new tire sizes, suggestions and recommendations appreciated
Old Oct 24, 2013 | 06:05 PM
TIGERTREV67's Avatar
TIGERTREV67
Default new tire sizes, suggestions and recommendations appreciated
I'm thinking of getting wider tires but not sure what sizes will and won't fit
Old Oct 25, 2013 | 04:47 PM
Z-Crazy's Avatar
Z-Crazy
What's your budget, wheel size and weather?
Old Oct 26, 2013 | 09:02 AM
terrasmak's Avatar
I would start with your wheels that are currently on your car. I'm good, but i for some odd reason don't have the info I need.
Old Oct 28, 2013 | 02:55 PM
TIGERTREV67
It has 225/45R18 front and 245/45R18 rear, just kinda pricing around, and hot summer to cold winter but, NO snow driving
Old Oct 28, 2013 | 04:08 PM
Spike100's Avatar
Spike100
I’m guessing your car is equipped with stock 8x18” wheels. If that is the case, you are limited to 245mm wide tires.
One change you might consider if you keep the stock 8” wide wheels is mounting 245/40-18” up front. That provides better grip on the front and reduces understeer with 245/45-18 on the rear wheels.
If you want wider tires, you need to purchase wider wheels. --Spike
Old Oct 29, 2013 | 05:32 PM
TIGERTREV67
That I know, I was wanting to know how wide of wheels (rims and tires) I can put my car.
Old Oct 29, 2013 | 08:59 PM
terrasmak's Avatar
https://my350z.com/forum/wheels-and-...es-thread.html good place to look.
Old Oct 30, 2013 | 08:39 PM
Spike100's Avatar
Spike100
Ok and Sorry…. I missed that completely.
You can mount a plethora of wheels and tires on the 350z. That certainly is a feature making the 350z so much fun.
The easy sizes are 245 front and 275 rear. This size provides ideal handling for your 350z. That tire size dictates ideal wheels are 8.5” front and 9.5” wide rear.
--Spike
Old Nov 2, 2013 | 09:12 PM
TIGERTREV67
I was told by a tire and wheel expert I could do 295 front and 325 rear or 10" front and 12" rear
Old Nov 2, 2013 | 09:50 PM
terrasmak's Avatar
You can get wider up front,just depends on the setup. Then wheels are one thing, tires different.wheels get refuted to in inches ie 10 inch front, also useless without offset listed. Tires are always metric unless you talking about trucks, they still have inch sizes at times
Old Nov 4, 2013 | 04:29 PM
TIGERTREV67
Lots of the rims choices I've looked at have offset listed
Old Nov 4, 2013 | 06:13 PM
Spike100's Avatar
Spike100
I’m not sure what you are asking?
The best result comes from a selection of tire size, wheel size, and wheel offset. You can search on this site for all that information as well as seeing the installed setups.
--Spike
Old Nov 4, 2013 | 09:21 PM
Waiz's Avatar
Waiz
Before proceeding any further you need to set a realistic budget with tires
Then we can actually help you...
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
SharX59
Sep 27, 2015 09:23 AM
