new to aftermarket wheels..help?
Old Jun 23, 2009 | 08:07 PM
kaiwei's Avatar
kaiwei
Default new to aftermarket wheels..help?
so basically, im new to this wheel thing, im looking at a set of rota d2s 18 x 9.5 which is available in :
30mm offset + 67.1mm bore
50mm offset + 73mm bore
i understand what an offset refers to, and what the bore refers to, but my question is what would you guys recommend? this question might seem pretty simple to most of you but its new to me, and thanks for any input
Old Jun 23, 2009 | 08:19 PM
terrasmak's Avatar
the 30mm offset ones
Old Jun 23, 2009 | 08:25 PM
2k6-z33's Avatar
2k6-z33
^Yeah the 30mm with 20mm spacers.
Old Jun 23, 2009 | 08:53 PM
I am not sure if a 9.5 inch wheel 30 mm offset will clear the brake calliper.
Old Jun 24, 2009 | 12:44 PM
kaiwei's Avatar
kaiwei
okay, thanks for the responses, i looked into the availability and if i go 18x8 in the front, should i go with the +25 or +48 offset? and for the rear if i go 18x9 should i go +30 or +50? thanks for any input
Old Jun 24, 2009 | 12:52 PM
Bumpinjeep's Avatar
Bumpinjeep
Why not just get a used set of quality wheels instead? You can pick up a used set of Volks with a +22 and your car would look great. You wouldn't really need any spacers or worry about proper fitting. Do you have Brembos or a BBK?
Old Jun 24, 2009 | 12:53 PM
Not sure if you comprehend the relationship between wheel width, offset and wheel position.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 24, 2009 | 12:55 PM
BTW when you start talking +48 and +50 mm offset I think you are looking at wheels for front wheel drive.
Old Jun 24, 2009 | 01:18 PM
GeauxLadyZ's Avatar
GeauxLadyZ
If your going with 8" wide in the front, and 9.5" in the rear...get the LOWEST possible offsets you can find. (lowest as in lowest number)
For 8 and 9.5, the optimal would be something around 10mm - 15mm, respectively.
Old Jun 24, 2009 | 02:06 PM
WheelDude.com's Avatar
WheelDude.com
Vendor - Former Vendor
The Rota D2 only comes up to 18x9 fitment and is not offered in 18x9.5 fitment. The most aggressive size is 18x9 +30 and to be honest, this wheel wasn't made specifically for the 350Z. This wheel will "fit" the car however due to the higher offset the fit won't be ideal and would require spacers in the rear to achieve a nice stance.
We do carry a wide variety of Rota Wheels specifically for the 350Z that come in better fitments (typically 18x9 +20 front, 18x10 +20 rear). If you have more questions feel free to post or PM me
The 18x9 +48 to +50 model is the rear wheel for Honda S2K applications. This is one of the few RWD cars that use a very high offset wheel
-Dan
Old Jun 24, 2009 | 09:22 PM
kaiwei's Avatar
kaiwei
thanks for all the info, and yeah a typo on that, it was supposed to be 18x9 in the rear. ive been lurking the marketplace sections and nothing that really catches my eye. hopefully something will come up in my favor
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
