Enkei NT03s help!!
Old Dec 29, 2009 | 11:05 AM
TheBlue350z's Avatar
TheBlue350z
Default Enkei NT03s help!!
im looking at getting the the Enkei NT03+M wheels.
Front:18X10.5 +30 offset
Rear:18x10.5 +30 offset
Is there any problem running 10.5 all the way around. Is there a diffence with using a staggered look.
What size tires should i be looking at.
Old Dec 29, 2009 | 12:28 PM
eltness350's Avatar
eltness350
The Untouchable
that offset might be pushin it in the front, might have to roll the fender ...but the rear is good, thats what i have and no roll was needed even when i lowered mine. i would go staggered only cause unless u r tracking the car and want a square setup its pointless imo. i have 305's on my 10.5 rears....they can handle up to 335's but thats a ton of tire and $$$$...for the front stretch a 275 im thinkin....
Old Dec 29, 2009 | 03:07 PM
terrasmak's Avatar
I have the staggered set of those. Possibilities are endless, 275/35 front and 295/35 rear , 245/40 or 255/40 front and 275/35 rear. None of those will rub, you can see pics of my car under my profile, but i run a 20mm rear spacer and 10mm front spacer.
10.5 in the front, don't know. Never tried to fit them, don't know if they will fit or not. May need a 5mm spacer to keep them from rubbing the inside.
Old Dec 29, 2009 | 05:16 PM
BloMyS14's Avatar
BloMyS14
Yea you might need a spacer in the front.
Old Dec 30, 2009 | 06:44 AM
TheBlue350z
so 275/35-front and 295/35-rear will look the best for those set of rims.
Old Dec 30, 2009 | 06:47 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it will need a spacer up front and it doesn't clear a big brake kit up front (not by a long shot)
Old Dec 30, 2009 | 06:52 AM
terrasmak's Avatar
9.5 front clear BBK's no problem. I have heard that 13 inch kits may require a 5mm spacer, and i know 14inch kits clear without.
Old Dec 30, 2009 | 06:53 AM
Z1 Performance
Former Sponsor
but 10.5 +30 doesn't
not all 9.5 clears either...it depends on the offset. There are no absolutes with 13 inch kits fitting/not fitting or 14 inch kits fitting or not fitting. It all depends on the specific kit - they each have different clearance needs, sometimes by substantial amounts
Old Dec 30, 2009 | 07:22 AM
TheBlue350z
i dont have a big brake kit, nor will i get one, maybe just aftermarket rotors and pads. I would like to have a neurtal stand with 10.5 all the way around. i dont mind getting wheel spacer, but wondering what size to get 15,20,25mm (Front/Rear)? and what size tire will look and fit the best?
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
