Official Aggressive Wheels & Fat Tires Thread
Old Oct 13, 2010 | 09:17 PM
  #1121
MannySRT8's Avatar
MannySRT8
Originally Posted by boomerz33
car is lookin clean man. The droid camera resolution is pretty crisp.
brandon..your car looks great..perfect balance
Old Oct 14, 2010 | 12:10 PM
  #1122
gotagetmyZ's Avatar
gotagetmyZ
Originally Posted by SQBassHead
gotagetmyZ^^^ YOU NEED A DROP ASAP!!!!!!!
love the fat tires.... what camber you @?
also are you lowered on anything at all?
Just finished a built motor so Coils will have to wait a lttl longer but I definately want to drop her a lttl more. It hard enough driving her w the Nismo bumper and Custom skirts
Front suspension is stock
Rear only has the spring boot cut Approx 3/4" w SPC camber arms n toe bolt.
Originally Posted by lemmiwinkz
looks good gotagetmyZ, i like the whole look of your car. what springs are you lowered on now?
Old Oct 14, 2010 | 01:18 PM
  #1123
zerafian's Avatar
zerafian
get a 1/2 more negative camber on that rear and drop it another 1" and youll be set. Good thing the beginning of that exhaust tip starts directly under your tires so it wont catch the ground.
Old Oct 15, 2010 | 09:35 PM
  #1124
bikinilust's Avatar
bikinilust
Originally Posted by ExtaZ33
whats the camber specs on this?
Old Oct 15, 2010 | 09:42 PM
  #1125
bikinilust's Avatar
bikinilust
Originally Posted by Kuhan
255/35/19 and 285/35/19
offset and camber please
Old Oct 15, 2010 | 09:52 PM
  #1126
bikinilust's Avatar
bikinilust
CAN ANYONE PLEASE CONFIRM??
Im looking to rock:
19x9.5 [+12] w a 255/35 and a 19x10.5 [+12] w a 285/35
my question is, can these specs be ran w less than or equal to -2.5 camber?
I intend on rolling the fenders tight, but DO NOT WANT TO PULL FENDERS.
Plus I will drop the car only till theres a ZERO GAP between tire and fender line.
DOnt like TUCKED and dont like GAP
Old Oct 16, 2010 | 05:14 AM
  #1127
dkmesa350z's Avatar
dkmesa350z
Im looking to rock:
Yes - running a 285/35-19 on a 19x10.5 +12 with -1.2 degrees of camber and I have a pinky's width to spare.
Old Oct 16, 2010 | 08:56 PM
  #1128
bikinilust's Avatar
bikinilust
are you running +12 offset all around and dropped w zero gap?
Got any pix?
Old Oct 16, 2010 | 09:13 PM
  #1129
sosojeffcc's Avatar
sosojeffcc
I'll know tomorrow what my camber is after i get my alignment. but no rub here...
Old Oct 16, 2010 | 09:42 PM
  #1130
ComeBack's Avatar
ComeBack
^^ That is a really nice tire fit/size. It doesn't flex over the rim nor is it stretched.
Old Oct 16, 2010 | 09:52 PM
  #1131
bikinilust's Avatar
bikinilust
this is disgustingly SIIIIICK!!!!
specs please
rim size, offset, tire sizes [+brand would be nice], fender modifications, camber, and if a camber kit was needed
I WANT THIS
  #1132
ALO8's Avatar
ALO8
^^^^post more pics after alignment. do you think a +7 in your setup would work?
Old Oct 16, 2010 | 10:02 PM
  #1133
sosojeffcc's Avatar
sosojeffcc
specs please
I WANT THIS
mike, you installed my gf210's back a couple of months haha. I've since switched to kw v1's. 19x10.5 +12. 285/35 falken FK452's. Fenders are rolled(this is a must). I have no camber kit tho. My last alignment with the gf210's was at -2.2/-2.1. I'm getting an alignment tomorrow, hopefully they can correct the toe without toe bolts, and we'll see where the camber ends up then.
more pics here: https://my350z.com/forum/media-share...installed.html
Old Oct 16, 2010 | 10:04 PM
  #1134
sosojeffcc's Avatar
sosojeffcc
my roll is pretty mild, but i think if i folded the fender a lil bit more a +7 miiiight work.
Old Oct 17, 2010 | 08:24 AM
  #1135
sosojeffcc's Avatar
sosojeffcc
Alignment came out to driver side -3.0 and passenger side -2.7. Probably won't be bothering with a camber kit.
Old Oct 17, 2010 | 08:38 AM
  #1136
midz350's Avatar
midz350
Originally Posted by gotagetmyZ
Sir, you have a mean looking car
Old Oct 17, 2010 | 01:42 PM
  #1137
bikinilust's Avatar
bikinilust
with these numbers, how much clearance do you have between the tire and the rear fender?
DO you think if you went with an aggressive fender roll [not pulled though] you'd be able to get the camber to -2.5 or less?
Old Oct 17, 2010 | 01:54 PM
  #1138
sosojeffcc's Avatar
sosojeffcc
I think with an aggressive roll one could bring it back to -2.5, but it really depends on the tire brand as well. I remember people saying that the fk452's run on the narrow side, compared to say the KDW's.
Old Oct 18, 2010 | 11:11 AM
  #1139
bikinilust's Avatar
bikinilust
hmmmm....
I wanna rock this but dnt wanna have to flip my tires every other oil change
Old Oct 18, 2010 | 12:44 PM
  #1140
scotts300's Avatar
scotts300
hmmmm....
Flip your tires? What are you specifically referring to?
