Official Aggressive Wheels & Fat Tires Thread
Old Jul 8, 2013 | 07:00 PM
  #4881
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Originally Posted by AlexBG
Yes fenders rolled all 4 corners.
Yeah I hate that lip.
I am probably going to do a bumper eventually. I just can't find anything that's not fiberglass.
Any suggestions?
Aerosync in full polyuerthane...
https://my350z.com/forum/body-exteri...yurethane.html
Old Jul 9, 2013 | 08:31 AM
  #4882
calistrat1991's Avatar
calistrat1991
I want to run wider tires on my 03 enthusiast. I was wondering how fat I could go without rolling the fenders. I want to keep the stock ride height as well. I have no plans of lowering the car, its just not my cup of tea... plus louisiana roads don't really allow for it
Old Jul 9, 2013 | 11:59 AM
  #4883
scotts300's Avatar
scotts300
Depends on wheel width and offset. 305s easy, even 315s in the rear, 285 front easy, maybe more.
Old Jul 9, 2013 | 01:20 PM
  #4884
jdmlove1's Avatar
jdmlove1
my wheels are +22 offset, 9.5 - 19 .. and when i kept the Invos 35-285 in the rear they rubbed the fender.. then i had to roll them..
Old Jul 9, 2013 | 11:37 PM
  #4885
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Found a clip of my Z from Houston Cars & Coffee in Feb. Took a screen shot of the the fitment of the rear wheels.
And in case I'm asked again...
HRE P43SC wrapped in Toyo R888 tires
305/30-19x11 +25.
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-screen-shot-2013-07-10-at-10.33.25-am.png
Old Jul 10, 2013 | 01:02 AM
  #4886
jdmlove1's Avatar
jdmlove1
^^^ woow! prefect fitment Robert! using 30 profile you can put a wider tire.
with 35 u will be limited to 295.. i guess!
Old Jul 10, 2013 | 01:21 AM
  #4887
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I'm actual consider a 275/30 or 285/30 front and 315/30 rear. We'll see. Working on my G37S fitment first.
Old Jul 10, 2013 | 01:50 AM
  #4888
jdmlove1's Avatar
jdmlove1
^^ make sure to post pics of the G once u finish.
Old Jul 10, 2013 | 02:00 AM
  #4889
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-img_1385.jpg   Official Aggressive Wheels & Fat Tires Thread-img_1352.jpg
Old Jul 10, 2013 | 02:12 AM
  #4890
jdmlove1's Avatar
jdmlove1
^^ you should add Carbon Signal front bumper with rear diffuser for the G!
Old Jul 10, 2013 | 02:17 AM
  #4891
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I've looked at them but not a fan on the Blueslate. Plus think I'm going to keep this simple and no carbon theme.
Old Jul 10, 2013 | 06:17 AM
  #4892
STL 350Z's Avatar
STL 350Z
@Robert K **cough** V2 front bumper w/ carbon lip & canards **cough**
Old Jul 10, 2013 | 08:46 AM
  #4893
Robert_K's Avatar
Robert_K
Didn't Go Cheap
**cough** next money into my Z will be for new turbos and/or intercooler **cough**
Old Jul 10, 2013 | 07:27 PM
  #4894
RAntunes's Avatar
RAntunes
i have been running toyo r888's 295s on 18x10's and 315s on 18x12's for some months now, although very stiff sidewall car handles great and hooks very well.
resting height it looks flush and full compression there is more room, as i said before , r888 335 will fit with the right height and camber settings, and if you are familiar with r888 you know they run extremely wide for their sizes. Which then its safe to say some 345's will also fit, again with the right combination of "ifs" . Of course fender pulling is a must.
i was going to put the 335's after i wore out this set, but my power goals have changed and now i will be going with 28 inch tall sticky mickeys 345/35/18's, and YES i know i can make them fit.
for a compact the z chassis has massive room for big rubber, its all in the details guys, and that does not mean you have to be running -3 camber either
note: this was the very first set of wheels i ever measured/bought , so anyone with a tape measure, common sense and some patience can achieve nearly any wheel combo on this car.
hope it helps!
Renato
Attached Thumbnails Official Aggressive Wheels & Fat Tires Thread-img_0672.jpg   Official Aggressive Wheels & Fat Tires Thread-img_0469.jpg   Official Aggressive Wheels & Fat Tires Thread-img_0931.jpg
Old Jul 10, 2013 | 07:52 PM
  #4895
KingBaby's Avatar
KingBaby
Hardest Setting
Nice...
Old Jul 11, 2013 | 05:17 PM
  #4896
freddys 350z's Avatar
freddys 350z
guys, i need some input for my fronts. right now i got 255-40 on a 18x8.75 +5 (same poke as a 18x10 +20) my front fenders do have a pull on them, see pic, an i wanna go to a 18x10 +15 with a 275-35 Michelin pss tire. (fyi, im on coilovers with 12 k springs in the front.)
right now its a d 350mile a week DD, so i dont want rubbing. and the main reason im upgrading is to kill my mid corner understeer when i autocross or cruise the hills.
so what do you guys think? should i do this or go to a 18x9+15 and put spacers on.
<a href="http://www.flickr.com/photos/72945596@N08/9263970369/" title="Untitled by freddy 350z, on Flickr"><img src="http://farm6.staticflickr.com/5463/9263970369_beb62bb17a.jpg" width="374" height="500" alt="Untitled"></a>
Old Jul 12, 2013 | 01:34 PM
  #4897
NA&CH's Avatar
NA&CH
You should fit. My need to do something up front. Looking for enkeis I have some for sale I had 18x10.5 +15 front with a 265.Pretty low. By no means "slammmmmmed"
Chris
Old Jul 12, 2013 | 01:35 PM
  #4898
03Screamer's Avatar
03Screamer
It's a tough call when it's that close and small/slight unknown variables come into play. If you have upper control arms, you could dial in a bit more camber and pull off that setup no problem though (I have 18x11 +15 on the front of my Z, with 285/35/18 Hankook RS3's, ~ -3.5 camber, pulled fenders and don't have any rubbing whatsoever).
The 18x10 +15 would obviously stick out another 5mm more (assuming your math is correct) from where your current rims sits - which wouldn't be a problem. With the 275/35/18 Michelin PSS (which runs fairly wide relative to the RE760 I believe), you would likely end up with a similar stretch as your current setup (see pic of 18x10/PSS 275/35/18 to get an idea http://farm9.staticflickr.com/8030/7...05d85a8d_c.jpg), so the tire would likely only stick out another 5mm or so from your current combo...which you could probably get away with (in terms of clearance), due to camber gain as the suspension travels.
But please don't take my word for it though, as these ones can be hard to call at times and you can never really be certain it will work until you physically do so lol. Best of luck
Old Jul 12, 2013 | 06:51 PM
  #4899
Lubo's Avatar
Lubo
This is 295/30/ 18 on 18x10.5 et15 dropped about an inch with -3.2 camber
As you can see plenty of space, no rubbing whatsoever, even during autocross.
I do no forsee any problems with your setup
Old Jul 12, 2013 | 07:18 PM
  #4900
Bmurray350z's Avatar
Bmurray350z
any rubbing on big dips in the road or anything^^ ?
