Another terrible question...
Old Jul 30, 2009 | 07:11 PM
350ZToeRing's Avatar
350ZToeRing
Default Another terrible question...
1. Can you fit a 255/35/19 tire on an 8" rim? (tire rack said yes but I don't know if I trust them)
2. Can you/has anyone successfully ran a 255/35/19 / 275/35/19 set up without any problems?
Stock height. 8" front rim , 9.5" rear rim.
Old Jul 30, 2009 | 07:21 PM
GeauxLadyZ's Avatar
GeauxLadyZ
1. I wouldnt, but its possible, yes....hazardous, yes
2. yes, but few if any on YOUR rim specs
EDIT: I would go with a 245/35/19 in the front at max with a 8" rim
Old Jul 30, 2009 | 07:23 PM
jbuff's Avatar
jbuff
a 255 is the optimal size to run on a 8.5" from what i know...so id bump that down a bit for your own good
Old Jul 30, 2009 | 07:26 PM
GeauxLadyZ's Avatar
GeauxLadyZ
245 is the optimal for 8.5.
He shouldnt run 255 on an 8".
Old Jul 30, 2009 | 07:54 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
If you go to the tires manufactures web site the size will tell you what size wheel to run.
Old Jul 30, 2009 | 08:48 PM
scotts300's Avatar
scotts300
255 is pushing it on an 8" wheel. Maybe the particular tire you are referring to is more narrow than other 255s, and that's why TTR said it was ok. 245/275 are more appropriate for your 8/9.5 combo.
Old Jul 30, 2009 | 09:14 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
25.4mm per inch. Hence you've got a good inch on each side of tire bulbage (technical measurement!)
Old Jul 31, 2009 | 07:44 PM
350ZToeRing
yah I know 245/275 is the most appropriate setup, and its currently what I'm running. I just found a great deal on some 255's and thought I might be able to beef it up in the front.
My other question with it was the VDC factor. Would it engage due to this?
3vilbunny
Jul 18, 2017 05:10 PM
Nihsnek
Feb 9, 2016 12:57 AM
Paul.
Oct 16, 2015 07:34 PM
MATIX
Aug 23, 2003 11:45 PM
Rob Nance
Texas
Apr 11, 2003 07:34 AM
