What tires for 19x9.5 +22 all around
Old Mar 24, 2022 | 10:45 PM
Asher king's Avatar
Asher king
Default What tires for 19x9.5 +22 all around
Im going to buy wheels and tires but i need help to know if the sizes im going with are going to rub on anything. Stock suspension but im definitely going to lower. Will i need to roll fenders?
wheels are 19x9.5 +22 square setup
for tires i need help i dont want them to be stretched but as close as i can get them without them having to be the better
I mostly worried about rubbing on the upper control arm. I will daily it in rain and snow as well so whatever size works good for that as well.
also if going with a square setup will screw with anything
any help is greatly appreciated
Old Mar 25, 2022 | 03:06 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
245/35-19 & 275/35-19
Please don’t triple post.
Old Mar 25, 2022 | 06:08 AM
Asher king's Avatar
Asher king
sorry im new to this I didn’t realize that i did
so even tho my setup is square i should still put wider tires in the back?
Old Mar 25, 2022 | 04:54 PM
Ponyryd's Avatar
Ponyryd
It depends what look and performance you’re after, if it’s just a driver I’d run 245/40 all around, this setup will be slightly stretched though.
Old Mar 25, 2022 | 04:59 PM
Asher king's Avatar
Asher king
grip preferably
For looks i would want them looking to chunky but just normal really
Old Mar 25, 2022 | 05:14 PM
Ponyryd's Avatar
Ponyryd
9.5” will need a wide tire to look chunky, so if that’s the case I’d be looking at 265/35 or even 275/35, but it’s tough to say if it would rub after lowering as there are too many variables. My concern is with you running such a wide tire in the snow, as it will be pretty hard to handle, but it’s your call man.
Old Mar 26, 2022 | 05:26 AM
MicVelo's Avatar
245/40-19 is a Z34 front size; too tall for Z33. It clears fine, just a little awkward with car being nose high.
265/35 or 275/35 (better fit) are well within the 120% recommended rim:tire ratio. Very unlikely it will rub. Only time I rubbed a 275 on 9.5 wheel was with +15 offset. Roll n’ seal took care of that.
Old Mar 26, 2022 | 10:23 AM
Ponyryd's Avatar
Ponyryd
I didn’t see anywhere where he mentioned what year car, or even what brand or model of car he has, my size estimate was based on his intended use, and the wheel widths. As well he said he would be lowering the car, so without knowing how low he plans to go it’s very hard to say what will rub and what won’t.
xxboarderxx
May 27, 2012 10:11 AM
travismaser
Mar 3, 2011 08:48 AM
ericjackson
Dec 29, 2009 05:23 PM
ANXIOUZ
Southern California
Sep 4, 2007 01:28 PM
zzz350zzz
Photoshop
Aug 5, 2007 03:30 PM
