when warmed up, I cant imagine how the RS3's will handle with a wider size.
Old Jun 28, 2013 | 06:14 AM
  #4829
STL 350Z's Avatar
STL 350Z
Quick question before I order my front tires today. I purchased Nitto Invo 305/30-19's for the rear (19x10.5 +20 wheels) and for the front I am stuck between 265/30-19 or 275/30-19.
Wheel spec's for the front are 19x9 +15 offset. What would be the best size to get?
Old Jun 28, 2013 | 11:16 AM
  #4830
ProXR 440's Avatar
ProXR 440
If it was a 9.5" wheel I'd say 275/30's for sure. Definately wouldn't do the 265/30's because the sidewall is smaller and overall diameter is smaller. Maybe consider 255/35's? But then you've got front tires that are 5 sizes smaller...
I guess you have to decide on what's more important, looks or performance. I wouldn't want a front tire that looks fatter on the wheel than my rear does.
Old Jun 28, 2013 | 11:36 AM
  #4831
STL 350Z's Avatar
STL 350Z
Damn. Already ordered the 265's after seeing Rober K's setup of 305/30 rear and 265/30 fronts. His setup looks great.
Old Jun 28, 2013 | 12:06 PM
  #4832
STL 350Z's Avatar
STL 350Z
I called and had my order changed to 275/30's. Discount tire said they would be ok on my 9in wide wheels with my 305's out back.
Old Jun 28, 2013 | 12:10 PM
  #4833
-Trav-'s Avatar
-Trav-
Good call, 265/30 on a 9.5 is too small IMO
Old Jun 28, 2013 | 12:28 PM
  #4834
ProXR 440's Avatar
ProXR 440
Robert K is on 19x11 and 19x9.5
You have 19x10.5 and 19x9
Old Jun 28, 2013 | 01:20 PM
  #4835
STL 350Z's Avatar
STL 350Z
I am aware of that. Thanks.
Old Jun 28, 2013 | 01:21 PM
  #4836
STL 350Z's Avatar
STL 350Z
Its a 19x9. Odd size I know...
Old Jun 28, 2013 | 03:11 PM
  #4837
mr. sparco's Avatar
mr. sparco
Don't always trust them. I had a manager argue with me that 225s would not fit on a x7 wheel for my wife's car. He would not mount it at all so I got his name, called corporate and they reamed his ****.
Old Jun 28, 2013 | 04:12 PM
  #4838
STL 350Z's Avatar
STL 350Z
If they dont fit right they'll be in the marketplace LOL!
Old Jun 28, 2013 | 04:32 PM
  #4839
-Trav-'s Avatar
-Trav-
Ah, even better in that case. Most 275/30's I see on 9.5's tend to look slightly stretched compared with a 305/30 on a 10.5". Im assuming youre trying to make front and rear look as even as possible, if so you should be money. In for results!
Old Jun 28, 2013 | 04:38 PM
  #4840
03threefiftyz's Avatar
03threefiftyz
275 is definitely not stretched on a 9.5....
