light while driving
Old Nov 23, 2009 | 08:10 PM
al71's Avatar
al71
Default light while driving
Sometimes while driving long distance an alert sign comes up. Looks similar to
I dont believe its the tire pressure because i already checked that. Does anyone know the problem?
Old Nov 23, 2009 | 08:16 PM
s31t8n8's Avatar
s31t8n8
if its an ! enclosed in a circle and parentheses than it is a brake warning light. If its an ! with parentheses and a line at the bottom than its the tire pressure warning. There is something wrong with whichever sensor it is
Old Nov 23, 2009 | 08:17 PM
Spike100's Avatar
Spike100
It's your TPMS telling you there is low pressure in at least one tire.
Ifr you did a manual check and all is well, it may be a malfunction.
--Spike
Old Nov 23, 2009 | 10:31 PM
350ZTheStandard's Avatar
350ZTheStandard
Quit looking at the gauges, & pay aTTention to the road.
Old Nov 23, 2009 | 11:28 PM
roskoracing777's Avatar
roskoracing777
If its the brake warning light, then he should be paying attention to it, I is a very important warning light. It signals the driver that there may be something wrong with the brake system.
But, I agree people should pay more attention to the road.
Old Nov 24, 2009 | 03:16 AM
DavesZ#3's Avatar
DavesZ#3
If it's a light that comes on after 30-45 minutes of driving, then it's the TPMS warning telling you that one or more of the sensors is not being detected. Do you have aftermarket wheels on your Z? Do they have the original TPMS sensors installed?
If you're sure you have the sensors installed, then one or more of them is not working and the system is not detecting it.
Old Nov 24, 2009 | 06:05 AM
KornerCarver's Avatar
KornerCarver
I believe it is the brake warning light. Your fluid might be a little low or the pads might be wearing out.
Old Nov 24, 2009 | 10:31 AM
CFactor's Avatar
CFactor
So I have low tire pressure but haven't had time to put air in my rear right tire. Will an audible warning tone go off when the sensor registers low pressure?
Old Nov 24, 2009 | 11:35 AM
GeauxLadyZ's Avatar
GeauxLadyZ
^What he said....exactly.
The computer is not picking up one or more of your tpms monitors...this is the only reason light should come on after 30-45 mins.
It is NOT braking system, and it is NOT low pressure warning.
To test if pressure is low after warning light appears, stop car, turn off, then turn back on....light and audible signal should appear instantaneously. If it does not, and only comes on after driving long period, problem is what is stated above.
Old Nov 24, 2009 | 01:38 PM
DavesZ#3's Avatar
DavesZ#3
If the pressure drops below about 28psi, then yes, you should get a warning. Once you put air in and drive it again, the warning should go off.
Old Nov 27, 2009 | 07:12 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Most likely just an undetected TPMS Sensor. It goes off after about ~30 miles of driving
Old Jan 13, 2010 | 06:52 PM
BOOCKER's Avatar
BOOCKER
Default same problem
i have that problem the light goes on after 30 minutes, if i turn the car off and turn it on again, the light goes off, but after 30 minutes it goes on again...
Old Jan 14, 2010 | 03:15 AM
DavesZ#3's Avatar
DavesZ#3
https://my350z.com/forum/showthread....9&postcount=44
Old Jan 14, 2010 | 03:32 AM
maXmood's Avatar
maXmood
Under Boost!
if it's ur TPMS, and your tires are maintaining pressure. then check ur tires for a nail/screw or some sort of these things.
i've been in the same situation couple of times..
Old Jan 15, 2010 | 03:32 PM
BOOCKER's Avatar
BOOCKER
They r mantaining pressure, i already checked it, and i still have the problem, i check for any nail, or something like that and nothing...
i only have the problem after 30 minutes, if i turn off the car, the like turns off, and if drive for 30 minutes it goes on again...
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
