Rota Torque Offset question
Old Mar 2, 2011 | 09:59 PM
c_buz's Avatar
c_buz
Default Rota Torque Offset question
I am planning on getting a set of Hyper Black rota torques 18x9.5 all around for my redline 350z. My question is with offset. I know a lot of people run +20 with these. However I want to get the most concave look I could get away with. Correct me if I am wrong:
If I run a higher offset than +20 then that means I will have the wheel closer to the fender thus less concavity on the rim.
And If I run a lower offset (if it is even available) it would look more concave but the wheel would not be flush with the fender?
Old Mar 2, 2011 | 10:04 PM
calin's Avatar
calin
You got it the other way around. The lower the offset, the closer the wheel will be to the fender.
Old Mar 2, 2011 | 10:08 PM
kemps's Avatar
kemps
Exactly what calin said, what size tires are you going to run, that will effect what offsets you should get.
Old Mar 3, 2011 | 07:39 AM
dan avoN7's Avatar
dan avoN7
The lower the offset the further out the wheel will sit. The Torque is commonly offered is 18x9.5 +28 and 18x9.5 +20 fitments. The 18x9.5 +20 mode will sit exactly 8mm's further out on the car, ie flusher with the fender. Also, if you have Brembo brakes you will want to get the +20 model as these will clear the front calipers without spacers.
In regards to wheel concavity, all Rota Torque's in 18x9.5 look identical. This is a cast aluminum wheel based off one single wheel mold. Offset is changed by the use of a hub adapter during production so the concave, spoke profile, etc.. is identical regardless of the offset. I would suggest the 18x9.5 +20 model on the 350z. It looks great and will fill the fenders properly
Old Mar 3, 2011 | 07:42 AM
Use a offset calculator and see how the wheel changes position when you change offset.
Old Mar 5, 2011 | 10:02 PM
c_buz's Avatar
c_buz
tires will be 265 rear and 235 fronts. Goodyear eagle F1. They are almost brand new so I am going to keep them foe the new setup
Old Mar 5, 2011 | 11:35 PM
sportbiketed's Avatar
sportbiketed
Sell them and run 245 & 285 or 255 & 295.
Old Mar 6, 2011 | 09:04 AM
c_buz's Avatar
c_buz
I don't want to loose money on a st of tires that has less than 4k on them. Those will work for now. The smallest size you can fit upfront I think is 245 so 235 should work also. They will be slightly streched.
Old Aug 26, 2011 | 05:28 PM
Did the old tires fit the new wheels?
issyz
Jul 2, 2017 03:04 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
